IOIO board for SN10 to Samsung Galaxy Note 4
Old May 9th 15, 01:57 PM posted to rec.aviation.soaring
Sean Fidler
Default IOIO board for SN10 to Samsung Galaxy Note 4
I'm looking to build this integration and put my miserably outdated Oudie out of its misery. Of course I am looking to run XC Soar or Top Hat on the Galaxy Note 4.
Has anyone built this specific IOIO board to date? If so please send me any lessons that you may have learned along the way.
I am ordering parts this weekend.
Thanks in advance!
Sean
Old May 9th 15, 02:54 PM posted to rec.aviation.soaring
waremark
I prefer SYM to XCSOAR - fully flexible screen layout and really easy to do what you need whether on the ground or in the air. I now have an Oudie IGC with bright screen, all day battery life, IGC logger (with wireless download), backup audio vario, and seamless integration with SeeYou for file setup. Please tell me what you prefer about XCSOAR other than that use of it is free.
Old May 9th 15, 04:52 PM posted to rec.aviation.soaring
The device you're getting the source data from isn't really relevant as long as you can figure out what pins the TX, RX and Gnd (and maybe +5v if you want to draw power off of the SN10) are on. Pipe those into an RS232 to logic level converter and then into the IOIO and you're good to go. I used the IOIO OTG board and the MAX 3232 breakout board (both from Sparkfun.com). I'm pulling GPS, wind, MacCready and bugs from a 302 into IOIO UART 0 (pins 3, 4) and FLARM traffic data into IOIO UART 1 (pins 5, 6). The 3232 board can handle two TX/RX pairs so it works beautifully.
Robert
Thanks in advance!
Sean
Old May 9th 15, 04:58 PM posted to rec.aviation.soaring
jfitch
In my opinion, XCSoar has a better UI in most respects than SYM. If those were the only two choices, I would pay for XCSoar even if SYM were free. Fortunately those aren't the only choices.
Old May 9th 15, 10:40 PM posted to rec.aviation.soaring
Sean Fidler
1) The UI
2) The flexibility of the Modern Android devices
3) The vastly higher resolution touch sensitivity of the modernAndroid devices (try using Oudie with your fingers and not the stylus)
3.1) pinch to zoom, two fingers to pan, etc.
4. The software itself (XC Soar vs SeeYou mobile which is essentially unchanged in a decade)
5) The ability to use cellular broadband data connectivity for a whole host of applications:
5.1) SKYLINES
5.2) Weather
5.3) Retrieve applications
5.3.1) GPS coordinates, etc
5.4) Device integration with SPOT or Delorme InReach Bluetooth connected applications
5.5) etc, etc, etc.
6) The VASTLY superior resolution of this the terrain map.
7) Automatic calculation of Final Glide over terrain.
8) I can go on and on and on and on....
Old May 9th 15, 10:42 PM posted to rec.aviation.soaring
Sean Fidler
Thanks Robert. Great info. Soldering iron warming up...
Old May 10th 15, 12:49 AM posted to rec.aviation.soaring
I too am in the market for a change for a flight computer (actually a secondary flight computer). eInk seems best but all current production models...like Nook...are too big in my opinion. Please understand I am not challenging your direction but have a few questions.
What specific transition electronics are you planning to use? Sparkfun? Have you you had a Galaxy Note 4 in a cockpit to confirm it will be visible in bright sunlight?
Thanks for sharing.
Thanks in advance!
Sean
Old May 10th 15, 02:45 AM posted to rec.aviation.soaring
Sean Fidler
Ink screens are great but lack smartphone data connectivity. I just want one device. Also color screens are rapidly improving in brightness specs. Especially the phablets (large ones).
Here are some quotes about the Note 4. It is widely considered to be the brightest and highest contrast of the new generation of OLED displays. They are exceptionally displays and so bright that they begin to hurt my eyes at times in less that bright light. I also have an iPhone 6 plus and it is considerably less bring that the note 4.
Link to article on Note 4 brightness: http://www.displaymate.com/Galaxy_Note4_ShootOut_1.htm
QUOTE: As a result of its high Brightness and low Reflectance, the Galaxy Note 4 has a Contrast Rating for High Ambient Light that ranges from 71 to 93, among the highest that we have ever measured.
More importantly, on the Galaxy Note 4 the Maximum Brightness can go much higher when Automatic Brightness is turned On, so that users can't permanently park the Manual Brightness slider to very high values, which would run down the battery quickly. High screen Brightness is only needed for High Ambient Light, so turning Automatic Brightness On will provide better high ambient light screen visibility and also longer battery running time.
When Automatic Brightness is turned On, the Galaxy Note 4 reaches an impressive 750 cd/m2 in High Ambient Light, where high Brightness is really needed - it is the brightest mobile display that we have ever tested. As a result of its high Brightness and low Reflectance, the Galaxy Note 4 has a Contrast Rating for High Ambient Light that ranges from 100 to156, the highest that we have ever measured for any mobile display. See the Brightness and Contrast, the High Ambient Light and the Screen Reflections sections for measurements and details."
Old May 10th 15, 02:59 AM posted to rec.aviation.soaring
Sean Fidler
bought 2 kinds listed on the XC Soar forum. Sparkfun was back-ordered any Android IOIO on that list should work well. It's a simple matter of mapping out the pins carefully.
I may start a little business making these. I have a very bright neighbors kid who wants a summer job!
I have used Luke's IOIO (Gen 1) in my Lak17 with a V7 vario and a Dell Streak. It was great. This setup should be far better than that was and I'll have full Verizon data (when not flying contests).
I'll post a video once I get it tested.
Old May 10th 15, 12:39 PM posted to rec.aviation.soaring
waremark
Thanks for replying. I think some of that is a bit like saying the Porsche 911 is unchanged in 50 years. I always use fingers not stylus on SYM without difficulty, find zoom and pan easy, and by the way Oudie now has connectivity using bluetooth via a phone. The SYM UI works really well for frequent tasks like task entry which is slicker than XCS. Each to their own.
iPhone 6+ or Galaxy Note 4? Duster Soaring 22 March 28th 17 12:23 AM
XCSoar and Top Hat issues running on Samsung Galaxy Tab 3 Gary Adams Soaring 4 July 11th 13 02:55 PM
C-5 Galaxy approaches WPAFB - C-5 Galaxy WPAFB final apch 4-17-07.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 April 18th 07 02:03 PM
C-5 Galaxy-getting in some flight time - C-5 Galaxy lft bank Dayton,OH 12-14-06.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 December 17th 06 03:41 PM
C-5 Galaxy-getting in some flight time - C-5 Galaxy rt bank Dayton,OH 12-14-06.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 0 December 17th 06 03:41 PM
