PowerFLARM parameters for Silver badge?
Old March 6th 15, 06:02 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default PowerFLARM parameters for Silver badge?
On Friday, March 6, 2015 at 12:32:38 PM UTC-5, Bob Pasker wrote:
thanks, most helpful answer yet. i'm not ready to do distance, just altitude gain and duration, so I don't yet have to worry about the declaration.
I'd recommend that you get used to doing declarations on every flight; then, when Silver Distance day comes, it will be a habit, and not another detail on what will be a hectic day. If you get in the habit of inserting declarations and downloading the files, you will be able to analyze your flying against others ("how did she stay up when I could not?") and gain OLC points (OLC is a great place to store flights for later).
Paper declarations are good for initial attempts; however, the table in Appendix 2 to Annex C of the Sporting Code indicates you don't need one for Silver Height or Duration - just fly the flight and download the file for the Height, and use either the file or a Certificate of Continuous Observation for the Duration...
Annex C is very readable. Recommended reading.
Old March 6th 15, 08:24 PM posted to rec.aviation.soaring
Darryl Ramm
As you start exploring XC I would try to start making declarations, just for the experience to see how it works, and get used to all the extra complexity associated with different starts and finishes etc. Once you think you've done even the shortest declared flight, download it and play in SeeYou and see if you think the flight really qualifies...
Old March 7th 15, 12:04 PM posted to rec.aviation.soaring
Flights downloaded from OLC have been altered. They will not verify and therefore are not valid for badges.
Walter
Silver Badge questions Bob Pasker Soaring 31 February 22nd 15 08:23 PM
fly with ce silver badge question Bob Cook[_2_] Soaring 4 August 20th 13 04:37 PM
fly with ce silver badge question Bob Cook[_2_] Soaring 0 August 20th 13 02:47 AM
Silver Badge! [email protected] Soaring 17 November 24th 08 03:12 AM
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
