ASH-25 flutter
Old June 28th 15, 10:05 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by View Post
You've got to be kidding.
It is done by pulling in and out of landing flap enough to flex the wing tips up and down as the mixer moves the ailerons between positive and negative settings
Old June 28th 15, 02:18 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default ASH-25 flutter
On Saturday, June 27, 2015 at 7:07:58 AM UTC-7, JJ Sinclair wrote:
Time for another JJ story. We were finishing at Ephrata at 50 feet and 140 knots in our ASH-25 (with 2 meter wing extensions). As I crossed the finish line, I pulled up and rolled left,. At about 45 degree left bank, I applied right stick to stop the left roll............IT KEPT ROLLING LEFT................I then applied full right stick and rudder and the left roll stopped, but by then we were in a 75 degree left turn. The nose was up, so as airspeed slowed, the ship slowly responder to right stick commands.
After landing, I talked to the guy running the finish gate who was looking right down our wing as we flew through the gate...........He said it was the scariest thing he had ever seen! The wing tip leading edge, twisted down and doug-in, resulting in the un-commanded left turn, the rest of the wing looked like a sign wave. The wing extension had been somewhat blessed by Schleicher who had us install some 12# of lead in the outboard leading edge.. I believe it was to prevent flutter, but probably aided the twist problem.. Any aerodynamic experts explain why the lead was placed in the leading edge? Didn't it help twist the wing leading edge down?
Not too long after that, I sold the ship and retired to the peace and tranquility of the finish cylinder in sports class.
JJ
Happened to my Dad doing Max Q pull-ups while flight testing an F-86. The aileron acted like a trim tab for the entire wing. Not fun at transonic speeds.
I don't have a precise answer for the lead in the leading edge. Aeroelastics are complex, but presumably they want the leading edge to twist downward under loading so that there is a restoring force from whatever input perturbs the wing. Make sense that this could increase the resonant frequency and delay the onset speed for flutter and/or add some damping effect, but obviously it had a second consequence for you.
9B
Old June 28th 15, 07:26 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
ROLLING LEFT...............I then applied full right stick and rudder
lead in the outboard leading edge. I believe it was to prevent flutter,
but probably aided the twist problem. Any aerodynamic experts explain
JJ
transonic speeds.
It also helps delay flutter onset if the wing CG is in front of the
torsional axis. Adding lead in the LE or putting weights in front of the
LE on stingers are both ways of moving the wing's CG forward. I heard
that years ago from a fellow who worked at the Royal Aircraft
Establishment at Farnborough and have seen the stingers used to sort out
flutter problems on models.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 28th 15, 09:39 PM
Senior Member
JJ
9B
I would agree with your assesment of the reasons for the lead. As seen with the Nimbus 4T/M when being modified to 850 kg MAUW, it has among other things lead added to the leading edge out towards the tip as noted in the following; http://www.schempp-hirth.com/fileadm...68-10-3490.pdf.
Colin
High altitude flutter - Vne bildan Soaring 58 January 8th 09 08:04 PM
Question - rudder flutter ? Bravo Two Zero Piloting 47 December 27th 07 01:31 PM
Can Washout Cause Flutter?? DonMorrisey Home Built 12 January 19th 07 02:32 AM
Counterweighting to prevent flutter [email protected] Home Built 11 June 10th 05 03:51 AM
Tail flutter! I Can Computer Services Home Built 3 November 24th 03 12:56 AM
