Terra TX720 schematic ...
Old April 14th 15, 04:57 PM posted to rec.aviation.soaring
Ron Gleason
Default Terra TX720 schematic ...
I have searched RAS for this topic and could not find specific answers so ...
The local club here in Northern Utah has acquired a new Grob Twin Astir with a Terra TX720 radio installed. The radio is working but the On/Off and volume switch has flat spots and we would like to replace it.
Does anyone have the schematics for this radio? Or does anyone know the exact switch that is needed (no markings on the existing switch).
Thanks in advance
Ron Gleason
Old April 14th 15, 07:59 PM posted to rec.aviation.soaring
Thanks in advance
Ron Gleason
Redo your search, but use "tx-720" instead. There are quite a few threads that will pop up.
IIRC, Gary Kemp had info on the radio, but it's an older thread.
Old April 15th 15, 05:36 PM posted to rec.aviation.soaring
Burt Compton - Marfa Gliders, west Texas
Search
http://www.esscoaircraft.com
Essco website shows they have a paper or downloadable manual in stock for $30.
A good investment if you plan to keep this older radio.
Old April 15th 15, 05:52 PM posted to rec.aviation.soaring
Ron Gleason
Thanks Burt. We will see what the club wants to do.
Old April 15th 15, 06:28 PM posted to rec.aviation.soaring
Craig Funston
If it's a simple switch + potentiometer you may be able to measure resistance at several points and find a replacement at Mouser or somewhere like that. If it's just a dirty pot, you may be able to use some cleaner on it and get a few more years out of the existing one.
Good luck,
Craig
Old April 15th 15, 07:30 PM posted to rec.aviation.soaring
Ron Gleason
Good luck,
Craig
Thanks Craig. We have some measurements but the number appear high (I am not a electronic guy) and were hoping to get actual specs before we looked around for a replacement.
Telex ANR schematic Roger[_6_] Owning 1 September 11th 12 04:04 AM
Narco COM 11A schematic Jstar Owning 1 August 1st 12 02:22 PM
Need Schematic for OLD Telex ANR Roger[_6_] Home Built 2 April 9th 11 10:47 AM
NEW Terra TRT 250 and Terra AT 3000 altitude digitizer - $500 grafxman Aviation Marketplace 1 December 29th 08 06:39 PM
FS Terra TX720 Soaring 0 February 12th 04 01:13 AM
