Hard to assemble glider
Old July 26th 14, 02:34 PM posted to rec.aviation.soaring
Tim Taylor
Default Hard to assemble glider
Very easy to make a "tool" to prevent the left wing from coming out while inserting the right wing. Just a block of wood cut the correct length and cut with a hole saw on one end to match the spar pin and rounded on the other to match the fuselage. Put the left wing in, insert the spar pin part way so that it does not extend beyond the left spar. Then put the tool in between the pin and the left side of the fuselage. Not needed if the plane is cleaned and lubed properly but can be helpful on very hot days.
Old July 26th 14, 10:25 PM posted to rec.aviation.soaring
John Firth[_4_]
All the comments should identify the glider!
PIK 20E with self rigging gear.
1. Wing alignment is crucial; root gap parallel.
Height of the wing tips must be right.
Make a height gauge to perch on the fuselage to show when the stands are
cranked to the right height
2. Tape the first wing in to hold it; you have to tape it anyway.
JMF
i=
cu=
other=
way
betwe=
cl=
Old July 27th 14, 11:56 AM posted to rec.aviation.soaring
HGXC[_2_]
JMF
i=
cu=
other=
way
betwe=
cl=
Thanks for all of the advice. I flew yesterday and the glider went together with ease- I think the flap setting in S and pinning the air brake was a big factor but I cleaned and lubed the fittings as well.
Dennis
How hard is a Diamant to assemble? Spam Soaring 18 July 5th 15 02:54 PM
U2: Big Glider; hard to land [email protected] Soaring 1 March 16th 09 09:15 AM
Do you assemble your glider paying good attention to it? [email protected] Soaring 6 January 24th 07 10:48 AM
Do you assemble your glider paying good attention to it? Steve Leonard Soaring 0 January 23rd 07 12:53 AM
A&P signoff required to re-assemble 1-26? [email protected] Soaring 5 July 13th 05 05:32 PM
