Cutting sheet steel
Old November 25th 03, 04:04 AM
Ernest Christley
Default Cutting sheet steel
I've got some .035 4130 that I have to cut elevon ribs from. 2 inch on
one end, 3/8ths on the other and about 16" long (each one is a different
length). The small end fits against a run of tube, the thick end against
the elevon spar. Both ends have to be shaped appropriately. The sides
of the long runs need to be perfectly straight. I've seen a lot of
options on how to cut aluminum, but the info on steel seems to be more
limited. Here's where I'm at so far.
A shear big and strong enough to handle the job is currently out of my
budget. (though, I keep hearing that the economy is coming back around)
Harbor Freight has a $35 cutting tool that can handle the job according
to the advertised specs. It sorta, kinda looks like an angle grinder,
except that it has a short arm and a reciprocating tooth out one side.
I figure I can drill a 3/8" hole, clamp a 2x4 to each side of the sheet
as guides, and just make a run with the cutter. Anyone have experience
with these things? Do they leave a clean edge?
Another option is to pay a machine shop. If I can find a good shop, I'm
sure to get quality work, but I can't say that I did it and I won't have
a tool afterward. I'm saving that as a last resort.
Are there any better options?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old November 25th 03, 04:32 AM
Veeduber
..035 isn't that thick and 'perfectly straight' is relative but the average
nibbler will be close to its limit.
One of the most commonly used tools in my shop is the throatless shear.
First thing I would do is make up an accurate pattern showing the centers of
any holes plus at least two tooling holes. I'd lay that out with at least a
sixteenth outside the finish line and do all the drilling in the flat. Then
whack them into APPROXIMATE size with the throatless shear, phasor (ie, plasma
cutter), bandsaw or abrasive disk. Once cut the edges have to be treated so
the pieces will lie flat against each other. They they get bolted together
using the tooling holes.
Now I've got a steel BAR about three-eights thick by 16" long, which should be
pretty easy to bring to finished size using a file, disk grinder, belt sander
or whatever..
I think you'll find that uniformity will have a higher priority than absolute
dimensional accuracy.
-R.S.Hoover
Old November 25th 03, 04:34 AM
Orval Fairbairn
I have a very large pair of sheet metal shears thet I have use to cut
..032 4130. It takes a lot of effort, but is doable.
Old November 25th 03, 12:53 PM
Jimmy Galvin
Save yourself a lot of aggravation. Do not buy anything from "Harbor
Fright". All they sell is junk and it never works like they say. You would
have a lot more fun throwing the money in your toilet and watching it swirl
around as you flush.
Old November 25th 03, 01:24 PM
KJKimball
If this is a one time project and you do not see the need for a proper shear in
your future, find someone near you with a shear, pay them to cut the ribs for
you. Or, if they will allow, use their shear to cut the ribs. We let locals
use our shear now and then.
Kevin
Old November 25th 03, 03:13 PM
Rick Pellicciotti
"Jimmy Galvin" wrote in message
swirl
I think it is pretty obvious from the prices that the stuff you get from
Harbor Freight is not "top of the line". That said, I have bought a lot of
stuff from them that works just fine. My air powered pop rivet gun has
built 3 airplanes so far. I only paid $39.00 for it. My band saw has cut
anything I have need to cut on 3 airplanes. The snowmobile casters that I
bought from them hold my Pulsar just fine and allow me to put it in the T
hangar, behind the pole, and still fit my Waco in too.
It is a bit of an overstatement to say that nothing Harbor Freight sells
works.
Rick Pellicciotti
Old November 25th 03, 07:26 PM
Holger Stephan
Sometimes it is not what you get that matters but you make out of it:
http://www.mini-lathe.com
That said, a lot of tools at Harbor Freight work just fine without such
refinement. Some do not, so asking around may make sense.
- Holger
Old November 25th 03, 10:22 PM
Jimmy Galvin
You have stated a valid view point.
I have been in construction all of my life. I made a living using tools. I
am not satisfied with less than top of the line tools because they make life
soooooo much easier. An example would be I use Milwaukee drills. I would not
walk across the hall to get a free Master Mechanic drill. I don't care for
their quality but if you are satisfied with their products then that's fine.
of
works.
Rick Pellicciotti
Old November 26th 03, 12:08 AM
O-ring Seals
On Tue, 25 Nov 2003 03:04:45 GMT, Ernest Christley
Veeduber
Veedubber,
One of the easiest ways to cut sheet 4130 is with a band saw. Use an
old metal cutting blade installed upside down (the teeth pointing up).
Run the saw at normal speed and feed in the material. Keep the
pressure up and it will go (melt) through like you are cutting butter.
Don't pause though, it is not so easy to get started again. Some have
also used the back side of the blade for this purpose with success.
O-ring Seals
Old November 26th 03, 01:34 AM
Roger Halstead
Just a comment on the plasma torch. I had one here for a while when
we were building the shop. It didn't take long before I could cut one
of those sheets of painted barn metal without scorching the paint. If
the paint started to show signs of heating you knew you were moving
too slow (and this was one of those little self contained units with a
turbine compressor.) Those things are nice...plus they'll cut just
about anything unlike a torch.
I had ordered a much larger one, but they tried to talk me into the
little one. It wasn't big enough for the 1/2 inch thick plate and
even thicker I beams I was cutting so I used the torch. After wearing
out one tip, I let them have it back, but by then I couldn't justify
the big one.
You'll have to fix the return add due to dumb virus checkers, not spam
(N833R, S# CD-2 Worlds oldest Debonair?)
www.rogerhalstead.com
or whatever..
-R.S.Hoover
air drill question Ded Dog Home Built 24 November 24th 03 11:43 PM
blue foam & cutting it Richard Riley Home Built 6 November 24th 03 02:53 PM
Pitts Special Steel Tube Fuse Mod. Martin Morgan Home Built 0 November 24th 03 12:08 AM
steel 4130 Philippe Vessaire Home Built 4 October 19th 03 08:19 AM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 08:08 PM
