SSA responds to ANPRM
Old August 19th 15, 06:06 AM posted to rec.aviation.soaring
Ramy[_2_]
Default SSA responds to ANPRM
On Tuesday, August 18, 2015 at 8:45:12 PM UTC-7, George Haeh wrote:
I have been slogging through the some
220 responses and came across a
response from the NTSB:
http://www.regulations.gov/contentStrea
mer?documentId=FAA-2015-2147-
0137&attachmentNumber=1&disposition
=attachment&contentType=pdf
"our main concern was to ensure that
gliders are detectable by an aircraft
equipped with a traffic alert and collision
avoidance system (TCAS)"
Gliders are already kept well away from
air carriers by Class B and C.
That makes the primary beneficiaries of
the ANPRM private jet owners able to
afford TCAS - $30K to $200K before
installation.
As long as they're transmitting ADS-B,
anybody with PowerFLARM knows
exactly where they are from several miles
away and can avoid.
This can not be further from the truth! Is NTSB really that clueless? Are they assuming that air carriers are immediately in class A when outside of class B/C, or do they assume that gliders only fly in patterns around small airports outside class B/C? Anyone who is flying in Reno area, Las Vegas area, in the Bay Area and any other soaring area within 50 miles of a major airport knows that we sharing the same airspace with airliners, including inside Mode C veil!
Ramy
  #62
Old August 19th 15, 06:45 AM posted to rec.aviation.soaring
jfitch
installation.
away and can avoid.
At least some air carriers are not transmitting ADS-B as of this writing. Southwest for example - none of their jets flying into and out of Reno show up on PowerFlarm. Biz jets seem to have a higher install rate than airlines.
  #63
Old August 19th 15, 06:50 AM posted to rec.aviation.soaring
jfitch
installation.
away and can avoid.
Ramy
Ramy - the NTSB only said the part in the quotes, the rest of it was the opinion (or mistake) of the poster.
  #64
Old August 19th 15, 08:35 AM posted to rec.aviation.soaring
Ramy[_2_]
Oops, don't know how I missed the end of the quote. It didn't make sense to me that the NTSB will be so clueless. I am amazed that some glider pilots believe we
  #65
Old August 19th 15, 02:07 PM posted to rec.aviation.soaring
David Kinsell[_2_]
On Wed, 19 Aug 2015 03:32:29 +0000, George Haeh wrote:
I have been slogging through the some 220 responses and came across a
http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147-
0137&attachmentNumber=1&disposition =attachment&contentType=pdf
"our main concern was to ensure that gliders are detectable by an
aircraft equipped with a traffic alert and collision avoidance system
(TCAS)"
Gliders are already kept well away from air carriers by Class B and C.
That makes the primary beneficiaries of the ANPRM private jet owners
able to afford TCAS - $30K to $200K before installation.
As long as they're transmitting ADS-B, anybody with PowerFLARM knows
exactly where they are from several miles away and can avoid.
You took that one sentence well out of context. With the advent of ADS-
B, the NTSB now believes gliders should also lose their ADS-B exemption.
ADS-B In capability is a whole lot cheaper than TCAS, and will be much
more widely deployed.
As I keep saying, this ANPRM isn't about transponders, it's about
transponders and ADS-B, as should be obvious from the survey questions
they asked. I believe FAA has decided to suck gliders into NextGen, and
are using the (extremely late) letters from Reid and Amodei as
justification. I'm generally in favor of that in principle, but hope we
can get regulations that make it more practical given the constraints of
gliders.
-Dave
  #66
Old August 19th 15, 02:42 PM posted to rec.aviation.soaring
David Kinsell[_2_]
(TCAS)"
rate than airlines.
So SouthWest isn't using their transponders these days?? Hope you report
that to FAA.
  #67
Old August 19th 15, 02:56 PM posted to rec.aviation.soaring
Bruce Hoult
(TCAS)"
rate than airlines.
that to FAA.
They of course have transponders, but only the most recent models of 737 have ADS-B.
Southwest still have quite a lot of -300 and -500 models which I believe will never be fitted with ADS-B. They will be retired by 2020.
The -700 and -800 models will be retrofitted with ADS-B by 2020. Some may have come with it from the factory (-800s?).
  #68
Old August 19th 15, 04:33 PM posted to rec.aviation.soaring
On Tuesday, August 18, 2015 at 1:08:29 PM UTC-4, Sean Fidler wrote:
Shouldn't hang and paragliders also have ADSB? ;-)
If a toy helicopter needs too...
FAA?
And skydivers, birds, and especially mountains. People are always flying into that last one.
  #69
Old August 19th 15, 05:45 PM posted to rec.aviation.soaring
George Haeh
installation.
away and can avoid.
  #70
Old August 19th 15, 05:56 PM posted to rec.aviation.soaring
George Haeh
Here in Canada the air carriers are pretty
much on ADS-B already; so my PF sees
them. Aside from the odd towplane, my
PF has only alerted me to one
transponder target.
I can receive several ADS-B returns on a
single flight.
SSA's planned response to ANPRM Transponders, etc [email protected] Soaring 0 July 11th 15 05:01 AM
ANPRM - removal of transponder exception for gliders [email protected] Soaring 29 June 17th 15 11:00 PM
Sheriff Responds to AOPA Jp Stewart Soaring 27 January 29th 13 04:49 PM
USS Liberty Survivor Phil Tourney responds to Cindy McCain NOMOREWARS_FORISRAEL Naval Aviation 0 September 24th 11 11:22 AM
AS responds to the latest Ventus 2cxa KevinFinke Soaring 3 March 18th 09 03:45 AM
