Is it correct to say that maximum sustained turn rate of an aircraft is
equivalent to steepest bank angle aircraft can sustain in a turn? Emilio |
Possibly.
Energy maneuvering (EM) diagrams that show turn rates usually assume a level flight condition (no altitude gain or loss). The sustained turn rate is defined as a line that starts at the left hand boundary ("stall" line) and goes across the chart to the right until it meets the max airspeed line. This line, known as the "zero Ps" line, goes up and down as a function of speed and "g". The peak of the zero Ps line is the max sustained turn rate and is defined as the intersection of a turn rate and airspeed value. In most cases, this point is below the max attainable turn rate point. All EM diagrams must specify a weight, altitude, power setting, and configuration...therefore there is no such thing as one max sustainable speed. Bank angle enters the picture as a function of available g and the need to maintain level flight. If an aircraft can pull additional g while maintaining level flight, then it is not at its max zero Ps point. The absolute max turn rate for a given weight and altitude would be with the aircraft inverted and pulling max available g...the additional one g of gravity would increase the turn rate as long as the lift vector was oriented below the horizon. "Emilio" wrote in message ... Is it correct to say that maximum sustained turn rate of an aircraft is equivalent to steepest bank angle aircraft can sustain in a turn? Emilio |
configuration... I was trying to relate the diagrams to real situation. As you put it, too much factors come in to play as far as performance is concerned. The bank angle and whether your opponent is sustaining level turn is one thing you can see in ACM. The absolute max turn rate for a given weight and altitude would be with the aircraft inverted and pulling max available g... That is the tactical egg right? If that is the case, Split S maneuver to reverse flight direction beats max turn rate to turn 180 degrees? Emilio. "Andy Bush" wrote in message ... Possibly. Energy maneuvering (EM) diagrams that show turn rates usually assume a level flight condition (no altitude gain or loss). The sustained turn rate is defined as a line that starts at the left hand boundary ("stall" line) and goes across the chart to the right until it meets the max airspeed line. This line, known as the "zero Ps" line, goes up and down as a function of speed and "g". The peak of the zero Ps line is the max sustained turn rate and is defined as the intersection of a turn rate and airspeed value. In most cases, this point is below the max attainable turn rate point. All EM diagrams must specify a weight, altitude, power setting, and configuration...therefore there is no such thing as one max sustainable speed. Bank angle enters the picture as a function of available g and the need to maintain level flight. If an aircraft can pull additional g while maintaining level flight, then it is not at its max zero Ps point. The absolute max turn rate for a given weight and altitude would be with the aircraft inverted and pulling max available g...the additional one g of gravity would increase the turn rate as long as the lift vector was oriented below the horizon. "Emilio" wrote in message ... Is it correct to say that maximum sustained turn rate of an aircraft is equivalent to steepest bank angle aircraft can sustain in a turn? Emilio |
On Mon, 10 May 2004 10:50:50 -0500, "Emilio"
wrote: I was trying to relate the diagrams to real situation. As you put it, too much factors come in to play as far as performance is concerned. The bank angle and whether your opponent is sustaining level turn is one thing you can see in ACM. Frankly, in ACM, you don't really care about sustaining a level turn. What you care about is the ability to maneuver to a weapons employment solution. That being said, we can find simplicity in "Eddie's Three Rules of BFM"---these are for 1-v-1, forward firing, low-aspect ratio kill solutions. In other words, classic gun tracking or boresight IR shots. Rule 1:--maneuver to reduce angles. This means reduce both aspect angle and angle off. Get to a position behind your adversary and align your fuselage with his. (Defensively it reverses--maneuver to increase angles. Move your adversary to high crossing angle and forward on your wingline.) Rule 2:--maintain positive delta energy. This means get a superior total energy situation over your adversary. Total energy is the combination of kinetic and potential (speed and altitude). Never exchange energy for a net loss. Don't dissipate energy without gaining signficantly in position--think "don't cobra!" Rule 3:--unless taking up the slack in the trigger, always maneuver outside of the enemy's plane of motion. This means don't tail chase. If he turn level, you turn vertical. Predict where he is going and employ cut-off. Maneuver in three dimensions relative to his two dimension turn. The absolute max turn rate for a given weight and altitude would be with the aircraft inverted and pulling max available g... That is the tactical egg right? If that is the case, Split S maneuver to reverse flight direction beats max turn rate to turn 180 degrees? Actually the best rate reversal depends upon own speed relative to corner velocity. (Corner is the min speed to pull max allowable G). If above corner, pitch-back--a nose high 45 degree banked reversal. If below corner, slice back--a nose low 