has anyone try to use this in their glider?
http://www.sportys.com/pilotshop/ipa...for-ipad.html/ --bob |
On Friday, July 31, 2015 at 12:59:04 PM UTC-7, Bob Pasker wrote:
has anyone try to use this in their glider? http://www.sportys.com/pilotshop/ipa...for-ipad.html/ --bob What are you expecting it would do for you? It won't "see" any Flarm equipped gliders/tow planes. It won't reliably "see" any transponder equipped aircraft (unless *your* glider has ADS-B Out *and* you are in ADS-B ground station TIS-B coverage... which requires you be within ATC SSR coverage) It will "see" 1090ES and UAT Out equipped aircraft... which effectively means no gliders and few GA aircraft today. .... if you have a compatible display and you'll likely get a boat load of annoying traffic threat warnings in typical glider-glider scenarios, if other gliders are seen at all. |
One of our club members flies with the 1st Gen Stratus and iPad mini. It works to see the airliners descending into the local class B.
It's a carry over from his powered aircraft. And if he's close enough for the airliner to be an issue, he's within the hockey puck airspace to piggyback on the TIS-B data being broadcast to the airliner. So the airliner sees the glider 1202 code. BillT |
At 02:07 01 August 2015, Bill T wrote:
One of our club members flies with the 1st Gen Stratus and iPad mini. It works to see the airliners descending into the local class B. It's a carry over from his powered aircraft. And if he's close enough for the airliner to be an issue, he's within the hockey puck airspace to piggyback on the TIS-B data being broadcast to the airliner. So the airliner sees the glider 1202 code. BillT Bill, unfortunately, no airliner can see any code of a transponder. Airliner TCAS only shows two different symbols. A solid white diamond or a hollow white diamond identification on its TCAS when there is no threat. The solid white diamond display identifies that it has an altitude encoder with its transponder, the hollow white diamond just says there is a transponder out there with no altitude encoder or the encoder function is not operating. The solid white diamond will give altitude above or below the airliner. The Airliner TCAS will react to a solid white diamond(ie a transponder with altitude encoder) The white diamond will change to blue if it is being interrogated on a transponder code other then VFR. The diamond will change to yellow or red if the TCAS believes it will be in the projected path of the airliner. It will not show that it is a 1202 glider! Doug |
On Friday, July 31, 2015 at 7:07:45 PM UTC-7, Bill T wrote:
And if he's close enough for the airliner to be an issue, he's within the hockey puck airspace to piggyback on the TIS-B data being broadcast to the airliner. So the airliner sees the glider 1202 code. BillT An airliner likely has TCAS and will interrogate the glider's transponder directly. *If* the Airliner has TIS-B capable equipment then it will receive position reports for nearby transponder equipped aircraft that are in SSR coverage.... the target aircraft do not need to be in any hockey puck". it works the other way... its TIS-B or ADS-R receiving aircraft that need to be within a "hockey puck" to see other threats... hockey pucks created by their own ADS-B Out devices. |
On 7/31/2015 6:09 PM, Darryl Ramm wrote:
On Friday, July 31, 2015 at 12:59:04 PM UTC-7, Bob Pasker wrote: has anyone try to use this in their glider? http://www.sportys.com/pilotshop/ipa...for-ipad.html/ --bob What are you expecting it would do for you? It won't "see" any Flarm equipped gliders/tow planes. It won't reliably "see" any transponder equipped aircraft (unless *your* glider has ADS-B Out *and* you are in ADS-B ground station TIS-B coverage... which requires you be within ATC SSR coverage) It will "see" 1090ES and UAT Out equipped aircraft... which effectively means no gliders and few GA aircraft today. ... if you have a compatible display and you'll likely get a boat load of annoying traffic threat warnings in typical glider-glider scenarios, if other gliders are seen at all. What Darryl said, plus buying Stratus locks you (and your wallet) into an unholy 3-way Foreflight-Apple-Stratus alliance. Unless there has been a recent change, Stratus only supports the Foreflight EFB. Foreflight only works on Apple and Stratus hardware. See the problem? I have flown with Foreflight and concede that it's excellent. But Foreflight also has lots of excellent EFB competition barking at its heals! Going forward, with Foreflight's strategy of "locking in" their customers with hardware, they will have less incentive than the others to compete on the basis of price, features, customer service and innovation. There are several ads-b receivers out there with comparable features to the Stratus that cost less while giving you the option to choose between multiple EFB apps and hardware platforms. Vaughn |
The airliner with ADS-B IN will get the traffic data rebroadcast from ATC and the 1202 traffic will show on his ADSB display.
