Trying to find resources on tanker history
Old June 1st 04, 08:28 AM
Ian
"Keith Willshaw" wrote in message
"Ian" wrote in message
Is it still the case that the USN uses the trailing drogue (as the
RAF/RN
do), with the USAF using the tanker to steer the probe? If so, why the
different approaches?
The flying boom method has a higher transfer rate but probe
and drogue can be fitted to buddy tankers.
Keith
Maybe a bit simplistic but couldn't they equal the transfer rates by just
increasing the bore of the drogue feed pipe? It all ends up in the same fuel
system (on the refuelling aircraft) so it can't be a pressure constraint?
Old June 1st 04, 09:41 AM
Keith Willshaw
fuel
That means increasing the bore of a longer length of pipe
than on a flying boom. I suspect there are weight restraints
at work here.
Keith
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Old June 1st 04, 10:07 AM
Guy Alcala
fuel
at work here.
And size (hose takes up space, after all), and drag. More importantly, there are
limits on the size at the other end. While large a/c can carry around a large
diameter fixed probe with little effect on performance, fighters and attack a/c don't
have that option. So, for instance, on their Victor tankers the RAF used Mk. 20 wing
pods with smaller diameter hose/drogues (and lower flow rates) to refuel
fighter/attack a/c, and a centerline Mk. 17 HDU of greater diameter hose/drogue to
refuel bombers/transports (which have larger diameter probes than fighter/attack
aircraft, so can accept higher transfer rates, although still not as high as a boom).
A fighter just can't be carrying around such a massive piece of hardware all the time,
especially if it's fixed external (there wouldn't be enough room to house it
internally on a fighter, and no one seems to have tried a bomber-sized extendible
probe).
A boom receptacle, OTOH, is theoretically only limited in diameter by the fuel flow
rates that the a/c's internal fuel piping is designed to deal with; since the flow
rate in A/B is quite high, and since none of this is adding weight/drag outside the
airframe, transfer rates can be much higher with little/no weight penalty on the
receiver. The tanker is paying the weight/drag penalty of the boom, but it's a lot
larger and can afford it.
Guy
Old June 2nd 04, 03:17 AM
Henry J Cobb
And then you've got three pilots.
One pilot for each aircraft and then somebody in the back of the tanker
to fly the boom.
-HJC
Old June 2nd 04, 03:38 AM
Kevin Brooks
"Henry J Cobb" wrote in message
the fuel flow
since the flow
outside the
penalty on the
it's a lot
to fly the boom.
The boom operator is neither trained nor paid as a pilot, so your point
would be...?
Brooks
-HJC
Old June 2nd 04, 05:16 AM
Henry J Cobb
to fly the boom.
would be...?
"Fly the boom" is a common phrase in the USAF.
http://www.afmc.wpafb.af.mil/HQ-AFMC...eb/0226-03.htm
You need three people adjusting airfoils to make boom refueling work.
That's one more person than is needed for a probe and drogue refueling.
Heck, you could make an unmanned tanker for probe and drogue refueling.
-HJC
Old June 2nd 04, 06:00 AM
John Keeney
Guy Alcala wrote:
After that the USAF decided to go
over completely to the boom/receptacle method, as their tankers would
(presumably) always have airbases to operate from, just as their
fighters and
bombers would. The boom gives better transfer rates and seems to be
more
reliable and easier to tank from, but it does limit the types of a/c
that can
be tankers, and it requires a lot more money and work to convert.
Will the F-35B be the first USAF aircraft since then to be built with
just a probe?
Clearly USAF helicopters have been built with "just a probe".
Outside of the rotory wings I can't think of any USAF probe
refuelers during the last 30 some years.
Old June 2nd 04, 07:09 AM
Buzzer
On Wed, 2 Jun 2004 01:00:49 -0400, "John Keeney"
fighters and
more
that can
just a probe?
A-7D?
Old June 2nd 04, 07:55 AM
Henry J Cobb
How many helicopter capable tankers does the USAF have?
Or do they have to call in the Marines? ;-)
-HJC
Old June 2nd 04, 10:56 AM
Cub Driver
to fly the boom.
The boom handler is a pilot? Why?
There used to be a joke about flying up dead-end canyons: don't do it
unless you've learned how to fly a plane backwards. Presumably a boom
operator could do just that.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Enola Gay: Burnt flesh and other magnificent technological achievements me Military Aviation 146 January 15th 04 10:13 PM
EADS aims at USAF tanker market Matt Wiser Military Aviation 0 September 20th 03 05:54 PM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
