How do you delete all flight logs from a PowerFlarm?
Old April 26th 15, 09:54 PM posted to rec.aviation.soaring
Default How do you delete all flight logs from a PowerFlarm?
Anyone know how?
Old April 26th 15, 10:35 PM posted to rec.aviation.soaring
Richard[_9_]
On Sunday, April 26, 2015 at 1:54:35 PM UTC-7, wrote:
Anyone know how?
Add this to your config.txt file
$PFLAC,S,CLEARLOGS
Richard
wwww.craggyaero.com
Old April 26th 15, 11:52 PM posted to rec.aviation.soaring
Paul Remde
Hi,
The easiest way is to use the latest PowerFLARM Configuration File
generator - which is available he
http://flarm.com/support/tools-softw...guration-tool/
There is a checkbox for clearing the memory.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
______________________________
Anyone know how?
Old April 27th 15, 04:22 AM posted to rec.aviation.soaring
Fantastic, thank you for sharing!
Robert
Anyone know how?
$PFLAC,S,CLEARLOGS
Richard
wwww.craggyaero.com
Old April 27th 15, 04:24 AM posted to rec.aviation.soaring
Paul, thank you for sharing this! the configuration tool on the Air page doesn't seem to have this checkbox. I'll need to get my serial number so I can try out you link.
Robert
On Sunday, April 26, 2015 at 5:52:23 PM UTC-5, Paul Remde wrote:
Hi,
Best Regards,
Paul Remde
Anyone know how?
Old April 27th 15, 04:20 PM posted to rec.aviation.soaring
Ron Gleason
Robert
Hi,
Best Regards,
Paul Remde
Anyone know how?
Robert, you can get the serial number for your PF from a IGC file that has been downloaded from the PF. Might save you a trip to your glider.
If you use SeeYou open the flight, under EDIT select FLIGHT PROPERTIES and then choose the MISC tab. This will display the IGC file. Scroll down and look for the LFLA record (first 4 characters in the records) that contains the character string FLAPFC10A. Here is the line from my IGC file
LFLA17572807DEVNO FLAPFC10A-000351
Serial number 000351 in my case.
If you do not have SeeYou then open the IGC file with an application such as NotePad, Word or other and search for FLAPFC10A.
Good luck
Ron Gleason
Mangling of U.S. Contest Flight Logs? [email protected] Soaring 10 April 10th 12 04:17 PM
Cambridge GPS-NAV Flight Logs Dan Marotta Soaring 5 May 6th 11 01:44 AM
[US] Seniors Flight Logs PMSC Member Soaring 0 April 5th 09 04:35 PM
looking for flight logs from Cordele, '07 John Bojack[_2_] Soaring 1 February 27th 08 03:27 PM
Need GPS flight logs in NMEA format... [email protected] Soaring 6 February 15th 08 08:05 AM
