ClearNav Instruments - Cambridge Repair Service - July
Old June 28th 15, 01:06 PM posted to rec.aviation.soaring
KiloKilo[_2_]
Default ClearNav Instruments - Cambridge Repair Service - July
Just a quick expansion on the July support suspension.
Cambridge Repair Service is suspended for the month of July as Gary Kammerer and his bride will be in Indonesia on their honeymoon - and visiting with the bride's parents.
Please make arrangements (call Gary) post August 1st for any Cambridge repair needs.
Congratulations, Gary !
http://clearnav.net/index.html
Old June 28th 15, 10:08 PM posted to rec.aviation.soaring
KiloKilo[_2_]
My apologies ... I have apparently attempted to get Gary married off without the benefit of clergy.
Gary will be vacationing in Indonesia and visiting the extended family of his fiancée - but a traditional Indonesian (or even American) marriage is not in his immediate plans.
Again my apologies to all ...
KK
Old July 4th 15, 07:43 PM posted to rec.aviation.soaring
Unfortunately my clearnav picked this weekend to lock up with a blank dark screen. Is anybody around that knows this unit?
Roy
Old July 4th 15, 08:46 PM posted to rec.aviation.soaring
Roy
Yep- dead processor.
UH
Old July 4th 15, 09:51 PM posted to rec.aviation.soaring
Roy
UH
Gee, that sounds expensive . . .
Roy
Old July 4th 15, 10:11 PM posted to rec.aviation.soaring
Roy
UH
Roy
I just bit the bullet and did the CNII upgrade since I had been thinking about it anyway.
UH
Old July 4th 15, 10:47 PM posted to rec.aviation.soaring
Roy
UH
Roy
UH
Does it use the same stick controller and fit the same panel mount? If so, I may do the same.
ROY
Old July 4th 15, 11:45 PM posted to rec.aviation.soaring
6X
yes. no change to controller or mounting dimensions. Enhanced processor speed makes a big difference when changing screens or making selections.
Old July 5th 15, 12:41 AM posted to rec.aviation.soaring
Roy
UH
Roy
UH
ROY
"Speed is money, how fast do you want to go????....!!!!".
Updates on ANY "PC based system" are normal. Some are "bug fixes", some are "Enhancements"...... You won't know until the "full update"..... meaning, if you do some updates WITHOUT doing the updated config file, "You're screwed".......
Cambridge 302 versus new ClearNav vario? Paul Villinski Soaring 6 January 7th 15 07:05 PM
Big News from Cambridge and ClearNav Paul Remde Soaring 4 January 30th 14 10:49 PM
ClearNav Instruments Discussion Board Evan Ludeman[_4_] Soaring 2 October 22nd 12 02:54 AM
ClearNav Announces OLC Solution for Cambridge 10/20/25 Flight Recorders Evan Ludeman[_4_] Soaring 5 September 24th 12 05:03 AM
ClearNav Instruments Variometer Paul Remde Soaring 0 December 20th 10 04:45 PM
