#11
![]() A Lieberman wrote: ATC came back and said, 43 Lima, cleared to Covington LA as filed, climb to 5000, squawk 1234. I think, by me saying "ready to receive clearance", triggered the response. No, he came right back with your clearance because he knew exactly where you were. It had nothing to do with your being ready to copy a clearance. Nobody gets an IFR clearance unless the controller knows where you are. |
On Mon, 07 Feb 2005 06:08:37 -0800, wrote:
I could argue that "cleared to" is by itself insufficent. Even more significant is to hear "maintain XXXXX altitude." Shouldn't there also be a "route" included? (i.e. Cleared to xxx, via as filed, maintain 6000) Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Lot's of good answers given. Welcome to the learning portion of your
lifelong IFR classroom. I would add that if you ever find yourself changing altitude without ATC prompting or as the result of a specfic clearance (plan means nothing), something is wrong. Hey, don't stop filing on those VFR days - it really helps learn the system without IMC distractions. Wizard of Draws wrote: I took a short XC today after a layoff of a few months due to real life constraints and weather. I filed IFR even though it was VFR because I wanted to get back into the groove of communicating with ATC. I filed for 5000 going east. On the ground, they told me it would be faster if I took off VFR and opened my plan in the air, so I did. I was at 5500 when I finally got through since I was VFR, but all I was given initially was a squawk code with no altitude assignment or clearance. I assumed that I was IFR at this point so I began to descend to 5000 per my flight plan. As I did I asked ATC if he had an altitude assignment, and he came back with 6000, cleared direct. No problem, I pull back up and fly as I'm told. So, was I IFR as soon as I was given a squawk and required to fly my flight plan, or should I have waited to change from a VFR altitude to an IFR altitude until I was given specific instructions? |
On 2/6/05 8:58 PM, in article , "Stan
Prevost" wrote: Hi, Jeff - You are not under IFR until you have received an IFR clearance including the words "cleared to". If you departed VFR (without an IFR clearance and release), you are not IFR and must obey VF Rules. Once airborne, you contact ATC with something like "ABC Approach (or center), N1234 off Podunk Field, IFR to Niceville, request clearance." They will assign you a squawk code, wait to identify you on radar, then give you your clearance and instructions (inlcuding altitude). Until then, you maintain VFR, including altitude. But see http://www.avweb.com/news/columns/189034-1.html . Stan Thanks Stan. I learn something from every flight nowadays. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
On 2/6/05 9:46 PM, in article ,
"Roy Smith" wrote: Wizard of Draws wrote: I took a short XC today after a layoff of a few months due to real life constraints and weather. I filed IFR even though it was VFR because I wanted to get back into the groove of communicating with ATC. I filed for 5000 going east. On the ground, they told me it would be faster if I took off VFR and opened my plan in the air, so I did. I was at 5500 when I finally got through since I was VFR, but all I was given initially was a squawk code with no altitude assignment or clearance. I assumed that I was IFR at this point so I began to descend to 5000 per my flight plan. As I did I asked ATC if he had an altitude assignment, and he came back with 6000, cleared direct. No problem, I pull back up and fly as I'm told. So, was I IFR as soon as I was given a squawk and required to fly my flight plan, or should I have waited to change from a VFR altitude to an IFR altitude until I was given specific instructions? You're IFR when you hear the magic words "cleared to". When the controller first gave you squawk code, you were still VFR. He wanted to get you in radar contact before issuing your clearance (so he didn't have to apply non-radar separation rules). I assume when you wrote, "6000, cleared direct", it really sounded more like, "Cleared to the XYZ airport, via direct, maintain 6000". Clearance limit, Route, Altitude, always in that order (followed by Frequency and Transponder code, giving the popular CRAFT acronym). What confuses me is, "given a squawk and required to fly my flight plan". In what way were you required to fly your flight plan? Until you are IFR, the controller can't really require you to do much of anything (assuming class E airspace). Thanks for answering. Craft is not exactly correct since I got the transponder code first. It was a monkey wrench that I didn't really expect since I normally get clearance on the ground in CRAFT order. It's been quite a while since I opened a plan in the air and 3 months since I've flown at all. A lot of rust to work off. I suppose I should have used the word 'expected' instead of required. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
On 2/6/05 10:04 PM, in article , "A
Lieberman" wrote: I would suspect, until you hear "CRAFT" from ATC, you are still under VFR rules. Allen Yep, thanks. There wasn't much chance of actual anyway. Everything was at 12K. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
On 2/6/05 11:35 PM, in article
, "Peter R." wrote: Wizard of Draws wrote: On the ground, they told me it would be faster if I took off VFR and opened my plan in the air, so I did. Hey, Jeff, since you received a lot of answers to your direct question, I thought I'd take a different slant with your post. In response to the above quote, consider this article: http://www.avweb.com/news/columns/189034-1.html This article, coupled with a "learning" experience I had last summer have taught me to really ensure there are comfortable VFR conditions for many miles surrounding the airport before I launch VFR expecting to pick up an IFR clearance in the air. Just something to consider for future flights. Yessir, learned that one back in November during a couple of flights with actual. Ceilings can vary quite a bit from reported as I found out, so I won't be launching without a VFR safety net. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
On 2/7/05 2:47 PM, in article
, "Maule Driver" wrote: Lot's of good answers given. Welcome to the learning portion of your lifelong IFR classroom. I would add that if you ever find yourself changing altitude without ATC prompting or as the result of a specfic clearance (plan means nothing), something is wrong. Hey, don't stop filing on those VFR days - it really helps learn the system without IMC distractions. Filing IFR is too much fun not to do it as often as I can. And anytime I can have a second set of eyeballs working for me... -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
Craft is not exactly correct since I got the transponder code first. It sounds like things happened in two chunks. Within a single call, the elements will (or at least should be) in CRAFT order, but you had it broken up into two parts. First, he gave you a transponder code. You entered that, he found you on radar, and he declared "radar contact". Now he can apply IFR radar separation rules, which greatly reduces the amount of airspace he needs to dedicate to you. Next, he gave you your clearance. You already had a code and a frequency, so he just gave you the new stuff, in CRAFT order, i.e. just the CRA part. |
How to use Lycoming remote filter | Evan Carew | Home Built | 0 | September 30th 04 11:43 PM |
