Glider pilot rolls inverted and exits at 1400 feet AGL
Old July 28th 14, 12:14 AM posted to rec.aviation.soaring
son_of_flubber
Default Glider pilot rolls inverted and exits at 1400 feet AGL
http://news.stv.tv/tayside/282807-pi...de-in-mid-air/
Old July 28th 14, 04:22 PM posted to rec.aviation.soaring
son_of_flubber
My first take on the story was that control was lost after the collision and that he just happened to be inverted when he exited. Based on the numbers given he lost 600 feet after the collision.
Do aerobatic-versed pilots plan this inverted exit strategy in advance? It seems rather fast and efficient.
Old July 28th 14, 06:22 PM posted to rec.aviation.soaring
If g forces loaded you up, exiting a deep cockpit would be a challenge. Rolling inverted would not necessarily unload the aircraft and allow you to fall out.
Could be a mad scramble...
Mark
Old July 28th 14, 07:22 PM posted to rec.aviation.soaring
kirk.stant
No. If you have enough control to roll inverted, you can probably land the glider.
After a midair, who knows what the plane will do.
And taking the time to roll upside down (real slooowww in a glider) is a poor choice most of the time, when all you have to do is undo your straps and slam the stick forward - if you get more than 1 negative G that's the same as falling out from an upside down cockpit.
But practically, after a midair your glider will probably either be spinning (loss of most a a wing?) or diving steeply (loss of tail controls) so the trick is to get out any way you can RIGHT NOW and not go for style points.
The "roll upside down and drop out" comes from situations in planes where you still had control but had to get out - like a fire, or out of fuel over unlandable terrain. Common advice in WW2 fighter manuals.
Of course, if you are upside down as a result of a midair, I sure wouldn't try to roll rightside up before getting out!
Kirk
66
Old July 29th 14, 04:55 AM posted to rec.aviation.soaring
Ramy[_2_]
Pushing the stick hard forward (assuming you still have some control) is one of the best advice I heard for exiting the cockpit. Probably something to add to mental bailout practices, as it may not be intuitive during bail out. Thanks Kirk for that advice.
Ramy
Old July 29th 14, 05:11 AM posted to rec.aviation.soaring
Steve Koerner
Ramy
I agree. I've never heard that advise before and it makes darn good sense. I've been doing 40 dips, 3 times a week to make sure that I have a fighting chance to get out of the cockpit. Pushing the stick forward sounds a heck of a lot easier than all those damn dips that I do.
Old July 29th 14, 08:09 AM posted to rec.aviation.soaring
JS
Assuming the tail is still connected!
It's possible to land inverted (too many Gs to bail out) and fly many national records afterwards.
Old July 29th 14, 08:40 AM posted to rec.aviation.soaring
wouldn't your glider pitch up and whack you after you released the stick?
Old July 29th 14, 01:55 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
stick?
Not necessarily. IIRC there was a case in Australia some years back when
a Std Cirrus bunted violently from level flight, throwing the pilot out
through the canopy. He parachuted down while the glider flew, inverted,
in circles round him all the way down and eventually landed some 10-20
metres away.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 29th 14, 02:41 PM posted to rec.aviation.soaring
kirk.stant
Unlikely - it will just return to 1 g or so, not rebound. Bigger problem is hitting the tail - although your relative speed difference will still be pretty low. Good idea to protect your head or wear a helmet (depending on who you thermal with!).
A pointed TE probe might hurt, though!
Like I said earlier - this was a common practice in pre-ejection seat fighters - there is even some good gun-camera footage showing German pilots "popping" out of their cockpits while being shot down by P-51s or P-47s; the only way that could happen is either a good shove on the stick, or (if you have time) by running in full forward trim while holding back the stick then letting go. You see the pilot move away from his plane, not slamming back into the tail. And the negative G only lasts for a second or so, not really long enough to change the plane's flight path.
So a childhood reading all the books I could find about fighter planes turned out to be kinda useful...
Kirk
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
JetPilot and Team Payne win USA OLC with Brilliant Last Minute 1400 km Wave Sortie [email protected] Soaring 1 October 12th 07 05:28 AM
Youth lands glider after dad blacks out at 3,000 feet [email protected] Soaring 0 July 27th 06 12:40 AM
New style emergency exits Michelle Piloting 7 February 7th 06 10:45 PM
5000th glider rolls out the SZD factory Janusz Kesik Soaring 0 November 19th 04 07:29 AM
