13.5 Meter World Championships
Old August 3rd 15, 07:55 PM posted to rec.aviation.soaring
Sean Fidler
Default 13.5 Meter World Championships
Go Tony! Go Francios!!!
Results after 2nd contest day:
http://www.soaringspot.com/en_gb/135...15-08-03/total
  #32
Old August 4th 15, 07:59 PM posted to rec.aviation.soaring
JS
What's an "incorrect landing lane" warning?
  #33
Old August 4th 15, 08:49 PM posted to rec.aviation.soaring
Landing on a surface other than "recommended"? Frankly (didn't look at the scoresheet), if nobody was hurt and nothing broken, "I declared an emergency (maybe only in my mind as PIC), thus I can break any rule out there provided I have a good reason for breaking the rule/rules in the follow-up discussion.....".
  #34
Old August 4th 15, 09:11 PM posted to rec.aviation.soaring
Dan Daly[_2_]
On Tuesday, August 4, 2015 at 3:49:29 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
From Local Procedures:
7.8.1 Landing procedures
The landing frequency is the same as the finish frequency - 122.500 MHz (call sign POCIUNAI INFO). Sailplanes landing straight in shall, during landing, proceed according to the instruction received from finish officials on the airport frequency. The aim is that the first finishing sailplanes shall normally continue as long as possible landing to allow other sailplanes to land safely behind and to use as much runway as possible. Any sudden change in direction of flight or rolling during the landing procedure is strictly prohibited. Violations will be penalized. Landing instructions for sailplanes landing from the runway circuit will be specified at the briefing.
See Appendix B
Appendix B has 14 illustrations on how they want folks to land/take-off depending on runway in use...
http://www.wgc2015.lt/documents/
I assume either changing direction or rolling, or landing first and not taking it to the end as the procedures say.
2D
  #35
Old August 5th 15, 05:08 AM posted to rec.aviation.soaring
Tony[_5_]
The field is split into halves. Yesterday the right half was for direct landings and the left for speed finishes and patterns. I'm guessing François drifted over the imaginary centerline on his rollout.
  #36
Old August 14th 15, 07:57 AM posted to rec.aviation.soaring
Tony[_5_]
Contest is going alright. We'll end up with 12/14 flying days. Hope you've all been following along!
Sean would be happy here...so far 9/10 tasks have been Racing Tasks. We had an area task on a day where thunderstorms were expected.
  #37
Old August 14th 15, 11:46 PM posted to rec.aviation.soaring
Nice dedication of our team's flights in memory or Rick.
Well done guys
UH
  #38
Old August 15th 15, 03:15 AM posted to rec.aviation.soaring
Sean Fidler
:-). I have been keeping quit but am also glad that you mentioned the great tasking, befitting a world championships.
Bravo to the CD. I think its absolutely fantastic to have a 13.5 contest with all racing tasks. This would of course be near blasphemy in the US right now unfortunately, We definitely do not call enough...but this year has been a distinct improvement. I am hopefull we continue to add these pure, clean tasks to our contests whenever possible.
I think the Diana 2 and Lak mini have an edge (as they should as they are both newer designs). What was your impression of them vs. your gliders? The GP 14 will probably surpass them. This leapfrogging in performance is a bit unfortunate for the 13.5 class right now. I hope things stabilize.
I think you and Francios have done an incredible job. Congratulations!
  #39
Old August 15th 15, 07:47 AM posted to rec.aviation.soaring
Tony[_5_]
Hank-It was our pleasure and I was glad that we had a great team flight. We've been flying pretty well together and its been a lot of fun.
The weather has been really good and appropriate for racing tasks here. Only one day where thunderstorms were a remote possibility and we got an area task that day.
The racing tasks have forced us to cross different terrain, shift gears, and do all that fun stuff you would expect at a world championship. It's been a fun time.
Day 12, the final day, coming right up!
  #40
Old August 15th 15, 04:00 PM posted to rec.aviation.soaring
Sean Fidler
Yes. Soaring changes when you can't fly wherever you want all/most of the time. Racing tasks definitely can be more difficult, but for those who learn to adapt, far greater rewards!
World Gliding Championships. R. Suppards Soaring 0 July 6th 14 11:03 AM
Women’s World Gliding Championships RRK Soaring 2 June 19th 11 01:17 PM
5th Junior World Gliding Championships [email protected] Soaring 0 July 28th 07 11:43 AM
World championships in Sweden CD Soaring 0 June 5th 06 11:03 PM
