Wind Turbine Blades
Old December 4th 14, 08:39 PM posted to rec.aviation.soaring
Default Wind Turbine Blades
On another forum I visit these was some discussion regarding the design of wind turbines - the number and size of blades, various configurations etc. A question I had that no one answered had to do with what I can only call a "dip" in the blade out near the tip. I looked for a good image but couldn't find any that show it well. I don't know if all/most blades are designed like this but the ones where I live are and it is obvious if you are close enough. Tip vortex reduction?
Old December 4th 14, 10:54 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Not quite sure what you are trying to describe, but here are my observations.
In planform, all seem to have an eliptical shape at the tip.
In airfoil sections used, most seem to have a concave section on the top (side away from the mast) that is visible under proper light conditions (front 2/3 or so of the blade lit up by sunshine, a portion that is dark, then the last 10-15% of the chord is back in sunshine).
Many of the large diameter turbines now have, for lack of a better term, a "dihedral break" in them out near the tip. Near as I can tell, this is primarily for providing blade to mast clearance, as the blade flexes back towards the mast and the designers had a choice between adding mass (to get stiffness), putting a "kink" in the blades, to bend it out away from the mast, or making a new top end with an even longer overhang. Two of those three options add cost and weight and reduce efficiency. The third gets the clearance needed and actually increases the swept area over a blade set that does not have this "dihedral" break in the blade. This "break" is in the range of 15 to 20% of the balde length in from the tip of the blade.
Some of the earlier wind farms in Kansas had roughly 75 foot long blades, and these did not have this feature. The newer ones going in have nearly 100 foot long blades, and they do have this feature. It may look like a "dip", as inboard of this, the blade is bent back towards the mast, and outboard of this, the blade is much more nearly parallel to the mast.
Old December 5th 14, 07:02 AM posted to rec.aviation.soaring
GM
Hi Steve,
your explanations are pretty much spot on. The blades are being built with a natural dihedral so they straighten out under load. There are typically around 12-13 airfoils in a wind turbine blade - at least in ours. To further increase the blade tip to tower clearance (we don't call it 'Mast'), the entire drive-train is tilted back by a few degrees.
Not sure which wind project in KS you are referring to but our current generation blades are 47.8m long which makes for a 100m rotor diameter. 120m and 130m rotors on 140m tall towers are already being used in Europe. Our aerodynamisists tell me that these blades have an L/D of around 100:1.
Uli
Old December 5th 14, 08:10 PM posted to rec.aviation.soaring
Thanks Steve/GM. That's exactly what I'm talking about. Mystery solved!
Old December 6th 14, 12:24 AM posted to rec.aviation.soaring
Craig Funston
Hi Steve,
Uli
So Uli,
The windpower aero group must be as interested in localized AOA changes and drag effects due to gusting as we are. Has there been any crossover between the fields. I expect at full power they're at higher reynolds numbers that we are. They certainly have more funding at their disposal than the soaring community.
Cheers,
Craig
Old December 6th 14, 05:49 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Friday, December 5, 2014 12:02:17 AM UTC-6, GM wrote:
Hi Steve,
Uli
Mast, tower. To me, towers are those trusses with wires and antennas on them. :-)
Yes, I had noticed the tilt of the box on top to point the axis of rotation up as it goes upwind from the tower. Figured this was also to get blade clearance.
The first one was out near Montezuma. This field has apparently reached obsolescence, as it doesn't seem to be operating any longer. But, all the turbines are still up. Newer ones by Spearville, Harper, etc. Didn't realize they were that big. I know they are really big when you see them being pulled down the highway!
Steve
Old December 6th 14, 08:13 PM posted to rec.aviation.soaring
bumper[_4_]
Uli
Wow! That pretty much says it all, the hell with honesty, I'm stealing a couple of them blades, assuming I can find both and right hand ones, and building me a new 100 meter 100:1 L/D glider!
Does anyone have a 50 meter trailer for sale? Oh, and really heavy duty one-man rigger?
bumper
Old December 6th 14, 08:44 PM posted to rec.aviation.soaring
John Firth[_4_]
Modern laminar airfoils normally have an L/D 100/1,
without the effect of limited span. It is the need
the house the pilot and provide stability which knocks
it down below 70.
JMF
ge=
120m
a=
Uli
co=
buil=
ding me a new 100 meter 100:1 L/D glider!=20
one=
-man rigger?
bumper
Old December 7th 14, 07:27 AM posted to rec.aviation.soaring
GM
Sorry, Bumper but them blades only come in a LH version. Your trailer and one man rigger would have to be quite hefty as each of them weighs in at around 10,000kg. :-)
GM
Old December 7th 14, 08:51 PM posted to rec.aviation.soaring
John Firth[_4_]
GM
Bumper should check with the Ozzies' maybe they make
RH blades for the S hemisphere.
JMF
Jacks Mountain Wind Turbine Letters Needed. Karl Striedieck[_2_] Soaring 11 January 24th 14 07:20 PM
Is a bird substantial enough to break turbine blades? Ricky Piloting 10 January 11th 08 06:21 PM
GSC prop as wind turbine??? clare at snyder.on.ca Home Built 11 March 18th 06 01:07 PM
Turbine Duke or turbine Baron? Montblack Piloting 1 December 13th 05 05:54 PM
Turbine Duke or turbine Baron? [email protected] Piloting 26 December 13th 05 08:50 AM