135 degree bank reversal. The nose high controls loss of airspeed better while minimizing the loss of G in a pure vertical climbing turn. The nose low maximizes airspeed gain while reducing altitude loss yet still giving a good component of god's G to turn rate. Nobody gives a damn about bank angle. Emilio. "Andy Bush" wrote in message ... Possibly. Energy maneuvering (EM) diagrams that show turn rates usually assume a level flight condition (no altitude gain or loss). The sustained turn rate is defined as a line that starts at the left hand boundary ("stall" line) and goes across the chart to the right until it meets the max airspeed line. This line, known as the "zero Ps" line, goes up and down as a function of speed and "g". The peak of the zero Ps line is the max sustained turn rate and is defined as the intersection of a turn rate and airspeed value. In most cases, this point is below the max attainable turn rate point. All EM diagrams must specify a weight, altitude, power setting, and configuration...therefore there is no such thing as one max sustainable speed. Bank angle enters the picture as a function of available g and the need to maintain level flight. If an aircraft can pull additional g while maintaining level flight, then it is not at its max zero Ps point. The absolute max turn rate for a given weight and altitude would be with the aircraft inverted and pulling max available g...the additional one g of gravity would increase the turn rate as long as the lift vector was oriented below the horizon. "Emilio" wrote in message ... Is it correct to say that maximum sustained turn rate of an aircraft is equivalent to steepest bank angle aircraft can sustain in a turn? Emilio Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
Is it correct to say that maximum sustained turn rate of an aircraft is equivalent to steepest bank angle aircraft can sustain in a turn? Emilio The simple answer is this: yes, the maximum sustained "level" turn rate is equivalent to steepest bank angle aircraft can sustain in a "level" turn under given conditions of airspeed and altitude. Although this may not have tactical significance, this level turn performance has historically been a contract requirement for fighter aircraft. It is also the flight test that defines the zero specific excess power (Ps) condition. Jim Thomas |
A Split S is not going to be the quickest way to reverse direction. Ed has
described the pitchback and sliceback, both of which can be thought of as the most practical way of turning around in the least amount of time, depending on entry airspeed. Your original question can be seen as an academic query...or as a basis for a tactics discussion. As you said, when taking an academic point of view, parameters such as sustained flight conditions, turn rate, specific energy curves, etc, all depend on a set of predetermined conditions. If we switch to tactics, then much of this EM stuff is left in the classroom...because what is "smart" in an engagement may have little to do with academic theories. One of the best examples of this is the corner speed value. Few would ever advise cruising at this speed simply because it represents a high turn rate value. "Emilio" wrote in message ... All EM diagrams must specify a weight, altitude, power setting, and configuration... I was trying to relate the diagrams to real situation. As you put it, too much factors come in to play as far as performance is concerned. The bank angle and whether your opponent is sustaining level turn is one thing you can see in ACM. The absolute max turn rate for a given weight and altitude would be with the aircraft inverted and pulling max available g... That is the tactical egg right? If that is the case, Split S maneuver to reverse flight direction beats max turn rate to turn 180 degrees? Emilio. "Andy Bush" wrote in message ... Possibly. Energy maneuvering (EM) diagrams that show turn rates usually assume a level flight condition (no altitude gain or loss). The sustained turn rate is defined as a line that starts at the left hand boundary ("stall" line) and goes across the chart to the right until it meets the max airspeed line. This line, known as the "zero Ps" line, goes up and down as a function of speed and "g". The peak of the zero Ps line is the max sustained turn rate and is defined as the intersection of a turn rate and airspeed value. In most cases, this point is below the max attainable turn rate point. All EM diagrams must specify a weight, altitude, power setting, and configuration...therefore there is no such thing as one max sustainable speed. Bank angle enters the picture as a function of available g and the need to maintain level flight. If an aircraft can pull additional g while maintaining level flight, then it is not at its max zero Ps point. The absolute max turn rate for a given weight and altitude would be with the aircraft inverted and pulling max available g...the additional one g of gravity would increase the turn rate as long as the lift vector was oriented below the horizon. "Emilio" wrote in message ... Is it correct to say that maximum sustained turn rate of an aircraft is equivalent to steepest bank angle aircraft can sustain in a turn? Emilio |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Boeing 757 turn rate? | Garyurbach | Aerobatics | 6 | June 14th 04 05:43 PM |
| Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 04:27 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 07:46 PM |
