Sat and Radar imagery video loop - Last day of Nephi Region 9N
Old August 11th 14, 06:24 AM posted to rec.aviation.soaring
WaltWX[_2_]
Default Sat and Radar imagery video loop - Last day of Nephi Region 9N
Decided to cross post this for discussion...
Walt Rogers WX
Here's the Sat imagery, Radar for the last day at Nephi. The plus plots are the TP database. The label for the plot points is mangled due to a bug in the program.
Here are two radar loops from MTX (Salt Lake City radar): One is reflectivity at 0.5 deg (lowest) elevation angle; the other is for echo tops in thousands feet. The GOES 1km Vis photo follows that. Note that there was an outage of sat imagery between 130pm and 3pm MDT (1930z-2100z):
https://www.dropbox.com/s/pyze3df7tc...1_20140809.mp4
https://www.dropbox.com/s/lc7wtxh3lh...s_20140809.mp4
https://www.dropbox.com/s/zou6a4j9n9...s_20140809.mp4
One suggestion on how to get the most timely radar graphics. Install an app called "RadarScope" or "Radar Pro". It's the best app out there for NEXRAD radar imagery of professional quality (free and paid for version - Iphone, Ipad, Android). I recommend the paid for version ($4.99) because it has lightning data plots. Lightning data in the U.S. is proprietary and must be accessed with a subscription (even the NWS pays for it). The Pro version also has the latest 20 frames instead of 5 (they come in every 3-10 minutes). There is no PC version... just IOS and Android. The free version is minus lightning data and shows only last 5 frames.
I've used this on the ramp just before launch to help make a decision on which way storms are moving or developing. It's also good for deciding on whether or not to disassemble. Works great on a small screen PDA phone.
Walt Rogers WX
Old August 11th 14, 04:29 PM posted to rec.aviation.soaring
jfitch
Walt Rogers WX
One suggestion on how to get the most timely radar graphics. Install an app called "RadarScope" or "Radar Pro". It's the best app out there for NEXRAD radar imagery of professional quality (free and paid for version - Iphone, Ipad, Android). I recommend the paid for version ($4.99) because it has lightning data plots. Lightning data in the U.S. is proprietary and must be accessed with a subscription (even the NWS pays for it). The Pro version also has the latest 20 frames instead of 5 (they come in every 3-10 minutes).. There is no PC version... just IOS and Android. The free version is minus lightning data and shows only last 5 frames.
Walt Rogers WX
Names again? On iTunes, RadarScope is $9.99 and requires a subscription for lightning, Radar Pro is $4.99 and doesn't mention lightning, they are by different authors.
Old August 11th 14, 05:02 PM posted to rec.aviation.soaring
Walt Rogers WX
Walt Rogers WX
I've been using RadarNow! for a while now. It's free, but it only shows
base reflectivity. RadarScope does look nice, although it's a little pricy
as apps go.
Old August 12th 14, 02:39 AM posted to rec.aviation.soaring
WaltWX[_2_]
Darn.. the Iphone App store on my IOS devices showed no price for the app, since I already had it installed. The download was FREE when I got it; now it's $9.99 (a roll of white tape). Even though they don't mosaic radar data together and you have to choose one radar at a time, the data is Level II, which means highest resolution available.
The $9.99 / year subscription is extra. Lightning data plots in real-time are not available anywhere for free.
Sure, there are other apps out there for free, but none of professional quality with the high resolution data.
Walt Rogers WX
Old August 12th 14, 02:47 AM posted to rec.aviation.soaring
WaltWX[_2_]
CORRECTION
The previous Echo Tops radar loop link is for the wrong day. This is the correct one for Nephi Sat 08/09/2014:
https://www.dropbox.com/s/ti71880mxx...X_20140809.mp4
New Video From Nephi and Update on 2014 Nephi Events [email protected] Soaring 1 June 5th 14 03:27 AM
2014 Region 5N video Sean Franke Soaring 4 April 28th 14 01:23 PM
Region 2 North Contest VIDEO Warren Soaring 0 August 26th 13 10:12 PM
Wurtsboro Region 2 VIDEO Warren Cramer Soaring 5 July 19th 11 05:54 AM
HD video from Logan Region 9 Contest Bruno Soaring 2 August 25th 09 04:03 AM
