Can anyone give me some pointers on how to research the FAA database to find out if a glider has a standard airworthiness certificate or must be registered in the experimental category?
Thanks, Uli |
Most any aircraft or glider will have a "Type Certificate Data Sheet" on file with the Federal Aviation Administration. You can search for the TCDS by Make/Model on FAA.gov. The TCDS will have the registration category listed. Some may change by serial number.
A copy of the TCDS should be part of the aircraft records. BillT |
On Tuesday, July 15, 2014 11:19:28 PM UTC-4, Bill T wrote:
Most any aircraft or glider will have a "Type Certificate Data Sheet" on file with the Federal Aviation Administration. You can search for the TCDS by Make/Model on FAA.gov. The TCDS will have the registration category listed. Some may change by serial number. A copy of the TCDS should be part of the aircraft records. BillT Thanks Bill! I wasn't familiar with that terminology. Found the db for the TCDSs. Uli |
At 03:01 16 July 2014, GM wrote:
Can anyone give me some pointers on how to research the FAA database to find out if a glider has a standard airworthiness certificate or must be registered in the experimental category? Thanks, Uli Uli, go to http://www.faa.gov in the search bar type in (TCDS) From there click on the link on the left side current model/By Make Click on the letter at the top of the manufacturer name. It will give alphabetical order. If it is not listed then it could be under a different type certificate. Check back here if you have a specific manufacturer not listed. Best of Luck, Doug |
At 05:10 16 July 2014, Doug Mueller wrote:
At 03:01 16 July 2014, GM wrote: Can anyone give me some pointers on how to research the FAA database to find out if a glider has a standard airworthiness certificate or must be registered in the experimental category? Thanks, Uli Uli, go to http://www.faa.gov in the search bar type in (TCDS) From there click on the link on the left side current model/By Make Click on the letter at the top of the manufacturer name. It will give alphabetical order. If it is not listed then it could be under a different type certificate. Check back here if you have a specific manufacturer not listed. Best of Luck, Doug Sorry for the repeat info. |
If looking up a glider by N-number, you can simply look at the registration to determine what category airworthiness cert it has. Under the "Airworthiness" section, look for "classification". It will be either "Standard" or "Experimental". This is the easiest way to tell for a particular glider, since some models have ended up in both the standard and experimental categories over the years.
Interesting - I could not find either AB Sportine Aviacija or LAK in the
TCDS database. Is that because my glider is Experimental? Dan Marotta On 7/15/2014 11:10 PM, Doug Mueller wrote: At 03:01 16 July 2014, GM wrote: Can anyone give me some pointers on how to research the FAA database to find out if a glider has a standard airworthiness certificate or must be registered in the experimental category? Thanks, Uli Uli, go to http://www.faa.gov in the search bar type in (TCDS) From there click on the link on the left side current model/By Make Click on the letter at the top of the manufacturer name. It will give alphabetical order. If it is not listed then it could be under a different type certificate. Check back here if you have a specific manufacturer not listed. Best of Luck, Doug |
On Wednesday, July 16, 2014 3:38:56 AM UTC-7, Matt G. wrote:
If looking up a glider by N-number, you can simply look at the registration to determine what category airworthiness cert it has. Under the "Airworthiness" section, look for "classification". It will be either "Standard" or "Experimental". This is the easiest way to tell for a particular glider, since some models have ended up in both the standard and experimental categories over the years... Be cautious about what you learn by doing that; the FAA's records sometimes contain errors about certificate type. For example, I think that there is at least one Russia sailplane for which the certificate type is shown as "Standard" despite the absence of an actual type certificate. Thanks, Bob K. |
On Wednesday, July 16, 2014 7:29:22 AM UTC-7, Dan Marotta wrote:
Interesting - I could not find either AB Sportine Aviacija or LAK in the TCDS database. Is that because my glider is Experimental? I think the cause and effect are the other way around, but, yeah. |
On Wednesday, July 16, 2014 4:38:56 AM UTC-6, Matt G. wrote:
GM;886150 Wrote: Can anyone give me some pointers on how to research the FAA database to find out if a glider has a standard airworthiness certificate or must be registered in the experimental category? Thanks, Uli If looking up a glider by N-number, you can simply look at the registration to determine what category airworthiness cert it has. Under the "Airworthiness" section, look for "classification". It will be either "Standard" or "Experimental". This is the easiest way to tell for a particular glider, since some models have ended up in both the standard and experimental categories over the years. -- Matt G. Not always. I've found the information lacking on more than one record. Of note, one was the SZD-54 Perkoz in the winch accident a couple of years ago. Frank Whiteley |
| Thread Tools | |
| Display Modes | |
| Using XCOM and Flight Line radios in certificated gliders | Paul Remde | Soaring | 11 | August 21st 11 03:34 PM |
| Drones To Be Certificated For GA? | hierophant[_2_] | Piloting | 36 | April 22nd 11 11:14 PM |
| Considering Refinishing Club/Standard Class Gliders for part time job | [email protected] | Soaring | 8 | January 3rd 09 09:21 PM |
| How are avionics technicians certificated? | Jim Stewart | Piloting | 7 | March 18th 07 03:45 AM |
| Motor gliders in Standard and 15-meter class? | wiktor256 | Soaring | 0 | July 23rd 05 09:51 AM |
