Wow! Ooops, take #3
Old April 3rd 15, 02:42 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Wow! Ooops, take #3
On Friday, April 3, 2015 at 8:02:11 AM UTC-5, Dave Walsh wrote:
I think it says more about the technical competence of the
engine designers; maybe God doesn't like them either?
Well, crankshafts don't like to be loaded at their output location other than along the axis of rotation. Put a belt reduction drive on there, and you are applying load perpendicular to that. Interesting dynamics happen with a two cylinder in-line engine with this setup. It is not an easy system to design.
Steve Leonard
Old April 3rd 15, 02:48 PM posted to rec.aviation.soaring
Dave Nadler
Steve Leonard
The failure is the prop hub (receiving end of belt reduction),
not at the crankshaft. Last round was classic fatigue - nice
crystalline structure on broken part.
Old April 3rd 15, 03:44 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Steve Leonard
Same sort of issue. Up and down loading on that shaft due to increasing and decreasing tension because of engine dynamics and the loading going in and out of phase with the prop being in low or high moment of inertia relative to the motion (prop horizontal, low moment of inertia relative to motion created by pushing up and down by the drive belt). Likely source of the fatigue failure. But, as stated before, these are complex systems with lots of interactions. Be interesting to know the crack propagation direction relative to the blades on the prop.
Old April 3rd 15, 04:22 PM posted to rec.aviation.soaring
On Thursday, April 2, 2015 at 4:44:59 PM UTC-4, Dave Nadler wrote:
Yikes.
http://ad.easa.europa.eu/ad/2015-0052-E
Sounds along the lines of this.....
http://www.bugatti100p.com/web_docum...lvibration.pdf
Sorta long read (the link), but curious to see results from the new AD.
Old April 3rd 15, 06:10 PM posted to rec.aviation.soaring
Dave Nadler
Steve Leonard
Same sort of issue.
Yep.
Crack propagation direction wasn't obvious on the broken part I saw.
Propagation *appeared* to have started at stress points from inadequate
flange radius and/or rough machining marks.
Not my area of expertise!
See ya, Dave
Old April 3rd 15, 07:13 PM posted to rec.aviation.soaring
Eric Munk
I have seen a picture of the fracture. Could be a brittle fracture, but
can't say for sure without having seen it live... I am sure Solo will be on
to it. Engine apparently was run well within operating limits, had very low
time and had the mandatory SB performed (new part failed).
Old April 3rd 15, 09:15 PM posted to rec.aviation.soaring
Jonathan St. Cloud
On Friday, April 3, 2015 at 6:02:44 AM UTC-7, John Galloway wrote:
At 07:46 03 April 2015, Tango Whisky wrote:
It affects ONLY 2350C engines with non-foldable propellor. That's
DG1000T
in the first place (which caused the AD) and probably J'S. S-H is not
concerned (and I'll use it on my Ventus cM).
Also the turbo Antares - or at least the prototype according to this:
https://www.youtube.com/watch?v=-mxwvd-ps2A
Try buying an Antares 23, they are not even being made.
Old April 3rd 15, 10:25 PM posted to rec.aviation.soaring
howard banks
On Thursday, April 2, 2015 at 2:44:59 PM UTC-6, Dave Nadler wrote:
Yikes.
Based on Mr Nadler's description, failure more or less inevitable.
Too small a radius will reduce the part's fatigue limit by somewhere between one third and one half roughly speaking. A 90 degree non-radius would result in a more or less infinite reduction in the fatigue limit (which is the stress on a part below which it should have an infinite fatigue life; in the real world all sorts of things reduce this limit, as we are seeing).
Rough machining can be even more insidious. Each piece of rough machining that you can see by eye is more or less the same as an already existing early fatigue crack. Its root radius at a microscopic level is effectively infinite with a corresponding reduction in the fatigue limit. Very bad news especially when it happens at a designed in place of inherently high stress.
All they had to do was to add some hard chromium plate on any wear surface that ran around the radius and failure would have been even earlier.
Pretty basic stuff. For it to have been repeated, as seems to have happened after a known problem, amounts to extreme carelessness.
Old April 3rd 15, 10:34 PM posted to rec.aviation.soaring
Dave Nadler
Yikes.
as we are seeing).
earlier.
To be clear: The failed part I examined in fall 2013 was a "take #2" part.
The part was redesigned for "take #3", "resolving" the 2013 AD.
The new "take #3" part failed, leading to the most recent AD.
I have no idea what the failure of "take #3" looks like...
It is a bit surprising that 3 iterations of this part have failed...
But it is not an easy problem!
Hope that is clear,
Best Regards, Dave
Old April 3rd 15, 11:15 PM posted to rec.aviation.soaring
Yikes.
as we are seeing).
earlier.
Hope that is clear,
Best Regards, Dave
I'm NOT an "ME", I'm a field service guy with a "ME" background (as well as spending a lot of time fixing "good enough bits" on many different types of machines.....).
My link before was to show that there are quite a few factors to consider (not that anyone here know all the facts or can direct the final decision).
Just pointing out that some failures have been hit before, thus a research can find a suitable resolution.
"Thus that ignore history are doomed to fail in the same manner"..... or close to that....
Ooops... Zomby Woof[_3_] Aviation Photos 0 April 21st 09 04:36 AM
ooopS! my Bdadd Bertie the Bunyip[_2_] Piloting 4 March 29th 07 10:40 PM
Ooops ... incident at Santa Fe A. Sinan Unur Piloting 18 November 10th 06 01:44 AM
Derby weekend ooops Jack Harkin Soaring 0 June 22nd 06 05:44 PM
Ooops - Correction Bill Denton Piloting 0 August 9th 04 01:53 PM
