Cobra Trailer front access door ....
Old September 6th 14, 08:49 PM posted to rec.aviation.soaring
Ron Gleason
Default Cobra Trailer front access door ....
I have a metal top Cobra trailer. The front access door latches just fine but there is a lot of play with the door and I can see wear marks on the side. Also I know of two pilots that have had the doors open and rip off while moving.
Has anyone added a 'safety latch' to the access door?
I am thinking about a hasp latch like this one http://www.stanleyhardware.com/detai...-hasp-s511-250
Or a barrel bolt type like this http://www.grainger.com/product/BATTALION-Heavy-Duty-Barrel-Slide-Bolt-WP157663/_/N-mf6?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/4PB93_AS01?$smthumb$
I know that locking the latch will help but I do not know where the key is and I am looking for a more durable solution.
Thanks in advance
Ron Gleason
Old September 6th 14, 09:48 PM posted to rec.aviation.soaring
give Cobra the serial number of your trailer, they'll provide you a set of new keys. Tested, it works ;-)
Aldo Cernezzi
Old September 6th 14, 10:07 PM posted to rec.aviation.soaring
Mark628CA
Ron-
I have installed a safety latch on my trailer, as well as some others. It is a good idea, as the latch can pop open, generally ruining the door and often breaking the gas struts and/or their attachment points. I used a simple hasp type, and just secure it with a hitch pin, but you could substitute a padlock.
BTW, there are only a few keys for all Cobra trailers. Williams Soaring generally has the one you need in stock.
Old September 6th 14, 11:26 PM posted to rec.aviation.soaring
Burt Compton - Marfa Gliders, west Texas
Key Code.
On the inside of the Cobra trailer on the upper right side where the right strut attaches to the clamshell is a triangle piece of aluminum that has 2 numbers (usually.)
The number on the left indicates the strength/force of the clamshell struts.
The number on the right indicates the code for the key to the trailer.
Old September 9th 14, 04:25 PM posted to rec.aviation.soaring
MQ
If it is a metal top from before 1990 no dice on keys from Cobra...they are right for later trailers though. From what you describe I do not think that keys would help anyway. Install a hasp as you mentioned and Mark suggests.
Old September 9th 14, 09:03 PM posted to rec.aviation.soaring
JS
Locking the front door for long trips is a good idea.
I've epoxy'd a piece of wood (paint stirring stick) in a couple of trailers as a speed bump for the latch to go over before it will unlock.
Give that a try?
Old September 9th 14, 09:55 PM posted to rec.aviation.soaring
Give that a try?
I have problems more with the back door on long trips ('80s fiberglass top).
I've taken to running a strap between the latches for the top to keep the
door closed. The lock will work itself out even with the strap over it!
Matt
Cobra Trailer-Replacing front panel K Soaring 2 January 15th 14 03:25 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 03:42 PM
Cobra Trailer leak, front end gasket, fix? SF Soaring 1 December 20th 10 08:30 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 03:11 AM
[1/1] - 01 Starboard Forward access door.JPG (1/1) Part 2 - Main event Spruce Goose. Waldo.Pepper[_2_] Aviation Photos 0 September 11th 08 12:22 AM
