On 7/18/2015 8:40 PM, son_of_flubber wrote:
http://www.ntsb.gov/_layouts/ntsb.av...15FA259A&rpt=p To me, this is the crucial passage: "At 1100:49, the radar target of the F-16 was located 1/2 nautical mile northeast of the Cessna, at an indicated altitude of 1,500 feet, and was on an approximate track of 215 degrees. At that time, the Cessna reported an indicated altitude of 1,400 feet, and was established on an approximate track of 110 degrees. At 1100:52 the controller advised the F-16 pilot, "traffic passing below you 1,400 feet." " I find transponder-reported altitudes to be pretty notoriously inaccurate in general. So it seems to me that these two planes indicating only 100 feet apart (but only reporting their altitudes in 100 feet increments) should have been considered at the SAME altitude. With my PCAS, I consider +/- 400 to be the same altitude. |
I was a bit stunned by the apparent lackadaisical behavior on the part
of both the F-16 pilot and the controller. Advice to turn should be acted on immediately in a conflict situation. From the writeup it seemed that neither the pilot nor the controller showed any concern about such a close encounter. Of course that could simply be that the printed word can't convey stress or tone in a voice. Also notable is the fact that, had the F-16 pilot /_not_/ turned when he did or /_had_/ turned when instructed, the collision would likely not have occurred. Vaughn, I agree with you on the PCAS altitude. My last conflict was noted as -300 ft and, when I spotted the aircraft, it was about 100 ft above my altitude. On 7/19/2015 8:52 AM, Vaughn wrote: On 7/18/2015 8:40 PM, son_of_flubber wrote: http://www.ntsb.gov/_layouts/ntsb.av...15FA259A&rpt=p To me, this is the crucial passage: "At 1100:49, the radar target of the F-16 was located 1/2 nautical mile northeast of the Cessna, at an indicated altitude of 1,500 feet, and was on an approximate track of 215 degrees. At that time, the Cessna reported an indicated altitude of 1,400 feet, and was established on an approximate track of 110 degrees. At 1100:52 the controller advised the F-16 pilot, "traffic passing below you 1,400 feet." " I find transponder-reported altitudes to be pretty notoriously inaccurate in general. So it seems to me that these two planes indicating only 100 feet apart (but only reporting their altitudes in 100 feet increments) should have been considered at the SAME altitude. With my PCAS, I consider +/- 400 to be the same altitude. -- Dan Marotta |
On Sunday, July 19, 2015 at 10:33:58 AM UTC-5, Dan Marotta wrote:
"At 1100:49, the radar target of the F-16 was located 1/2 nautical mile northeast of the Cessna, at an indicated altitude of 1,500 feet, and was on an approximate track of 215 degrees. At that time, the Cessna reported an indicated altitude of 1,400 feet, and was established on an approximate track of 110 degrees. At 1100:52 the controller advised the F-16 pilot, "traffic passing below you 1,400 feet." " So, the Cessna was pretty close to the beam, and therefore may not have shown up on the F-16s radar. It almost sounds like both the controller and the Viper driver expected the other to take the appropriate action - neither took full responsibility for preventing the possible collision, expecting the other to do it! So much for a transponder ALONE being the solution to midairs... And until installing ADS-B Out in a certified airplane is a LOT cheaper, what are the chances that that Cessna owner would have bothered? Would ADS-B in have provided timely warning to the Cessna of the approach of the F-16? As I understand it, since neither the Cessna or the F-16 had ADS-B out, the Cessna would not have received any traffic info from the ADS-B ground stations. Thanks, FAA, for this idiotic implementation - withholding traffic data as an incentive to equip with ADS-B out! Dual band ADS-B receivers SHOULD receive both weather AND all traffic! That would probably guarantee that just about everything flying would at least get traffic info! Kirk 66 |
A note about transponder altitude inaccuracy. I also noticed significant inaccuracy when I used the Zaon MRX but once I switched to PowerFlarm I found mode C reported altitudes much more accurate, so I suspect the significant inaccuracy that Dan noted is due to MRX error, not necessarily transponder error.
