DG1000T Solo 2350C Engine A.D.
Old October 8th 15, 04:41 PM posted to rec.aviation.soaring
NG
Default DG1000T Solo 2350C Engine A.D.
Chris. Apparently the Solo Engine problems are not just isolated to the DG1000T and Antares turbo. In the past the Duo Discus T which also incorporates the Solo engine and a variant propeller drive, also has had propeller hub cracking problems resulting in 2 separate FAA ADs. In 2007 AD 2006-25-14 called for daily pre-flight inspection of the propeller hub with a "10X magnifying glass" for cracks and mandatory return to the manufacturer if cracks were found. This was followed by another more recent AD in 2013, AD 2013-24-16, requiting inspection revisions for further issues with the same propeller hub, AD 2013-24-16. I contacted the U.S. dealer to try and find more about this history and possible similar issues with no reply.
I received a private notice from a party in the U.K. who stated that he had replaced his Duo T propeller hub no less than 3 times. In addition he states that a recent propeller departure in a Duo T resulted in entry into the fuselage with aileron linkage disruption which is currently being investigated by the U.K. authority.
So there you have it. More than 8 years of recurrent propeller hub and shaft failures, involving 5 airworthiness directives, spanning 3 different manufacturers, in addition to Solo the engine type certificate holder.
WTB solo 2350 engine [email protected] Soaring 1 May 27th 15 10:56 PM
Son's first solo! Morgans[_2_] Piloting 15 May 4th 09 06:04 PM
SOLO 2625-02 engine drawings Maciek Soaring 2 April 5th 07 01:15 PM
Solo 2350 Engine Overhaul Manual - Translation Requested Bob Gibbons Soaring 2 January 10th 04 08:45 AM
How NOT to solo... Greg Burkhart Piloting 3 December 16th 03 04:09 AM
