New Wind Forecast Site
Old December 17th 14, 05:43 PM posted to rec.aviation.soaring
John Carlyle
Default New Wind Forecast Site
Check out www.windyty.com It will be interesting to see if its forecasts are accurate enough for ridge soaring. One nice feature is that you can change the altitude for the forecast (lower right side) to get predictions for ridge height in your area.
-John, Q3
Old December 17th 14, 06:54 PM posted to rec.aviation.soaring
ND
-John, Q3
one thing I find interesting looking at texas/OK/NM. I know it's not the best season for the marfa dew line, but you can clearly see the convergence of desert air moving east and most air moving northwest from the gulf, which probably is depecting what we call the marfa dew line. kinda neat!
Old December 17th 14, 07:36 PM posted to rec.aviation.soaring
Burt Compton - Marfa Gliders, west Texas
More commonly called the Marfa Dry Line, here is the website I use for today's current dry line location near Marfa in southwest Texas: http://weather.unisys.com/surface/sf...de&inv=0&t=cur
The Marfa Dry Line occurs year-round. It is overhead today, with cumulus just to the north of Marfa visually indicating its presence. The website also shows a fairly tight gradient. Launch the fleet!
Old December 17th 14, 08:09 PM posted to rec.aviation.soaring
ND
On Wednesday, December 17, 2014 2:36:35 PM UTC-5, Burt Compton - Marfa Gliders, west Texas wrote:
Thanks for the additional info Burt. where are you seeing it located on that map? is it the region right around marfa where you see several relatively closely spaced dewpoint lines oriented approximately north and south?
Old December 20th 14, 01:48 AM posted to rec.aviation.soaring
JS
Cool. It's much like the Nullschool site. Either can be adjusted to various altitudes.
http://earth.nullschool.net/#current....92,41.00,3000
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) JR[_2_] Aviation Photos 0 August 13th 08 09:36 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
density altitude calculator and wind calculator on web site and asGoogle gadget Howie Piloting 3 August 5th 07 11:52 PM
density altitude calculator and wind calculator on web site and asGoogle gadget virtuPIC[_2_] General Aviation 0 August 4th 07 05:55 PM