Ramy |
Ramy wrote:
A note about transponder altitude inaccuracy. I also noticed significant inaccuracy when I used the Zaon MRX but once I switched to PowerFlarm I found mode C reported altitudes much more accurate, so I suspect the significant inaccuracy that Dan noted is due to MRX error, not necessarily transponder error. Ramy You may get larger MRX errors if the glider does not have a local transponder (that is being interrogated and seen by the MRX)...if it does the MRX will use the transponder's transmitted altitude instead of it's internal pressure sensor--which can be affected by cockpit ventilation. With the number of issues that I believe Ramy had with his MRX maybe it was not properly identifying the local transponder. |
Controller appears to have given an abundance of information to the F-16 pilot. The F-16 pilot, in one of the most highly maneuverable aircraft ever made, did virtually nothing with it to provide margin. huh.
That could be the case, however... The MRX PCAS uses an internal
barometric sensor in the absence of an own ship's transponder. I've observed its startup and noted that it initially reports a transponder code of 3707 or some other nonsense, after my transponder is turned on and begun replying to interrogations, the PCAS with show a TX code of 1200 and, finally, 1202 to which my Trig is set to reply. I don't know what the required Mode C/S accuracy is below FL180, but if it's +/- 200 feet, then you could occasionally see a 400' error. That or my PCAS lost lock with my Trig, or it's just sloppy. Next time I see an aircraft on which I've received an alert, I'll check the PCAS for the transponder code it's using for its calculations. If I gain some insight, I'll report it here. On 7/19/2015 11:43 AM, Ramy wrote: A note about transponder altitude inaccuracy. I also noticed significant inaccuracy when I used the Zaon MRX but once I switched to PowerFlarm I found mode C reported altitudes much more accurate, so I suspect the significant inaccuracy that Dan noted is due to MRX error, not necessarily transponder error. Ramy -- Dan Marotta |
On Monday, July 20, 2015 at 10:39:21 AM UTC-5, wrote:
Controller appears to have given an abundance of information to the F-16 pilot. The F-16 pilot, in one of the most highly maneuverable aircraft ever made, did virtually nothing with it to provide margin. huh. And if you have two planes, one heading 110 degrees, one heading 260 degrees, the plane heading 110 degrees is reported to be at the 12 o'clock position of the plane heading 260 degrees, why would you tell the plane heading 260 degrees to "Turn left to heading 180 degrees"? This seems to me to be continuing to aim the 260 degree heading plane at the 110 degree heading plane. It seems like it would have made more sense to turn the F-16 to the right. And, it could also be read that there would have been no conflict at all had the F-16 pilot not begun a left turn. By my read, he had changed his heading approximately 45 degrees in the direction directed by the controller when the collision occurred. So, if the F-16 pilot had done nothing, there would not have been a collision? Is this how good our ATC radar is? Or was there a controller error that helped facilitate the collision? Too much Monday Morning Quarterbacking. |
hey I'm not the one suggesting the controller should have said go right instead of left. But I'll admit its a fair point. Bottom line, that first call: traffic, 12 o'clock 2 miles opposite direction - ..close in altitude, is good info and more than a lot of us get when we end up finding ourselves close to another aircraft. It's a shame that was not enough to prevent the accident. |
| Thread Tools | |
| Display Modes | |
| NTSB crash report, autopsy report- Stevie Ray Vaughan | Mark. | Piloting | 5 | March 22nd 20 11:17 PM |
| Preliminary NTSB Report on the Oshkosh P51 Crash Released | Dudley Henriques[_2_] | Piloting | 58 | August 6th 07 07:58 PM |
| Preliminary NTSB report on Walton accident | ChuckSlusarczyk | Home Built | 11 | July 12th 05 05:23 PM |
| NTSB Preliminary report on HPN crash | Peter R. | Instrument Flight Rules | 83 | May 10th 05 09:37 PM |
| ntsb report | Peter Clark | Instrument Flight Rules | 38 | April 1st 05 04:18 AM |
