Mounting camera on wing of glider
Old August 26th 14, 10:59 PM posted to rec.aviation.soaring
Default Mounting camera on wing of glider
You can mount a camera by using a very thin piece of ally, or steel, from a buiscit tin. First you need to build an aerodynamic cradle using wood. One that streamlines the camera from the slipstream, while holding it rigid. Mount the camera to the cradle, by drilling a dole through your sheet metal, then knocking the countersunk head of the screw to recess it. Typically 1/4 UNC. then simply tape the sheet metal to the wing using 2" tape (white) orientating the streamlined end of the mount with the direction of the glider. You can either use a remote control to take stills, or leave the movie mode on!! Alternatively a wooden cradle can be made to mount it to the fin of the glider.
Old August 27th 14, 12:50 AM posted to rec.aviation.soaring
Mike the Strike
Cameras have also got much smaller and lighter since the OP's post of 2001!
Mike
Old August 27th 14, 02:05 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
2001!
Yep.
My one attempt (so far) at using an external camera involved a keyfob cam
and wing tape. It worked: the camera was steady enough to give a stable,
unblurred picture and was still there after the flight.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Use of 'Back up' camera with glider trailer son_of_flubber Soaring 7 January 7th 13 01:44 PM
PowerFlarm mounting question, and an idea for mounting devices brianDG303[_2_] Soaring 2 October 23rd 11 06:51 PM
Very Nice Camera for Glider...Stills or HD Video [email protected] Soaring 17 June 16th 09 10:28 PM
Video Camera/ Recorder to Visually Record Glider Flights From PilotsViewpoint [email protected] Soaring 5 November 17th 07 06:11 PM
What camera for pictures from a glider cockpit? Eric Greenwell Soaring 34 December 10th 05 06:19 AM
