Update on CAI flight recorder repairs from CNi (GPS Date problems)
Old December 11th 14, 08:48 PM posted to rec.aviation.soaring
Tango Eight
Default Update on CAI flight recorder repairs from CNi (GPS Date problems)
We've had to change tactics slightly to deal with the Cambridge flight recorder GPS date problems recently discussed here on r.a.s.
Here's the latest:
Cambridge 302 needs a new GPS card to fix this the right way. Simply soldering in a new battery won't get your 302 through Winter storage (which is where *my* 302 vario is right now). Few people will want to remove a vario for the Winter to maintain the GPS date.
This problem will be repaired under our existing CAI 302 flat rate policy: we fix (almost) any 302 and provide a 1 year warranty and fresh barograph calibration for $350.
Cambridge model 10/20/25 flight recorders were always intended to be mounted in an easily removable fashion, so we feel that the battery only fix is better economy for these older units. CNi will replace the GPS date battery, fix your date problem and calibrate the barograph for $125. It will be up to you to maintain the battery by powering up the flight logger for a few hours every 3 months or you will lose the date... there will be a warning/reminder label on your returned unit to this effect.
Gary Kammerer handles all of our CAI service, please find contact info for Gary on our website.
Best regards and Good Soaring in 2015,
Evan Ludeman for ClearNav Instruments
www.ClearNav.net
please join our forum for discussion of all things ClearNav
http://clearnav.net/simplemachinesforum/index.php
Old December 12th 14, 10:19 AM posted to rec.aviation.soaring
Ian Reekie
reco=
Here's the latest:
solde=
w=
vario
policy:
c=
mounte=
b=
battery=
u=
few=
warning/=
for
www.ClearNav.net
With regards to the older Cambridge loggers ie model 25.
Is it feasible to mod the logger such that the GPS internal real time clock
is powered off the same user replaceable 3v higher capacity lithium battery
that provides the loggers seal ?
I was stupidly thinking of a wire and a low V drop diode ? (Would this mod
mess up the GPS by injecting interference/noise into the screened receiver
Old December 12th 14, 01:27 PM posted to rec.aviation.soaring
David Kinsell[_2_]
Default Update on CAI flight recorder repairs from CNi (GPS Dateproblems)
reco=
Here's the latest:
solde=
is w=
vario
policy:
barograph c=
mounte=
is b=
battery=
be u=
few=
warning/=
for
Evan Ludeman for ClearNav Instruments www.ClearNav.net please join our
clock is powered off the same user replaceable 3v higher capacity
lithium battery that provides the loggers seal ?
mod mess up the GPS by injecting interference/noise into the screened
receiver ?)
There already is an aux power input for that battery at the interface,
4-35 volts, so obviously goes to a regulator. A better technical
solution would be for the firmware to use a few bits of the non-volatile
memory on board to prevent the time from going backwards, but that's not
going to happen.
Given that the old GPS-NAV models never have produced valid IGC files, I
would expect the cost of trying to do hardware modifications would exceed
any reasonable valuation of what they're currently worth. The brain
damage of trying to get OLC to accept the files has to be figured in
there somewhere.
Similarly, the 302 has had chronic data corruption issues in the flash
that were never fixed, so dropping $350+ today to swap out engines is
really hard to justify. But there's credible information that the black-
case models of those already have the newer engine, and may well be good
for a number of additional years.
-Dave
Old December 13th 14, 08:59 PM posted to rec.aviation.soaring
Pierre Vav
You should update your web site ...
Old December 14th 14, 10:32 AM posted to rec.aviation.soaring
Ventus2NZ
reco=
Here's the latest:
solde=
is w=
vario
policy:
barograph c=
mounte=
is b=
battery=
be u=
few=
warning/=
for
receiver ?)
going to happen.
there somewhere.
-Dave
Is there an updated gps engine we can fit in the 302ddv to keep these units going as an fai logger?
-Alan.
Old December 14th 14, 12:40 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Since FAI issues approvals for each individual model of logger, does this
modification mean that the logger is no longer an approved model and
hence no longer valid for badges, records, etc?
I genuinely don't know if this would be the case: can somebody who is up
to speed with GNSS approvals comment?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 14th 14, 01:50 PM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
You are right. When approval is first given, each manufacturer agrees to
certain conditions, which are listed in the Specification Document. Amongst
these is:
Notification of any intended change to hardware, firmware or software must
be made by the manufacturer or applicant to the Chairman of GFAC so that a
decision can be made on any further testing which may be required. This
includes changes of any sort, large or small.
GFAC may decide that further testing is required, or may just revise the
approval document to reflect the change. I do not speak for GFAC.
However, there may be a further difficulty. The firmware may need to be
changed so that the correct GPS engine type apprears in the IGC file. I am
not sure that the source files for the firmware are accessable any longer.
Tim.
Old December 14th 14, 02:35 PM posted to rec.aviation.soaring
David Kinsell[_2_]
flight reco=
Here's the latest:
solde=
(which is w=
vario
policy:
barograph c=
mounte=
fix is b=
battery=
will be u=
a few=
warning/=
info
for
this mod mess up the GPS by injecting interference/noise into the
screened receiver ?)
non-volatile memory on board to prevent the time from going backwards,
but that's not going to happen.
I would expect the cost of trying to do hardware modifications would
exceed any reasonable valuation of what they're currently worth. The
brain damage of trying to get OLC to accept the files has to be figured
in there somewhere.
black-
good for a number of additional years.
-Dave
-Alan.
There was a GPS15 that superceeded the GPS25, physically smaller but
drops in with a physical adapter. Ian Macphee in Australia has claimed
that these were used in back-case 302's. I have a black-case unit, it's
still good, and the igc file says GPS25. I've heard of other black-case
units also being good. Perhaps if people posted their results with the
two different case types that would be helpful. Or I expect ClearNav
could shed light on the issue. Ian works on Cambridge units in Australia
and should fully aware of the situation.
If GPS15's have been used in some units, perhaps they ought to be
grandfathered at this point, much the same way the whole GPS-NAV line was
grandfathered without producing valid IGC files in the first place.
-Dave
Old December 14th 14, 03:11 PM posted to rec.aviation.soaring
Tango Eight
Well the rumor mill is hot today!
The whole point of the exercise is to preserve the utility of the 302 as a secure flight recorder. Thought that was sort of obvious....
The GPS card in the 302 vario was changed twice that I know of during production. The CNi fix uses the same GPS 15 unit as the most recent 302 production.
best regards,
Evan Ludeman for CNi
Old December 14th 14, 03:25 PM posted to rec.aviation.soaring
I took my 302 out of my glider this week because it is not good. It has a black case and a GPS25. Was bought in 2007.
Latest update of SeeYou and OLC flight claims causing problems [email protected] Soaring 6 October 30th 14 08:59 PM
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 09:31 PM
IGC-approval for LXN Colibri recorder - update issued [email protected] Soaring 0 June 20th 05 09:58 PM
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder Ian Strachan Soaring 0 March 15th 04 03:32 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 09:08 AM
