CAI-302 Utility Program
Old September 5th 14, 01:12 PM posted to rec.aviation.soaring
Paul Remde
Default CAI-302 Utility Program
Hi,
The ConnectMe program works great for uploading task declarations to the 302
and downloading secure flight logs from the 302. However, it can't be used
to edit 302 settings or to load the pilot name. The 302 utility must be
used for those items. Fortunately, those settings only need to be setup
once. You can download versions for PC and PDA (not Oudie) he
http://www.cumulus-soaring.com/cai_downloads.htm
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_______________________________
"Muttley" wrote in message
On Thursday, September 4, 2014 9:23:39 PM UTC+1, wrote:
Nick,
Per your suggestion, I just sent a request to learn how to put the CAI
Utility file (PC or IPAQ) onto the Oudie, if possible.
Raul Boerner
DM
Can you not use the ConnectMe utility already installed on the Oudie, it is
supposedly compatible with the Cambridge 302??
Mottley
Old September 5th 14, 02:00 PM posted to rec.aviation.soaring
I am another person who would really like the Oudie to talk to the 302 so that settings like Ballast, Bugs, Polar (two different wings for my aircraft) could be set via the Oudie.
Is the problem that the Oudie people just don't want to install the software or is there a basic computer language problem with the systems?
Old September 5th 14, 03:58 PM posted to rec.aviation.soaring
Dan Marotta
I use a Dell Streak 5 running XCSoar which communicates with my 302 via
Bluetooth (K6BT that I got from Cumulus). It allows me to set MC, bugs,
ballast, polar, pilot name, etc., and receives GPS data, wind, speed,
etc. from the 302. I know at least one person who runs XCSoar on his
Oudie so perhaps that would be a way to achieve your goal. XCSoar is
FREE, so all you have to do is download and install it and you're ready
to give it a try. You can also download a PC version of the program to
learn and practice with.
I started this thread a while back because I'd lost my copy of the 302
utility. I got it from Paul's site and, one of these days, I'll carry
my laptop to the airport and see if I have my name in the 302. I
probably did it with the Ipaq when I bought the glider.
BTW, when I've flown other gliders, it's been simple to select another
polar from the list provided by the XCSoar executable.
Dan Marotta
Old September 5th 14, 10:37 PM posted to rec.aviation.soaring
[email protected][_2_]
I found this 23 February,2011 post by Andrej. However, there were other responses indicating freeze problems using these solutions.
Cambridge 302 Compatibility?
There are two ways to use the CAI utility on Oudie:
1. Save it to the root of the microSD card and rename it to UpdateOudie.exe. Before you use Oudie for inflight navigation you will have to remove the card otherwise it will keep running the utility.
2. Overwrite the ConnectMe.exe in 2577 folder with the utility file. That will remove ConnectMe from your Oudie and the ConnectMe button will start the utility. You can get the ConnectMe back by reinstalling the firmware.
Old September 6th 14, 03:21 PM posted to rec.aviation.soaring
Nick Kennedy
Lou
with all due respect, bringing my laptop to the airport, purchasing a converter cable, disconnecting my Oudie cable from my 302, connected this new cable, disconnecting the new cable and them rehooking up my Oudie cable does not sound simple to me. This is my point of my first post. We Should be able to bypass all of the above.
Simple to me is to have Naviter put the CAI Utility on the Oudie and then open the program with the touch of your finger and do your thing.
All you 302 + Oudie fans please shoot a email to Naviter and ask them to give use the option of loading the CAI Utility during the next update, I would hazard a guess it would be quite simple for them to do so and would be another great benefit of owning a Oudie.
Old September 8th 14, 12:39 AM posted to rec.aviation.soaring
Paul Remde
Hi Nick,
Unfortunately, the problem is not a Naviter problem - it is a Cambridge
problem. The Cambridge 300 Utility can be copied to an Oudie, but it
doesn't seem to run well on an Oudie. It must be compiled for a processor
which is not compatible with the Oudie. Naviter doesn't have the original
Cambridge 300 Utility code - so they can't fix the problem. Cambridge is no
longer around, so they can't fix it either. ClearNav probably doesn't have
the code. Even if they did - they wouldn't be motivated to work on it.
Theoretically, Naviter could create screens in SeeYou Mobile which would
make it possible to edit the pilot name and polar data and logging interval
in the 302 (as is done with the LX1600). However, I doubt they would be
motivated to do that since 302 units are not as popular in Europe and are
being replaced with newer products (like the LXNAV V7) quite rapidly which
work great with SeeYou Mobile. If you are doing to lobby Naviter - lobby
that they add 302 support (pilot name, polar and logging interval settings)
to SeeYou Mobile. But I wouldn't expect much. Naviter would rather work on
new features which would apply to a larger population of SeeYou Mobile
users.
Best Regards,
Paul Remde
"Nick Kennedy" wrote in message
Lou
Old September 8th 14, 03:37 AM posted to rec.aviation.soaring
GC[_2_]
On 7/09/2014 00:21, Nick Kennedy wrote:
Lou with all due respect, bringing my laptop to the airport,
above. Simple to me is to have Naviter put the CAI Utility on the
your thing.
I love self-absorption. It's such a pleasure to watch.
Let me see: using a laptop on the field which you probably already had
in your car to use in the clubhouse and hooking and unhooking a cable is
much more difficult and stressful than re-writing parts of a large
application - including its tricky communication protocols, testing the
re-writes, re-writing to fix the faults, re-testing, etc and then
promulgating the result to hundreds of owners around the world - of whom
ONLY 10 GIVE A DAMN!
....and ALL of that 10 already own the program and wouldn't pay a penny
for the revision!
Now I'm as prospective an Oudie owner as any of the thousands of r.a.s.
readers who also don't own one. Will easier 302 compatibility make me
rush out and buy one? No. Will any price rise due to increased software
maintenance overheads make the Oudie a more attractive purchase to me
and thousands of other non-owners? No also.
GC
Old September 8th 14, 11:24 AM posted to rec.aviation.soaring
Muttley
Plenty of old Ipaq's around where the CAI Utility works well on a cable connection. No need for Laptops.
Muttley
Old September 8th 14, 12:41 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
It should be trivial for anybody with a soldering iron to make up a T-
cable (possibly with a switch in it) by combining the new cable and an
Oudie-compatible cable.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 8th 14, 01:33 PM posted to rec.aviation.soaring
Nick Kennedy
Hi Paul
Thank you for response and the clear explanation why the CAI Utility is not compatible with the Oudie.
I know very little about software code and operating systems. The CAI utility, to me anyway, seemed to be a very simple program and I thought it would be easy to just Copy and Paste it into a Oudie. Obviously this is not the case.
Cheers
Nick Kennedy
Cambridge 302 Utility app [email protected] Soaring 1 June 7th 12 03:59 PM
Cambridge Utility Program Question Scott Alexander[_2_] Soaring 4 February 9th 10 07:34 PM
Utility program for PDA Oscar Goudriaan Soaring 4 April 10th 08 07:11 PM
CAI 302 Utility program confusion Frank[_1_] Soaring 1 March 30th 07 03:57 AM
CAI 302 Utility Program questions Andy Smielkiewicz Soaring 2 March 16th 05 01:32 PM
