Nosing over on soft turf ?
Old April 19th 15, 12:33 PM posted to rec.aviation.soaring
Jock Proudfoot
Default Nosing over on soft turf ?
Scout vs Pawnee. Which would have more of a tendancy to nose over on soft
turf. ?
Old April 19th 15, 03:26 PM posted to rec.aviation.soaring
kirk.stant
turf. ?
Never flown a Scout, but fly a Pawnee off soft turf all the time and it is absolutely no big deal - except for getting mud splashed on your face if you taxi too fast with the window down ;^).
Super Cub with a big engine and Borer prop is OK too, but you have to watch for prop strike and not be too aggressive bringing the tail up at the start of the takeoff.
Note that we have bigger than stock tires on our towplanes - not tundra, just a size up. That really helps when it's soft.
Kirk
66
Old April 19th 15, 04:52 PM posted to rec.aviation.soaring
[email protected][_1_]
Kirk is spot-on. I have towed a lot in both and neither wants to nose over as both have a lot of weight on the tail. As Kirk said upgrading tires to 8.50x10's is a good idea for soft conditions.
Above all, taxi slowly, especially downwind, keep the stick in the appropriate place relative to the wind and STAY OFF THE BRAKES!
Old April 20th 15, 03:15 PM posted to rec.aviation.soaring
turf. ?
Fully agree with previous comments. Remember that you want to stay away from wheel landings, and that the power of the Pawnee will make a big difference in takeoff distance on a soft field.
Skip
Old April 20th 15, 04:24 PM posted to rec.aviation.soaring
Dan Marotta
I do mostly wheel landings but that's because of the stiff crosswinds
that we usually have at Moriarty. Never had a problem. (Yet...)
turf. ?
Skip
Dan Marotta
Old April 20th 15, 09:19 PM posted to rec.aviation.soaring
Mike the Strike
crosswinds that we usually have at Moriarty.* Never had a problem.*
(Yet...)
I bet you haven't had your wheels dig into the runways there either!
Mike
Old April 21st 15, 02:12 AM posted to rec.aviation.soaring
son_of_flubber
crosswinds that we usually have at Moriarty.* Never had a problem..*
(Yet...)
Mike
Do they have Mud Season in NM?
Old April 21st 15, 02:46 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
crosswinds that we usually have at Moriarty. Never had a problem.
(Yet...)
Mike
I'll bite!
There generally is a summertime "monsoon season" throughout the Rocky Mountain
region. I'm reliably informed by Moriarty locals that the powdery reddish
stuff commonly blown about there and often entrained in dust devils isn't
"dust" but "enchantment." When enchantment gets wet, I doubt the locals call
it "mud" but have a far more positive euphemism!
Bob - Dan M.? - W.
Old April 21st 15, 04:37 PM posted to rec.aviation.soaring
Dan Marotta
True dat! You'd really have to spike it on to dig the wheels into the
"ground". :-D
(Yet...)
Mike
Dan Marotta
Old April 21st 15, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
Yaaas... The monsoon. I haven't seen enough rain yet to make the
pavement soft!
problem.
(Yet...)
Mike
I'll bite!
Mountain region. I'm reliably informed by Moriarty locals that the
powdery reddish stuff commonly blown about there and often entrained
in dust devils isn't "dust" but "enchantment." When enchantment gets
wet, I doubt the locals call it "mud" but have a far more positive
euphemism!
Bob - Dan M.? - W.
Dan Marotta
Turf Soaring Shirl Soaring 4 August 28th 07 05:54 PM
Turf Soaring? rustynuts Soaring 1 June 8th 07 07:37 AM
Turf? BT Soaring 7 April 9th 07 02:13 AM
Turf Soaring available. Charlie Lite Soaring 2 February 13th 07 12:19 PM
Mid-Air at Turf Soaring Herbert Kilian Soaring 7 January 2nd 04 11:26 AM
