Old XCSoar DAT file format
Old March 30th 15, 08:21 PM posted to rec.aviation.soaring
BDS
Default Old XCSoar DAT file format
Years ago XCSoar used a DAT file format for terrain files and the old
terrain generator would create a file like filename-dem.dat
Can anyone here shed some light on the file format of those DAT files and
how they were obtained or created?
Thanks.
Bruce
Old March 30th 15, 08:58 PM posted to rec.aviation.soaring
Frank Beythien[_7_]
Am 30.03.2015 um 21:21 schrieb bds:
You could try
http://forum.xcsoar.org/
Frank
Old March 30th 15, 11:31 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
That must have been a long time ago. Since version 6.0 (current is 6.7.7)
the file extensions used by XCSoar have been:
..dat = airfields and turnpoints in Winpilot format
..cup = airfields and turnpoints in SeeYou CUP format
..xcm = a compressed file containing the topology and terrain files
..txt has a number of uses:
(a) OpenAir airspace files
(b) airfield and turnpoint notes (these extend the info in
Winpilot DAT files
..tsk = task definition
..sua = SeeYou format airspace files
..prf = XCSoar configuration files
..xcp = glider polars, weights, ballast, etc and ID
..log = XCSoar runtime log
..igc = IGC flight log
..xcp was introduced with v6.0, (pulling together polars from .plr and ID
data from .prf.
..cup and .sua came in with v5.0
Apart from that, file extensions and their related file formats have been
pretty much the same since at least v3.0
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 30th 15, 11:37 PM posted to rec.aviation.soaring
Thanks.
Bruce
You have had 2 good replies, I guess my question is....... Why do you want to know? That may yield a totally different response from people on RAS.
Old March 31st 15, 03:19 AM posted to rec.aviation.soaring
SoaringXCellence
Thanks.
Bruce
The DEM files are created by geological surveys (satellite I think) here's the wikipedia entry:
http://en.wikipedia.org/wiki/USGS_DEM
Old March 31st 15, 03:03 PM posted to rec.aviation.soaring
BDS
"Martin Gregorie" wrote in message
Winpilot DAT files
data from .prf.
XCM yes - inside the compressed .xcm was the terrain file as
filename-dem.dat. This was the format in 2009 and perhaps for a few years
after that.
It is the -dem.dat terrain file that I am looking for information on.
Bruce
Old March 31st 15, 05:27 PM posted to rec.aviation.soaring
Chris Snyder
Bruce
If you want to have a terrain file for your area, you should check out the "Map Generator" - http://mapgen.xcsoar.org/ I was able to enter min/max lat/lon and it generated a map in a matter of seconds. I found my lat/lon using Google Map "what's here". Note, I did have to convert the Google Maps lat/lon format to the XC Soar format, but there were plenty of converters on the web.
If you need a hand generating, just post your location and desired radius and some tech-savy person may just do it for you.
Old March 31st 15, 05:41 PM posted to rec.aviation.soaring
or you can load "TopHat" by Rob Dunning - which is a user interface that uses XCSOAR - TopHat will go to the internet, show you a list and let you download the files you need - it is so easy, just be sure your device has internet connectivity when you are looking for the Site Files.
WH
Help adding a 2nd waypoint file in XCSoar Vsoars Soaring 0 June 22nd 14 09:35 PM
Format display Delbert Soaring 1 May 18th 09 01:41 AM
[Xcsoar-user] Terrain and waypoint file generation Ed Winchester[_2_] Soaring 0 May 3rd 09 02:34 PM
New 'Soaring' Mag Format Paul Hanson Soaring 0 February 3rd 08 12:19 AM
Hangar Queen in PPS format large file 3.21 MB Bruce R Aviation Photos 1 March 15th 07 02:49 AM