I did not say that he would be able to discern the code, just that the ADSB-R would show the traffic. BillT |
On Saturday, August 1, 2015 at 9:51:11 PM UTC-7, Bill T wrote:
The airliner with ADS-B IN will get the traffic data rebroadcast from ATC and the 1202 traffic will show on his ADSB display. I did not say that he would be able to discern the code, just that the ADSB-R would show the traffic. BillT You are assuming airliner CDTI equipment will display TIS-B traffic, and that CDTI has any capability of showing Mode A codes. Do you know that for sure? With what exact systems? You can't just assume what would be nice is actually how things work, especially in a highly regulated, complex and horrendously expensive transport category avionics, with TCAS/CDTI systems that have to work all over the world. Again, airliners are equipped with TCAS which really provides them with all the transponder based collision avoidance they need, and TCAS CDTI will not show Mode A codes. The latest versions of TCAS II utilize hybrid surveillance where the TCAS systems receives 1090ES Out from nearby aircraft and uses that to augment position information/avoid excessive transponder interrogations/provide long range traffic display. TCAS does not use that data directly for issuing a TA or RA. AFAIK TCAS II hybrid surveillance relies on 1090ES Out from the target aircraft, it does not utilize UAT, ADS-R or TIS-B for this. If anybody knows different it would be great to know what exact system that is. |
At 05:49 02 August 2015, Darryl Ramm wrote:
On Saturday, August 1, 2015 at 9:51:11 PM UTC-7, Bill T wrote: The airliner with ADS-B IN will get the traffic data rebroadcast from ATC= and the 1202 traffic will show on his ADSB display. I did not say that he would be able to discern the code, just that the AD= SB-R would show the traffic. =20 BillT You are assuming airliner CDTI equipment will display TIS-B traffic, and th= at CDTI has any capability of showing Mode A codes. Do you know that for su= re? With what exact systems? You can't just assume what would be nice is ac= tually how things work, especially in a highly regulated, complex and horre= ndously expensive transport category avionics, with TCAS/CDTI systems that = have to work all over the world. Again, airliners are equipped with TCAS w= hich really provides them with all the transponder based collision avoidanc= e they need, and TCAS CDTI will not show Mode A codes. The latest versions of TCAS II utilize hybrid surveillance where the TCAS s= ystems receives 1090ES Out from nearby aircraft and uses that to augment po= sition information/avoid excessive transponder interrogations/provide long = range traffic display. TCAS does not use that data directly for issuing a T= A or RA. AFAIK TCAS II hybrid surveillance relies on 1090ES Out from the ta= rget aircraft, it does not utilize UAT, ADS-R or TIS-B for this. If anybody= knows different it would be great to know what exact system that is. Thank You! |
Stratus / Foreflight ADSB | 6X | Soaring | 5 | December 17th 13 09:34 AM |
Telex 4105 vs Stratus 50 | Robert Barker | Piloting | 8 | February 26th 06 02:23 AM |
Telex 4105 vs Stratus | Robert Barker | Home Built | 0 | February 25th 06 01:34 AM |
Telex Stratus vs. 4105 | Robert Barker | Products | 1 | February 22nd 06 09:24 PM |
Telex Stratus 50-D headset? | Roy Smith | General Aviation | 4 | January 13th 04 01:44 PM |
