Pawnee landing gear
Old August 31st 15, 01:17 PM posted to rec.aviation.soaring
soaring4fun
Default Pawnee landing gear
On Tuesday, August 25, 2015 at 4:15:08 AM UTC-4, Craig Lowrie wrote:
We have fitted cable restraining straps to our two Pawnees... They save
the plane and prop in most cases with this or a strut-end failure (of
which we have had a couple)..... Craig
Craig, what strength cable did you use and where did you find the drawings or photo o exactly where to run the cable? From crop dusters? Any help is appreciated. My Pawnee bolts sheared (actually broke) and I know of another Pawnee that also had the very same happen. This was years ago. We change the bolts now...often. I have always wanted to put the cable around the top of the gear, but never researched it, so thanks for rattling the chain. Jayne
Old August 6th 17, 05:45 PM posted to rec.aviation.soaring
August 2017. Do you have the tech drawing or any reference which quotes the safety cable dimensions? We'd sure appreciate any info on just how long each cable should be. We have photos of cables installed on Pawnees, but need accurate length info. We operate two PA-25 Pawnee 235 as glider tugs. Dick Parker. Edmonton Soaring Club. Many thanks.
landing gear retraction in sel Ron Rosenfeld Piloting 2 February 15th 08 08:40 PM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 05:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
gear up landing: "There are those who have, and..." Daniel L. Lieberman Piloting 26 January 29th 05 12:03 AM
Landing Gear Lou Parker Home Built 2 April 11th 04 04:08 AM
