#31
At 04:07 06 April 2015, Jonathan St. Cloud wrote:
The badge process has withstood the test of time in building confidence and= skill. It took me three tries to finally get my diamond out and return. I = learned much from each flight, plus the fights got me flying further from h= m each time. On the first attempt the Cambridge data logger recorded point= s on either side of the turn point quadrant and if you drew a line between = the points the line would go through the quadrant, but it was rejected for = not hanging a Piont in the quadrant. You don't say when this was, but for a number of years a line through the quadrant has been an option in the Sporting Code. Sounds as though you were robbed. The second time, the logger lost GPS = signal for about four minutes while I was at the turn Piont. I was heading= for home when the logger re-established contact, I turned around and repea= ted the turn point but the claim was rejected as I had lost GPS and thus no= logging for four minutes. It was obvious to Judy Lincoln that on both flig= hts I completed the required distance but I was not in technical compliance= I would fight that one too. If the Pressure barogram shows that you could not have landed and re-launched (no ground within range at a height shown on the barogram), where's the problem? Anyway you would need to be very quick to land and re-launch in four minutes! But then I haven't seen the trace. .. So I flew it a third time! I had not been flying 500 k's more like 200k= 's, each summer weekend, all the sudden I did three 500 k's on three succes= sive weekends. I think not getting the badge on the first two attempts was= responsible for seriously expanding my range. If your badge claim is deni= ed, try try again, you will learn. |
#32
Dear Tim:
The time frame of the flights discussed was approximately 1996. I certainly was frustrated with the first denial, the second one I could understand as the recorder had stopped recording for about four minutes, but was very obvious I could not have landed and took off and climbed to altitude in that that short time frame. However, it was all a blessing in disguise. Before these flights I had been circling the airport maybe out to 50 - 70 miles at most. Now all the sudden I found I could declare a 500 K fly it and do the same thing again on suppose! Before these flights I had actually been passed about 20 miles out returning to the airport by an instructor flown ASK-21, I was flying a pre-winglet ASW-24 (my first real glider). Before the ASW-24 I had been renting the fixed wheel single seat Grob. I was still learning to fly the ASW-24, I thought it climbed best at 60 knots and all the experienced pilots were telling me I did not know what I was talking about I should be thermaling at 50 knots. Turns out I was right, the following year JJ installed winglets, that really made a big difference. That was a great bird. I remember the second year I had it, I set a goal of flying 400 hours. I flew all the time, if the weather was good during the week I would take a day (or two) off work to fly. I went on a soaring vacation for week to Minden and another week to Hobbs. Found out flying in the flat land is scary, in the mountains if I get low I tuck in close to the mountains, in flat land there is no place to tuck into I ended the season with 275 hours and there was just no way I could ever take that much time off of work again. I learned as much from the failures to earn the badge as I did from earning the badge. I sold the 24 moved up in size and had much fun until work, family and other interests lead me to stop soaring for other pursuits. I am back to soaring now and looking forward to this year and to buying a glider. |
| Acheiving Silver Distance 50KM | Scott Alexander | Soaring | 9 | July 19th 08 03:07 PM |
| ACCESS DENIED! | GARY BOGGS | Soaring | 6 | May 17th 08 09:30 AM |
| Airport Access Denied? | GARY BOGGS | Soaring | 13 | May 6th 08 02:47 AM |
| Silver Distance | Graham Hodgson | Soaring | 58 | June 15th 04 10:09 AM |
| Military Justice Denied | ArtKramr | Military Aviation | 3 | January 10th 04 08:20 PM |
