Glider pilot rolls inverted and exits at 1400 feet AGL
Old August 5th 14, 11:58 AM posted to rec.aviation.soaring
Dave Nadler
Default Glider pilot rolls inverted and exits at 1400 feet AGL
On Sunday, August 3, 2014 3:49:20 PM UTC-4, Martin Gregorie wrote:
Has anybody bailed out from a Libelle or knows anybody who has?
IIRC Steve Dedman bailed out of a Libelle circa 1992.
I've lost touch with him; JS - do you know if he's
still in Camden (Oz)?
I'm sure a few others must have bailed out of Libelles.
I'm just wondering if the two rear pins act as a
pseudo Roeger Hook and/or if you need to guard against
the canopy clobbering your head as it departs
Sorry, don't know...
Be careful out there (and for heaven's sake use FLARM),
Best Regards, Dave
  #52
Old August 21st 14, 08:25 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
I've lost touch with him; JS - do you know if he's still in Camden (Oz)?
I'm just wondering if the two rear pins act as a pseudo Roeger Hook
and/or if you need to guard against the canopy clobbering your head as
it departs
Of course, though its only an LX RedBox with the default display, which
is all I have panel space for. I've taken care to use the range analysis
tool on the FLARM website to fine-tune my antenna installation. I
regularly use it to check that coverage is adequate.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #53
Old August 25th 14, 06:11 PM posted to rec.aviation.soaring
flgliderpilot[_2_]
My guess, tail section not working, maybe broken fuselage, but ailerons still working. If elevator is stuck, and you are ready to bail, why NOT roll the ship to make it easier to get out?
Us fat guys joke about this all the time (having to get inverted to pry ourselves out)
  #54
Old August 25th 14, 10:30 PM posted to rec.aviation.soaring
Bruce Hoult[_2_]
ourselves out)
If the elevator is stuck then which way up you are is not going to make
any difference to the force keeping you in the cockpit -- only speed is.
Rolling inverted is going to put you into a half loop, with the initial
G force the same as it was the right way up, and then buiding.
If you don't have control of the elevator then you may well overspeed.
Or pull too many Gs. Or both.
It'll be easier to get out of the cockpit once the wings are gone.
  #55
Old August 25th 14, 11:21 PM posted to rec.aviation.soaring
flgliderpilot[_2_]
Not entirely true, he may have had a little elevator, or some elevator with very heavy control resistance, and took planned departure at minimum bailout altitude rather than chance landing and losing elevator entirely below 1000'.
I agree though that damage may have contributed to the roll and that it may not have been not 100% intentional!
  #56
Old August 29th 14, 08:45 PM posted to rec.aviation.soaring
ND
On Tuesday, July 29, 2014 12:11:28 AM UTC-4, Steve Koerner wrote:
On Monday, July 28, 2014 8:55:12 PM UTC-7, Ramy wrote:
Pushing the stick hard forward (assuming you still have some control) is one of the best advice I heard for exiting the cockpit. Probably something to add to mental bailout practices, as it may not be intuitive during bail out. Thanks Kirk for that advice.
Ramy
I agree. I've never heard that advise before and it makes darn good sense. I've been doing 40 dips, 3 times a week to make sure that I have a fighting chance to get out of the cockpit. Pushing the stick forward sounds a heck of a lot easier than all those damn dips that I do.
what about the potential to injured your legs under the panel, or bang your head on the fuselage on the way out? no, i say climbing out is still probably the best way.
  #57
Old August 29th 14, 09:29 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Ramy
Priorities matter in a time-sensitive emergency. I know three people who've
made emergency, personal-'chute-aided bailouts, one from a glider, two from
high-wing power planes.
All recommend unbuckling your seat belt (NOT your 'chute harness [duh!]), then
doing whatever it takes to get the heck out of the plane ASAP. One still has
shin lumps from scraping 'em on the leg hole cutouts of a metal panel 39 years
ago...never a big deal to him, physically or philosophically.
Develop an exit sequence/plan. Should it be necessary, don't hesitate to
attempt to implement it. Be prepared to ad-lib on your plan if necessary, but
the first priority should be to get the heck out of the aircraft, in a
physical condition capable of pulling the D-ring. Potential
non-life-threatening secondary injuries traded against a longer exit time? Not
so wise, but in your emergency, YOU'RE the judge. Mother Earth is the jury, and...
Bob W.
  #58
Old August 30th 14, 12:23 AM posted to rec.aviation.soaring
kirk.stant
The point is that under G, YOU CAN'T CLIMB OUT! Sure, you might get hurt. The option is getting dead, which (last time I checked) doesn't heal very good.
If you can casually climb out of the cockpit, sure, go ahead and enjoy the experience.
Kirk
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
JetPilot and Team Payne win USA OLC with Brilliant Last Minute 1400 km Wave Sortie [email protected] Soaring 1 October 12th 07 05:28 AM
Youth lands glider after dad blacks out at 3,000 feet [email protected] Soaring 0 July 27th 06 12:40 AM
New style emergency exits Michelle Piloting 7 February 7th 06 10:45 PM
5000th glider rolls out the SZD factory Janusz Kesik Soaring 0 November 19th 04 07:29 AM
