NavWorks ADS-600B ?
Old October 1st 15, 10:07 PM posted to rec.aviation.soaring
Bob Pasker
Default NavWorks ADS-600B ?
is anyone tracking the NabvWorks ADS-600B?
they claim to offer a single box that complies with the 2020 mandate for certified aircraft, starting at 1,999 + install. there an STC for lots of GA aircraft, but no gliders (yet).
http://www.navworx.com/ADS600BDescription.php
let the flame war begin!
--b
Old October 1st 15, 10:36 PM posted to rec.aviation.soaring
kirk.stant
--b
Well, you still need a transponder, encoder, display, etc. So not a "single box" solution for gliders or non-electrical system LSAs.
Kirk
66
Old October 1st 15, 11:59 PM posted to rec.aviation.soaring
--b
Kirk
66
Interesting to see that it has a Stealth mode.
UH
Old October 2nd 15, 12:39 AM posted to rec.aviation.soaring
Darryl Ramm
--b
I am not sure why this box deserves any mention on r.a.s. but it's been flogged to death here before.
UAT only not 1090ES. Not a transponder. Not compatible with TCAS/TCAD.
Not compatible in any way with PowerFLARM.
Requires an external traffic display.
High battery drain. And on and on and on....
Given the prevalence of PowerFLARM (with it's 1090ES-In capability) in the USA this UAT technology would be the very last thing any sensible glider owner should want to install in their glider.
In terms of compliance, lets wait and see what happens with transponder and ADS-B Out carriage requirement exemptions for gliders. If those exemptions are removed then I hope/expect TABS to be moved in to fill this space, and TABS would be a much more appropriate technology for gliders in the USA than UAT transceivers. TABS has the potential to help both as a way to deploy current 1090ES Out capable transponders (with lower-cost TABS Class B GPS sources) as well as TABS specific (Class A) devices.
Old October 2nd 15, 12:45 AM posted to rec.aviation.soaring
Darryl Ramm
--b
Kirk
66
UH
UAT-Out devices support optionally not broadcasting the aircraft's ICAO address. Which obviously only "works" if you are flying without a transponder or if you have a Mode-C transponder. Mode S transponders are required to transmit the ICAO address.
All that is a poor decision IMNSHO. But something AOPA and others wanted. And the FAA offered as an inducement for GA to adopt ADS-B out. That's back in the days where all the "FAA happy think" had GA on UAT and only the big boys on 1090ES. If AOPA had its head not in a dark space they would have insisted on a much simpler and much more likely to be usable single link Mode-S 1090ES based system.
Old October 2nd 15, 06:45 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Yup.
Nobody thought it all the way through and now we have an immensely complex rat's nest.
