Oudie to Cambridge
Old March 6th 15, 02:49 PM posted to rec.aviation.soaring
HGXC[_2_]
Default Oudie to Cambridge
Anyone using an Oudie connected to a Cambridge GPS model 20? I have a few questions.
Dennis
Old March 6th 15, 05:55 PM posted to rec.aviation.soaring
Peter von Tresckow
Dennis
Yes mine is hooked up to a model 20 and s-nav.
What do you need to know?
Pete
Old March 6th 15, 07:28 PM posted to rec.aviation.soaring
HGXC[_2_]
On Friday, March 6, 2015 at 12:56:42 PM UTC-5, vontresc wrote:
Dennis
Pete
Perhaps we can private email...
But in general I am setting up the DB9 serial connect so the Oudie can talk to the Cambridge
I would like to see a photo of the pin set up on the male serial that plugs into the Cambridge. Also if you are only using 3 pins (Sending Receiving and Ground) what do you do with the rest of the wires? Does the plug only show 3 pins?
Also how can i tell of the oudie is taking GPS from the cambridge? My glider is in storage but i can plug my cambridge in to power it up and I can take the three pins and insert them into the Cambridge and plug the mini usb into the Oudie. When i do that it is saying it lost GPS signal and is going to internal GPS so i am confused.
Thanks ...obviously I don't do electronics well.
Dennis
Old March 6th 15, 10:06 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I show the connections for the RJ45 to DB-9m adapter for use with a GPS-NAV
and Oudie he
http://www.cumulus-soaring.com/seeyo...pter-RJ45-DB9m
Make sure you set the Oudie to comm port 4 and 4800 baud.
The SeeYou Mobile software can receive GPS and pressure altitude data from
the GPS-NAV. I don't think it can receive vario or airspeed data sent
through from an L-NAV.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
____________________________________
"HGXC" wrote in message
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
Old March 6th 15, 10:17 PM posted to rec.aviation.soaring
vontresc
On Friday, March 6, 2015 at 4:06:35 PM UTC-6, Paul Remde wrote:
Hi,
and Oudie he
Best Regards,
Paul Remde
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
Paul is spot on. I still have the original Oudie cable that had a DB9 connector instead of the RJ45. That original cable will plug rught into the DB9 on the back of the Model 20. Thena all you need to do is to connect the power connectors to the ships power and you are done.
If you have the newer version with the RJ45 then follow Paul's instructions to wire it up.
To test it you can go to the serial terminal mode under settings/hardware. Should be 4800baud 8N1
Peter
Old March 10th 15, 09:15 PM posted to rec.aviation.soaring
HGXC[_3_]
Hi,
and Oudie he
Best Regards,
Paul Remde
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
To test it you can go to the serial terminal mode under settings/hardware.. Should be 4800baud 8N1
Peter
Peter all...its a bit frustrating as i still get a warning that I lost my primary GPS signal and going to back up. When i go to hardware i get the reading 4800 baud N 8 1. Its charging right from my 12 volt. I have tripled checked my red black and orange pins. Now i haven't clicked them in the converter yet i am just sticking the pins individually into the 2,3,and5 sockets..
Any other set up stuff i could be missing?
Dennis
Old March 10th 15, 11:47 PM posted to rec.aviation.soaring
vontresc
Hi,
and Oudie he
Best Regards,
Paul Remde
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
Peter
Dennis
Do you get any data when you open up the terminal mode window? You should see a bunch of streaming NMEA messages. "$GP..."
Pin 2 on the DB9 is the TX from the GPS Nav and should go to pin 5 on the RJ45 Oudie RX (red)
Pin 3 on the DB9 is the RX on the GPS NAV and should go to pin 6 on the RJ45 Oudie TX (black)
Pin 5 on the DB9 is the ground and should be wired to pins 7/8 on the RJ45
Here is the IGC Standard RJ45 pinout http://www.millenair.nl/shop/image/d...rj45pinout.png
Hope this helps.
Peter
Old March 11th 15, 01:15 AM posted to rec.aviation.soaring
HGXC[_3_]
Hi,
and Oudie he
Best Regards,
Paul Remde
few questions.
Dennis
Pete
to the Cambridge
show 3 pins?
Dennis
Peter
Dennis
Hope this helps.
Peter
"Do you get any data when you open up the terminal mode window? You should see a bunch of streaming NMEA messages. "$GP..."
No I saw nothing when I opened up the terminal window and i thought that was strange.
Dennis
Old March 11th 15, 02:56 AM posted to rec.aviation.soaring
Paul Remde
Hi,
I wonder, is there any chance that you have the pin order backwards. Pin 1
is on the right when connecting to the back of the male connector. It is on
the left when looking at the pins. Make sure you use a magnifying glass and
get the light angle right so you can read the raised pin number markings.
Best Regards,
Paul Remde
Hi,
GPS-NAV
and Oudie he
from
Best Regards,
Paul Remde
a
few questions.
Dennis
Pete
talk
to the Cambridge
plugs
Receiving
only
show 3 pins?
glider
take
into
to
Dennis
Peter
sockets.
Dennis
Old March 11th 15, 06:49 AM posted to rec.aviation.soaring
Ian Reekie
Hi
I have an Oudie connected to a GPS 25 and its works great.
Assuming the wiring is correct there is one big possible Gotcha
I am not sure anyone has mentioned.
The GPS 20 has to be sent a message by the Seeyou Mobile
on the 9 pin plug to command it to send out NMEA.
For Seeyou Mobile (SYM) to do this you have to have the SYM
set to both Cambridge GPS-NAV (in settings Hardware)
and the correct speed 4800 speed
It is very important that when you start Seeyou Mobile that
the Cambridge logger is powered up, otherwise it may
miss this message.
In the Terminal window you can manually send the command
to the Cambridge at the top of the window for test purposes
type NMEA then hit send.
So in summary assuming you have set up Seeyou mobile for
the Correct speed and Cambridge hardware.
I switch on the logger give it a minute to power up and
send waypoints to its square display. (which is a separate processor)
Then I start Seeyou mobile. Works every time :-)
Oudie 5.19 Bug Lauren Soaring 3 June 4th 14 06:57 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
