Glider pilot rolls inverted and exits at 1400 feet AGL
Old July 29th 14, 08:47 PM posted to rec.aviation.soaring
Dan Marotta
Default Glider pilot rolls inverted and exits at 1400 feet AGL
I guess I wasn't clear in my meaning.
I should have said that, after pulling yourself up by the instrument
panel (I assume your butt is out of the seat), rather than opening your
chute on the center line of the aircraft, it would be preferable to lean
yourself to one side and, hopefully, you'd go under the wing. Even if
you hit the wing or tail, your speed relative to the glider would be
very low and shouldn't cause much more than a bruise. On the other
hand, if you deploy your chute while standing hunched over in the
cockpit, your chances of a miserable ride to the ground while attached
to the tail of the aircraft are significantly increased.
Your life is in your hands at this point and it would do you well
(that's everyone) to know what to do and realize that things most likely
won't happen as you plan. I won't need the time for adrenaline to build
up since I've taken the initiative to get jump training.
Dan Marotta
On 7/29/2014 10:57 AM, John Carlyle wrote:
Dan, the key words were "last resort", ie, desperation time. Also, on the ground I am unable to roll out of the cockpit with a chute on my back from the normal seating position, much less while pulling myself as far forward as I can get. I think I can forget about being able to roll out while airborne under G loads, but maybe adrenaline would work wonders. I hope I never find out...
-John, Q3
On Tuesday, July 29, 2014 11:48:20 AM UTC-4, Dan Marotta wrote:
That maneuver may well have your parachute entangled in the tail of the
aircraft. Everything sounded great until the part about pulling the rip
cord. Better to get in the pulled up position and then roll right or
left out of the aircraft.
Dan Marotta
On 7/29/2014 7:48 AM, John Carlyle wrote:
Kirk has a lot of good ideas! I, too, will keep the "push the stick forward to help get out" maneuver in mind. If that doesn't work, though, seven years ago on RAS Kirk suggested a last resort maneuver:
"You can't get out of the cockpit. Last resort, (canopy gone) is to unstrap, lean forward as far as you can (pull yourself using the instrument panel), then pull the rip-cord. You WILL be extracted from the glider."
I sincerely hope that I never have to use either maneuver!
-John, Q3
Old July 29th 14, 09:16 PM posted to rec.aviation.soaring
Pam Howarth
Amazing; 19 posts and no one has mentioned DG's "NOAH"
system.
Jettison canopy and pull one handle, it automatically
disconnects the straps and "ejects" pilot within a second or so.
See:-
http://www.dg-flugzeugbau.de/index.php?id=noah-e
Old July 29th 14, 10:09 PM posted to rec.aviation.soaring
Andy K
Dan Marotta
-John, Q3
Dan Marotta
-John, Q3
It is really sad that most people do not receive an adequate training how to leave a glider. When I started flying at the age of 16 not only I went through hours of ground training that included leaving a glider being in all possible positions but I also I had to make a real jump. I consider myself very fortunate I received this training at the beginning of my flying experience.
On another note I was also fortunate to receive aerobatic training in a glider which I consider another desired training.
I would suggest aerobatic training to every glider pilot as well as good emergency training.
I bet someone could make good money running a training class like that in the USA.
I hope no one reading this post will ever need this skill, but having the skill greatly increases your chances of survival.
In the past I read accident reports where pilots did not know if they were in a spiral or spin. That is a result of very poor training as well.
Old July 30th 14, 02:10 AM posted to rec.aviation.soaring
son_of_flubber
system.
I wonder how many of those have been sold and whether any have been deployed in flight yet.
Likewise are the ballistic whole plane parachutes that give you more time to bail out.
Old July 31st 14, 03:57 AM posted to rec.aviation.soaring
On Monday, July 28, 2014 11:14:48 AM UTC+12, son_of_flubber wrote:
http://news.stv.tv/tayside/282807-pi...de-in-mid-air/
Can anyone advise the make of the two sailplanes involved.
John
Old July 31st 14, 09:19 AM posted to rec.aviation.soaring
Ramy[_2_]
And where they using Flarm?
Ramy
Old July 31st 14, 11:46 AM posted to rec.aviation.soaring
John Galloway[_1_]
Ramy
No Flarms. There exists a difference of views at the Scottish Gliding
Centre
as to whether Flarm alerts have a net benefit for gliders on our local
ridge
overflying two villages. The worry is that pilots could be alarmed by
alarms
and thus overloaded.
John Galloway
  #28
Old July 31st 14, 01:53 PM posted to rec.aviation.soaring
Peter Higgs
Does anyone know what trajectory a glider takes when the pilot jumps out?
The loss of weight forward of the C/G would upset the trim by a significant
amount.... More so if the glider was inverted.
  #29
Old July 31st 14, 06:33 PM posted to rec.aviation.soaring
Ramy[_2_]
An amazing photo of the bailout just emerged:
http://www.cambridge-news.co.uk/Hunt...0731101407.htm
Ramy
  #30
Old July 31st 14, 06:46 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
http://www.cambridge-news.co.uk/Hunt...t-Neots/Pilot-
pictured-baling-out-after-mid-air-crash-near-St-Neots-20140731101407.htm
That's a different bailout.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
JetPilot and Team Payne win USA OLC with Brilliant Last Minute 1400 km Wave Sortie [email protected] Soaring 1 October 12th 07 05:28 AM
Youth lands glider after dad blacks out at 3,000 feet [email protected] Soaring 0 July 27th 06 12:40 AM
New style emergency exits Michelle Piloting 7 February 7th 06 10:45 PM
5000th glider rolls out the SZD factory Janusz Kesik Soaring 0 November 19th 04 07:29 AM
