Rutan hits 200k feet! Almost there!
Old May 16th 04, 02:55 AM
Steve Hix
Mary Shafer wrote:
On Fri, 14 May 2004 22:44:42 -0700, Steve Hix
In article . net,
"Steven P. McNicoll" wrote:
"Vaughn" wrote in message
news
Sorry, but I have to go with Pete here, the relevent point is that
it is being done by a small private corporation...and they are making
it look easy!
What is significant about a private corporation duplicating a feat that a
government agency accomplished decades earlier?
They don't need a cast of thousands and a couple hundred million to do
it.
The X-15 program didn't have a cast of thousands. It also didn't cost
a couple hundred million. In fact, it didn't even have a cast of a
thousand, now that I think about it. Maybe two or three hundred
people, for all three vehicles, at most. The cost was in the
millions, of course, but not hundreds of millions.
I'd be surprised if the X-15 program could be duplicated now for
anything close to original cost and manpower.
And I don't think that that is a Good Thing(tm), either.
  #122
Old May 16th 04, 02:57 AM
Steve Hix
"Keith Willshaw" wrote:
nk.net...
"Keith Willshaw" wrote in message
The problem is that merely reaching the altitude is only a
part of the problem. The real issue is achieving orbital velocity
and the Rutan aircraft doesnt achive much more than 15%
of the velocity required to put something in orbit.
Why is that an issue?
Because without reaching orbit you cant do anything useful.
So much for sounding rockets. Let's shut down Wallops Island and White
Sands...
Reaching the altitude is all they're trying to do.
Thats obvious
Keith
  #123
Old May 16th 04, 03:25 AM
Peter Stickney
Chad Irby writes:
(Peter Stickney) wrote:
However, granting that - here's the list of altitude flights by X-15
#3 66672, (Which, it should be pointed out, wasn't the ablative coated
X-15A-II 66671.
Date (1963) Elapsed since Altitude Comment
previous flight
18 June 0 Days 223,700' Pilot: Rushworth
27 June 9 Days 285,000 Rushworth, (over 50 miles)
U.S. Astronaut
qualification
19 Jul 22 Days 347,800 Pilot: Walker (Over
100 Km) Intl Atro
qualification
6 Aug 17 Days Abort Weather Abort &
Computer overheat
13 Aug 7 Days Abort APU doesn't start
15 Aug 2 Days Abort weather Abort
22 Aug 7 Days 354,200 Walker: second
Intl Astro Qual
All X-15 operations postponed due to weather for 6 weeks after this
flight.
So, we've got 2 high altitude flights separated by 9 days,
Two-thirds of the height of the max alt flights needed under X-Prize.
285 is 2/3 of 328 ? Around here we use Base 10 Numbers, Podnah.
How 'bout 285 is 88% of the altitude needed.
If you look at what was done, adn how it was done, there wasn't much
difference, or any different preparation between an X-16 flight to 88
Km (50 miles), and 100 Km. It's a matter of engine run time and
flight profile.
What we have is two "qualifying" flights in July/August, separated by a
month, two hardware failures and a couple of weather failures. So, by
your own admission, they couldn't do it.
No, they _didn't do it. There wer also weather delays between the
first 100 Km flight and the second attempt.
Weather and Equipment problems are Bad Luck - NASA, or Burt Rutan, or
Raymond Orteig himself can't do anything about them. They will affect
all progrems, including Spaceship One. There was nothing in the
X-15's mission that _required_ that type of turnaround. You've been
contending that it wasn't possible. I've been pointing out that it
was possible. It just wasn't important.
I'd say that if somebody had really wanted to fly 2 over 100 Km X-15
flights somewhere around 10 days apart, they'd have certainly been
able to do it.
But, in the actual records, they *couldn't*. Computer overheat,
vulnerability to weather, bad APU... nope, they couldn't manage it, even
with the less-stringent "rules" in effect.
At this point, on this subject, I'd have to say that you are being
either blindly irrational or deliberately obtuse. C'mon Chad, you're
smarter than that.
If the Rutan craft doesn't manage to do the two flights in two weeks
because of some weather issues, will you argue that they could have done
it?
Sure. And knowing Burt Rutan, he'll keep trying until he does.
Nobody has limited teh X-Prize teams to only one try.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
  #125
Old May 16th 04, 03:34 AM
Peter Stickney
In article .net,
"Steven P. McNicoll" writes:
"Peter Stickney" wrote in message
And that was also, in fact, the Big Deal behind teh Orteig Prize.
Transatlantic flights had been done for nearly a decade before
Lindberg (Or Byrd, or Nungesser & Coli, ir Wooster) entered into the
picture.
The Orteig prize was not for the first transatlantic flight, it was for the
first non-stop flight between New York City and Paris.
Precisely. I think that _that's_ been clear from the very beginning.
But winning the Orteig Prize also didn't mean that commercial air
travel over the Atlanntic was feasible, either. That took another 10
years.
While not routine, there had been a number of crossings,
but of either so limited value (Alcock & Browm - a great flight, mind,
but so razor-edged that it wasn't in any wise anything but a valiant
first attempt)
Alcock & Brown won the Daily Mail prize with that flight, the first between
North America and the UK.
The first non-stop flight between North America and the U.K. The
NC-4's final destination was Southampton.
Pete Stickney
  #126
Old May 16th 04, 03:43 AM
Peter Stickney
Chad Irby writes:
In article .net,
"Chad Irby" wrote in message
om...
...for a tiny fraction of the cost, and having the ability to
repeat the feat in less than two weeks (which the government
program didn't manage).
So what's significant about it?
If I have to explain to you the significance of the tech behind a
reusable spaceplane, then why have you even bothered posting to this
thread to begin with?
There ain't a whole lot of tech, there, Chad - Burt's taking a very
low-speed approach, (Rather Grand Fenwickian, in fact) with a low
thrust, long burning rocket motor, and a fairly lightweight, high drag
reentry vehicle. Peak speeds are around Mach 2 on ascent, and
somewhere around Mach 1.9 on the re-entry. There's nothing
particularly exotic about those speeds. Heating is low - around 100
Deg C, and an Aluminum or Composite airframe can deal with those
temperatures and dynamic pressures without a whole lot of trickery.
He's also designed a self-stabilizing shape, (In some ways not too
different from the behavior of a badminton birdie) that doesn't need
sophisticated systems, such as adaptive flight control systems or
reaction controls, to set and hold its attitude. While it's a good
design, it's not significant in advancing technology. It also can't
be expanded much beyond the X-Prize requirements. You aren't going to
see an orbital Spaceship !, or a Semi-Ballistic Spaceship 1 Hypersonic
Transport.
It's a very clever design very highly optimized to do only one thing -
meet teh X-Prize requirements.
Pete Stickney
Spaceship 1 hits 212,000 feet!!!!!! BlakeleyTB Home Built 10 May 20th 04 10:12 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) Peter Stickney Military Aviation 45 February 11th 04 04:46 AM
Ta-152H at low altitudes N-6 Military Aviation 16 October 13th 03 03:52 AM
