Closest airfield to NYC to fly gliders or to keep a SLMG
Old December 17th 14, 06:08 PM posted to rec.aviation.soaring
Default Closest airfield to NYC to fly gliders or to keep a SLMG
On Saturday, December 6, 2014 3:08:20 AM UTC-5, albs wrote:
I live in Europe and will be relocating to New York City next spring. Which would be the closest airfield where I could keep a SLMG (doesn't necessarily need to be a glider club) or the closets airfield where gliders are operated (which and/or tow)? Any that you'd recommend in particular?
thank you
For soaring, the sites listed are your best bets. I believe there are still sites out on Long Island, but travel to them can be "interesting" in the summer due to traffic volumne.
As to where to keep your SLMG, keep in mind closer airports are within the "Mode "C" veil" from the 3 NYC area major airports. It will really require some additional radio/transponder equipment to deal with that even if the airport (like Lincoln Park, NJ) is "uncontrolled".
I know Middletown/Valley Soaring (where I've flown for 30+ years) has a bus from NYC to not far from the airport. Not sure what, if any, real "mass transit" options the other airports have.
We also have a number of Long Island/NYC area members that get together and car-pool to the airport.
Yes, you should visit each and see what you like. Valley Soaring is sorta modeled off the European "club type" airport. It is a mixed use airport (as most are) where we have glider operations, power traffic, ultralights, balloons, etc.
Old December 23rd 14, 02:14 PM posted to rec.aviation.soaring
thank you
I live in downtown Manhattan, grew up in the area, have lived in NYC all my adult life, and have landed at nearly every airport in NJ.
One thing you have to ask yourself is do you want fly out a glider community? or is any airport OK?
If you want a glider community, then you have already heard from the people in this group.
If you're happy with a "airplane airport," then you're right, Lincoln Park is a good non-towered airport, but it is still a fair trip from Manhattan.
Another alternative is (and I can hear the groans now) Linden airport. Its a fairly quiet airport, has a low volume, and is mostly used by commercial heli ops in NJ. The challenge is that it sits underneath an 800ft shelf of Newark's Class B, and 3 miles south of the surface area. Since you have a PPL, the radios and navigation should be no problem for you. Its a very quick trip to Linden from downtown Manhattan, and there are hangars and tiedowns.
The travel times mentioned to Blairsdown, Wurstburo, or Middletown are accurate, but they are best case only on if the timing is right. You could make it all the way from Blairstown to the Holland Tunnel in 45 minutes, and then wait 30-45 minutes at the tunnel toll. I know this because my in-laws live right near there.
Good luck with your move, and feel free to contact me if you want to chat privately about being a NYC-based pilot.
http://skyvector.com/?ll=40.58474990...art=119&zoom=3
Old December 23rd 14, 09:13 PM posted to rec.aviation.soaring
thank you
If you're happy with a "airplane airport," then you're right, Lincoln Park is a good non-towered airport, but it is still a fair trip from Manhattan..
I live 5 minutes from Lincoln Park airport and do not consider it suitable for any but the most powerful of self launch sailplanes. This is due to size as well as the airport environment. There are no options if something does not go right.
As to flying out of Linden, I would presume that the thought is to fly a touring motor glider out of there. Flying a true self launch sailplane would seem to make very little sense, given the constraints on exiting and entering the airspace. Flying a soaring type final glide into there would be folly.
FWIW
UH
Old December 23rd 14, 09:29 PM posted to rec.aviation.soaring
Bob Pasker
agreed. I should have been more specific
thank you
FWIW
UH
Old December 24th 14, 12:54 AM posted to rec.aviation.soaring
MNLou
@Bob - Welcome to the tribe! One thing I would strongly suggest is working through your B,C, Bronze, and Silver badges. The requirements for each badge get you increasingly prepared for cross country flight.
Lou
Old December 24th 14, 03:17 AM posted to rec.aviation.soaring
thank you
What type of glider are you planning on operating?
UH
Old September 25th 16, 09:24 PM posted to rec.aviation.soaring
Hi Alberto,
Where did you end up flying from at the end ?
Dan
thank you
Old September 26th 16, 10:54 AM posted to rec.aviation.soaring
albs
Haven't decided yet - went a couple times to Blairstown and I liked it very much so will probably we there, but the drive from where I live is a bit long (1.5h). If you have a slmg you could potentially try Somerset which is 1h from Manhattan. I fly power from Lincoln park (40 mins from Manhattan) - impossible there with a slmg. Best - alberto
ID this Airfield Hans Holbein Aviation Photos 0 August 1st 08 03:26 PM
The Closest thing to Owning an Aircraft customairmodels Owning 11 November 26th 05 02:24 PM
Closest GA Airport to Cape Canaveral? Jay Honeck Piloting 9 March 11th 05 10:54 PM
GA Airport closest to mississauga shakti Piloting 8 February 28th 05 10:19 PM
Closest SDF, LDA and LOC-BC Approaches Andrew Sarangan Instrument Flight Rules 17 June 5th 04 03:06 PM
