Pilots vs mechanics...enjoy
Old November 27th 14, 06:55 PM posted to rec.aviation.soaring
Default Pilots vs mechanics...enjoy
Remember it takes a college degree to fly a plane, but only a high school diploma to fix one:
After every flight, UPS pilots fill out a form, called a gripe sheet, which tells mechanics about
problems with the aircraft.
The mechanics correct the problems, document their repairs on the form, and then pilots
review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance
complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with
an S) by maintenance engineers.
By the way, UPS is the only major airline that has never, ever, had an accident....
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit
S: Something tightened in cockpit
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: IFF inoperative in OFF mode.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And the best one for last
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from the midget.
Be realistic. Expect a Miracle.
Old November 28th 14, 12:51 AM posted to rec.aviation.soaring
S: Cat installed.
Without aircraft maintenance, pilots would just be pedestrians with a big watch, cool sunglasses and a leather jacket
Old November 28th 14, 12:54 AM posted to rec.aviation.soaring
Dan Marotta
Since when did UPS install targeting radar? Do they intercept and shoot
down FedEx planes?
BTW, this used to be attributed to USAF squawk sheets...
S: Cat installed.
Dan Marotta
Old November 28th 14, 06:08 AM posted to rec.aviation.soaring
Darryl Ramm
Well that's a load of porky pies isn't it.
Old November 28th 14, 06:14 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
All very witty and amusing, but I've seen them all before over several
decades, attributed to other sources. UPS mechanics didn't invent them
down FedEx planes?
form,
and then pilots
are
solutions
an
accident....
descent
S: Cat installed.
Dan Marotta
Old November 28th 14, 02:54 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
an
accident....
In the further interest(s) of accuracy: UPS Flight 1354, Aug 2013...
I'll be leaving now, my anal work here is done.
Bob W.
Old November 30th 14, 12:25 PM posted to rec.aviation.soaring
J. Nieuwenhuize
How to tell a pilot from a mechanic:
http://www.youtube.com/watch?v=T-Y8exElqeo
Another way to enjoy wave kd6veb Soaring 3 January 2nd 09 10:48 PM
If you enjoy UseNet you might read this... Ronnie Baker Aviation Photos 5 June 28th 08 09:40 PM
A story most pilots will understand, and enjoy [email protected] Piloting 8 June 30th 07 07:56 PM
A few thoughts I think most will enjoy. Chris W Piloting 2 December 4th 06 06:04 PM
Enjoy your achievements as well as your plans. Martin Piloting 1 February 10th 04 12:35 AM
