.cup file Import into Google earth?
Old March 29th 15, 12:00 AM posted to rec.aviation.soaring
joesimmers[_2_]
Default .cup file Import into Google earth?
Is it possible to import a .cup file created in SeeYou
into Google earth for viewing?
Thanks for any info, Joe
Old March 29th 15, 04:25 AM posted to rec.aviation.soaring
Robert Dunning
try http://www.gpsvisualizer.com/gpsbabel
Rob
Old March 29th 15, 04:30 AM posted to rec.aviation.soaring
Yes! Good old GPSVisualizer. Converts most anything to GE. The go to site if you don't want to spent the $ on global mapper...
Old March 29th 15, 04:33 AM posted to rec.aviation.soaring
Actually, GPS Visualizer/GPS Babel is the convert almost anything page:
http://www.gpsvisualizer.com/gpsbabel/
Old March 29th 15, 06:16 AM posted to rec.aviation.soaring
2KA
My website at http://www.soaringdata.info also will do it.
- Go to the airports tab to access the query form
- Upload your .CUP file on the second line
- Check the checkbox for .KML companion file on line 4
- Type "Soar" into the required box and press Go.
Lynn Alley
"2KA"
Old March 29th 15, 05:42 PM posted to rec.aviation.soaring
Muttley
Lynn Alley
"2KA"
IGC Flight Replay will show .igc files in Google Earth
http://www.ywtw.de/igcsimen.html
Mottley
Old March 29th 15, 06:22 PM posted to rec.aviation.soaring
joesimmers[_2_]
I used Lynns website, worked great! Thanks!
Old March 29th 15, 11:53 PM posted to rec.aviation.soaring
WaltWX[_2_]
FIY...
Lynn's cup file database this year has excellent details information from the FAA database. The advantage here is that you can get tower freqd, AWOS/ASOS weather frequency, and other airport information sometimes even the airport manager name and phone number. Most moving map displays allow one to display this which is handy when your paper map (if you have one) is not quite up to date... or as in my case a year or two ago, the worn out old fold on the maps obliterated the tower frequency.
Walt Rogers
What on (Google) Earth... ?? GM Soaring 9 March 28th 08 04:54 AM
Saw This On Google Earth John[_1_] Naval Aviation 3 January 27th 08 12:25 AM
Google Earth Frank Whiteley Soaring 3 November 16th 07 12:36 AM
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 04:31 PM
Google Earth ttaylor at cc.usu.edu Soaring 8 September 22nd 05 12:07 PM
