Low energy (full stall) landings: are they safe?
Old July 27th 14, 11:29 PM posted to rec.aviation.soaring
Default Low energy (full stall) landings: are they safe?
On Thursday, July 6, 2000 3:00:00 AM UTC-4, Tom Serkowski wrote:
If one has nearly full spoiler prior to the flare, a 'wheel' landing is almost
impossible and is a perfect setup for a very nice minimum energy landing.
Think about the situation of being in a tail high attitude, well above stall,
main wheel a few inches above the ground. The CG is behind the wheel, so a
sudden down gust pushes the glider down. When the main wheel hits the ground,
the tail is still high and so the AOA increases and next thing you know,
you're at 10 feet with no airspeed. In a 'nose dragger' such as ASK-21,
DG-505, etc, the nose wheel will hit hard, maybe colapse, but will also cause
the nose to bounce up and again you're left wit altitude and no airspeed.
I fly as steep an approach as I can, then use nearly full spoiler at touchdown
and have never had a problem in over 2000 hours and 27 years of soaring in the
southwestern USA.
Most of the landing incidents in both gliders and airplanes that I've seen
have been due to too much energy at touchdown - not too little. I don't count
landing short of the runway as too little energy, that's a poor approach.
Just my $0.02 worth.
ASW-20b
http://www.Serkowski.com
Ajajaj! reading these posts it seems like there is more misconceptions about landings as there is stars in the sky. I learned to fly in Croatia on an L-13. Full flaps and you bleed out airspeed right above the runway until you do not hear the wind noise and at that point you are on the ground. You start your flare with full spoilers and then you smoothly retract them as you keep the glider right above the ground. Once on the ground, you either pop them out again to shorten your rollout or keep them in to go a little farther. How you land depends on the glider type. I miss flaps on L23 and that does not allow me to slow down as much as L13 and rollout is longer. Anyhow, the wing is STALLED if you do it right and there is no returning back in the air at that point. Spoilers out make it impossible to become airborne again after a full stall landing. I landed L23 in some pretty stiff crosswinds and never had control issues.
Jantar Standard is a special case. It was designed to be landed on tailwheel as the angle of incidence of the wing is very low. As long as one does not go crazy on lifting the nose too high and slamming the main wheel down from 4 ft.
Every type has it's own special flavor for landings but if you land wheel or both at the minimum speed possible for that attitude and get the spoilers out, you are staying down. Touch down too fast in anything and you just became a test pilot. Add a sudden gust to the tire bounce and leave your spoilers in and you are in for some interesting times.
Proper training and repetition of things forgotten is the key.
FAA cutting out spins and engine failures in takeoff is a testimony to what is wrong with flight training not what is better. Not training pilots for something that WILL happen to them sooner or later is insane.
Making a 3deg approach on a VFR flight is another insanity I will never get.. You are dragging on the engine power for 3-5 miles and if it quits, you will never make the runway. You could have come high within gliding distance and practice gliding to a landing every time to prepare for that day when the engine does quit. I had five of those and not a scratch on the planes.
Proof is in the pudding.
Old July 28th 14, 05:03 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
wrote, On 7/27/2014 3:29 PM:
landing is almost impossible and is a perfect setup for a very nice
above stall, main wheel a few inches above the ground. The CG is
behind the wheel, so a sudden down gust pushes the glider down.
When the main wheel hits the ground, the tail is still high and so
the AOA increases and next thing you know, you're at 10 feet with
no airspeed. In a 'nose dragger' such as ASK-21, DG-505, etc, the
nose wheel will hit hard, maybe colapse, but will also cause the
airspeed.
at touchdown and have never had a problem in over 2000 hours and 27
years of soaring in the southwestern USA.
I've seen have been due to too much energy at touchdown - not too
little. I don't count landing short of the runway as too little
ASW-20b http://www.Serkowski.com
issues. Jantar Standard is a special case. It was designed to be
and slamming the main wheel down from 4 ft. Every type has it's own
your spoilers in and you are in for some interesting times. Proper
training and repetition of things forgotten is the key. FAA cutting
never get. You are dragging on the engine power for 3-5 miles and if
those and not a scratch on the planes. Proof is in the pudding.
Where do these old posts come from, like Serkowski's? Are they doomed to
roam the Internet until someone responds to them, like a frog prince,
whose spell can only be broken by a kiss from a young maiden?
You'll be interested to know Tom Serkowski is still flying gliders
successfully, 14 years after the post you to which you responded. I
don't know if he has the same opinions about full stall landings, however.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old July 28th 14, 07:51 PM posted to rec.aviation.soaring
John Firth[_4_]
Eric always has something sensible to say! I always read his posts and
agree 99% of the time.
JMF
an old, no longer bold pilot.
airspeed.
however.
email me)
Old July 30th 14, 03:56 AM posted to rec.aviation.soaring
merkaba@ wrote, On 7/27/2014 3:29 PM:
I think it would help if Robert were to quote something he doesn't like. My message pretty much aligns with his thoughts. Several other posts might fit his critique, but I don't think mine did.
Of course, we never see completely irrelevant and inappropriate quoting on RAS. ;-)
don't know if he has the same opinions about full stall landings, however..
Still flying and still doing full stall landings. Now more than 300 flights and over 1300 hours in my ASH-26E and every landing has been full flaps, lots of spoiler and held off as long as possible. I've landed in 20+ knot crosswind and lots more headwind, and very gusty as well - never a problem. I do fly a faster approach as needed, but by the time I complete the round out, I'm at minimum energy.
-Tom
"Glider Pilots Make Safe Landings..." Evan Ludeman[_4_] Soaring 7 July 21st 12 03:08 PM
Approach to a full stall landing Bob Mowry Soaring 6 July 28th 10 12:28 AM
Why must night landings be full-stop? Ron Garret Piloting 25 March 17th 08 12:34 PM
Full Stall Landing? Danny Dot Piloting 27 November 17th 06 08:49 PM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 07:52 PM
