My airspeed indicator seems to have devolved a leak and pitot pressure is causing readings on the old uncompensated winter vario. When I blow on the pitot tube and disconnect the static line of the airspeed indictor you can hear air moving through the static line from the airspeed indicator.
Has anyone head of this before? I'm guessing replacing the airspeed indicator is the solution. Feedback would be great. Nick |
Yes. I had an ASI fail. Very prompt service from Winter.
John Cochrane |
The diaphragm has failed, likely due to corrosion.
No owner fix applicable. UH |
Just sent my Fahrtmesser back to Winter. Very quick turnaround and reasonably painless. The instructions are on their Website. That's assuming of course you have a Winter ASI (which is in like 90% of the glass fleet).
P3 |
How fast was the turn around from winter?
Does your glider perhaps have an old fashioned capsule total energy
compensation system on the mechanical vario? A leak in the diaphragm in that would account for the symptoms you describe. At 00:17 02 August 2015, wrote: My airspeed indicator seems to have devolved a leak and pitot pressure is = causing readings on the old uncompensated winter vario. When I blow on the = pitot tube and disconnect the static line of the airspeed indictor you can = hear air moving through the static line from the airspeed indicator. Has anyone head of this before?=20 I'm guessing replacing the airspeed indicator is the solution.=20 Feedback would be great.=20 Nick |
On Saturday, August 1, 2015 at 6:45:36 PM UTC-7, wrote:
The diaphragm has failed, likely due to corrosion. No owner fix applicable. UH Not legal of course, but a friend of a friend once repaired one, figured not much to lose, took it apart, bellows had a crack- cleaned, a little solder on the split. Worked fine. |
What glider are we talking about? I have an old (1revolution) ASI, with faded speed restrictions for LS 3a. I have checked it against my master ASI and it is working properly............How about $100 bucks?
JJ |
| Looking for a used 57 mm airspeed indicator | Scott Alexander[_2_] | Soaring | 0 | October 13th 12 08:28 PM |
| Airspeed Indicator Strangeness | Frank[_1_] | Soaring | 6 | June 9th 08 02:24 PM |
| verifying airspeed indicator | Heino & Deanne Weisberg | Home Built | 11 | October 22nd 05 08:36 PM |
| Need glider airspeed indicator | [email protected] | Soaring | 1 | June 21st 05 10:57 PM |
| Inaccurate airspeed indicator | Wyatt Emmerich | Instrument Flight Rules | 20 | April 20th 04 01:08 AM |
