Aero tow cost estimation
Old July 7th 14, 11:08 PM posted to rec.aviation.soaring
Bill D
Default Aero tow cost estimation
I need a detailed spreadsheet or work-up on tow plane costs. Anybody have one?
Old July 8th 14, 08:24 PM posted to rec.aviation.soaring
noel.wade
Bill -
I've done a ton of work looking into towplane costs over the last 4 years for my club. I have extremely detailed breakdowns of costs and maintenance and all kinds of good stuff. But unfortunately its very hard to provide you a spreadsheet that would accurately predict _your_ costs, because so much depends on:
1) What aircraft you're using
2) How the aircraft is equipped and under what conditions its used
3) Local costs of fuel & storage
4) How it is maintained
5) Whether you need to save money to have cash-on-hand for long-term maintenance items or whether you can finance these things over time
There are a lot of generalities that I can give you; but without knowing more I can't provide meaningful numbers.
Care to explain the situation and/or what information you're seeking to learn, specifically?
Take care,
--Noel
Old July 8th 14, 08:49 PM posted to rec.aviation.soaring
Bill D
I was hoping to find a spreadsheet where I could plug in variables like TBO, overhaul cost, fuel consumption, fuel price etc... Failing that, a workup for one tug might provide a methodology from which I could create my own spreadsheet.
Bill -
Take care,
--Noel
Old July 13th 14, 06:05 PM posted to rec.aviation.soaring
noel.wade
Bill - I'm not trying to be obtuse; but it really does depend on a LOT of factors. Here are a few of the major factors:
1) The operational environment (club vs commercial, for example)
2) How you use the ship (regular tows? lots of high tows? double-tows? new towpilot checkout?)
3) Runway surface and condition (smooth grass, rough grass, compact dirt, asphalt, ??)
4) What kind of ship you use (Pawnee? SuperCub? Cherokee or C-182?)
5) How many tows per year you expect to do
6) How many total towplanes will you be operating
7) Local weather (goes to your hangar/storage requirements and how many months out of the year you can use the airplane)?
8) Financial "style" of your business/club (do you require a funded reserve account so that you can pay cash for maintenance and repairs when items hit their expected life-limit; or is using credit or loans - either commercial or private - an option)?
9) Commercial use of your equipment - Are you offering a lot of commercial glider rides, or flight instruction, or other use that requires you to pay taxes and/or perform more-frequent inspections on your towplane?
These items need to be decided/outlined before any accurate numbers can be factored - otherwise you're just firing blind.
Take care,
--Noel
Old July 13th 14, 08:04 PM posted to rec.aviation.soaring
Bill D
Take care,
--Noel
Noel, you are not being obtuse at all - your points are excellent. I agree, there are a lOT of variables. To be clear, I'm not looking for actual costs because, as you say, they vary a lot from site to site for a lot of reasons.
I was just hoping someone had put all (or most) of those variables into a really big spreadsheet so different tug operations could plug in their particulars to more easily understand and budget their tug costs.
Old July 14th 14, 06:13 PM posted to rec.aviation.soaring
Morgan[_2_]
Bill,
I think I have what you are basically looking for. You'll have to adjust the variables for your scenario, but I did this breakdown years ago.
What has continually been a factor outside the ability to capture in a spreadsheet are the unexpected costs. The engine that hadn't been run routinely for the last 10 years or whatever prior to our acquisition and subsequent internal corrosion that resulted in a rebuild at 1200hrs instead of 2000.
Or the "oops" hangar rash that adds $2000 to your costs by surprise. The general stuff is pretty easy to calculate and pad for based on hours or tows..
Morgan
Take care,
--Noel
Old July 14th 14, 08:05 PM posted to rec.aviation.soaring
Bill D
Morgan, it's true - large, unexpected costs are a normal part of the airplane ownership experience. Having owned all or part of several airplanes, I managed to get buy by adding 35% to the expected costs to cover unbudgeted liabilities. Sometimes there was an annual surplus, sometimes a deficit but it seemed to average out. But then, maybe I was lucky.
Could you upload your spreadsheet to a public DropBox folder and let us have the link. I kinda hate to put an e-mail address on RAS.
On Monday, July 14, 2014 11:13:00 AM UTC-6, Morgan wrote:
Bill,
What has continually been a factor outside the ability to capture in a spreadsheet are the unexpected costs. The engine that hadn't been run routinely for the last 10 years or whatever prior to our acquisition and subsequent internal corrosion that resulted in a rebuild at 1200hrs instead of 2000..
Morgan
Take care,
--Noel
Old July 15th 14, 01:03 AM posted to rec.aviation.soaring
Frank Whiteley
The SSA Member Locator works a treat for finding member e-mails, much of the time, if the member keeps the information up to date, and you can guess the real first name if different from the commonly known name.
The USENET used to be the spammers early collection site for e-mails, but after I recently did some updating in LinkedIn, that seemed to cause a huge uptick in spam to an e-mail address which had been clean for years.
YMMV,
Frank Whiteley
Bill,
Old July 15th 14, 06:00 AM posted to rec.aviation.soaring
Morgan[_2_]
Hi Bill,
Took me a little while to get back to this, but I've got two spreadsheets to share with you.
One is a pretty generic airplane cost that you'll probably look at and feel familiar with. It's one I got from someone, cleaned up and added a few formulas in order to make changing variables cleaner and easier when trying to assess costs.
The second is pretty old. How old? Well, Avgas was $4.10gal last time I updated it. It was $5.85 here when I fueled on Sunday.
In any event, it's not terribly pretty, but allows you to assess the cost across the number of tows each year. That one is the GenericTowplaneCost.xls file.
Between the two you can probably work out a reasonable cost structure to anticipate for providing tows. Our towplane has been great for our club, despite an early rebuild and some unexpected damage pulling it from the hangar one day. I think we've been turning close to $20,000 in tow revenue annually as of late and that is at relatively low tow rates thanks to volunteer tow pilots.
Towplane Operational Costs:
https://dl.dropboxusercontent.com/u/...tEstimate.xlsx
Tow Costs vs Revenue
https://dl.dropboxusercontent.com/u/...cTowCosts.xlsx
For what it is worth we are operating a Cessna 150/150 at an 800MSL private airport. 3000ft runway and 100+ temps in the summer time. We try not to take high tows in the heat of the day, but generally they aren't required and once you find a good thermal you can climb better off tow.
Hope this is helpful. You can look me up on the member locator if you want to hit me up directly about anything.
Morgan
Bill,
Old July 15th 14, 04:57 PM posted to rec.aviation.soaring
Dan Marotta
Bill, you email address is displayed in the "From" line of your
message. At least it is on my laptop using Firefox...
Dan Marotta
Bill,
Morgan
Take care,
--Noel
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
Wright Cyclone price estimation Ricardo Reis Restoration 0 September 30th 03 10:26 AM
