Iglide
Old August 1st 15, 06:10 AM posted to rec.aviation.soaring
chris johnson
Default Iglide
I am completely at a loss when it comes to computers. I bought Iglide downloaded maps etc. and was ready to go in 5 stress free minutes. I have not flown with it yet so I do not know if I will need an external gps. So far so good.
Old August 1st 15, 11:32 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Iglide
Take it outside, wait until its got a GPS fix, and walk in a straight
line along a footpath. Within 10-20m Iglide should work out which way
you're going and orient the map accordingly. Turn round and walk back:
the map should rotate 180 degrees.
That's my usual test for a new install of XCDSoar or LK8000 on any gadget
with a built-in GPS, so it should also work with Iglide.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 1st 15, 03:22 PM posted to rec.aviation.soaring
jfitch
Default Iglide
You will not need an external GPS. If you have an iPhone 6 or 6+, it will also display pressure altitude, thermal lift dots, etc.
I was having trouble keeping my iPhone/iGlide connected to my Air Avionics variometer, when this loses the connection after a few minutes it defaults to internal sensors/stand alone operation. It works surprisingly well that way. The only thing I missed was the instantaneous wind display, and the lift dots are slightly delayed and filtered with a slow time constant (the iPhone does this to its pressure sensor).
iGlide Ben S Soaring 31 February 16th 20 04:14 AM
iPhone 6 Plus and iGlide jfitch Soaring 39 May 20th 15 01:07 AM
iGlide Mike Rinaldi Soaring 4 April 28th 15 12:48 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
