Dreaming of a BETTER PowerFLARM antenna
Old October 31st 15, 01:13 PM posted to rec.aviation.soaring
Default Dreaming of a BETTER PowerFLARM antenna
I hold the PowerFLARM supplied center fed vertical dipole antenna in the same likeness to Apple providing a 6V HD "brick" lantern battery to power a new Apple watch. IMO, the CFVDA is distracting, cumbersome, and most unsightly. Surprisingly, USA users have accepted them and happily butcher glare shields and let them distract forward view in order to place them where they can be effective.
Lets get them off the glareshield. Double E antenna engineers come out, come out, wherever you are and design/market something BETTER. How about a bottom fed "whisker" antenna mounted to both sides of the canopy rail. They would parallel just behind the canopy window vent and bend to follow the curvature of the canopy. They would be held by a snap-in clip fixed to the canopy rail so they could be removed for canopy cleaning. No bulky connectors at the antenna...hardwired with the only connector at the "brick" end. "Whisker" antenna wire would be as small gauge as possible.
My OCD is so bad I'd pay twice the price of the typical center fed vertical dipole antenna to have these. Please step up YO!
Old October 31st 15, 01:23 PM posted to rec.aviation.soaring
A step in the right direction. Antenna needs to be tuned for USA frequencies and the "whisker" needs to be a smaller gauge. The suction cup holder is "slick" but only one should be required at the base.
http://www.air-store.eu/epages/AIRSt...cts/1.0.0.0017
Old October 31st 15, 04:36 PM posted to rec.aviation.soaring
Ramy[_2_]
As a strong advocate of power flarm I can't agree more. Every time I see those stock dipole antennas on a top of a glare shield it disturbs me. Our forward visibility is already restricted and those antennas are so awkward. Mine are in the nose of the glider since the early 27a do not have carbon on the nose. Works great. I recommended those with carbon nose to put the antennas below the glare shield with only the top sticking out. Looks much better and still working well enough. There are other solutions.
Ramy
Old October 31st 15, 04:54 PM posted to rec.aviation.soaring
JS
Craggy Aero has a few antenna options...
Old October 31st 15, 05:05 PM posted to rec.aviation.soaring
jfitch
Ramy
If you don't put it on the glare shield, how are you going to cover it with a tin foil hat when those awful leachers are about?
Old October 31st 15, 08:21 PM posted to rec.aviation.soaring
Well, this is an old discussion.
I already published my home built bottom fed Flarm (and ADSB) dipole antennas 2 years ago.
https://sites.google.com/site/threeu...flarm-antennas
By now, my antennas are painted black.
I personally did not like the bulkiness of the standard center fed dipoles either.
That's why I build my own thin "whisker" ones.
However, it has been discussed here in the past also already that the fact that humans have stereoscopic vision, means that an object like a Flarm antenna at 2-3 ft distance does not limit / obstruct the human field of view.
I cannot subscribe to Ramy's recommendation to put the antenna under the glareshield without knowing what is under your glareshield.
On my carbon ship, there is metal tubing structure right under the glareshield. Putting the antennas down in between that structure would significantly impact the performance.
In general, placing an antenna close to metal structures, like frames or metal housing of electronics boxes (radios, transponders, varios, flarm boxes, etc.) is a bad idea.
I needed to raise the antennas as high as possible above the glareshield
See images in the link above.
On other ships like modern gliders with a panel attached to a glass composite bottom shelf, this might be a viable option.
With respect to placing antennas on the side rails, you have to keep in mind that while the Flarm systems have an option for 2 receive antenna, there is only 1 Flarm transmit (and receive) antenna. And then there is of course the single ADSB receive antenna.
So, if you would place the Flarm Tx/Rx antenna on one side and the ADSB receive antenna on the other side of the canopy frame, you would get a skewed range diagram.
Difficult to say how skewed. Would be worth while an experiment with the Flarm range evaluation tool.
3U
Old October 31st 15, 08:56 PM posted to rec.aviation.soaring
To be a bit clearer on the side rail mounting:
If you use both Flarm antennas (A and B) on either side of the canopy then your Flarm reception should be well balanced.
However, your Flarm transmission would be skewed to one side as only the Flarm A antenna transmits. The Flarm B antenna is receive only.
Mounting the ADSB/PCAS antenna on either side rail should not be an issue as the transponders are transmitting at very high power levels (150-250 Watts)
So, you will be receiving more than enough signal from a transponder equipped aircraft a few miles away.
Old October 31st 15, 09:06 PM posted to rec.aviation.soaring
Richard[_9_]
I am getting 4 nm to 8 nm range with my antennas. 1/2 wave dipole on the panel and the standard T antenna in the nose.
Analysis on this page at the bottom.
http://www.craggyaero.com/cables_&_antennas.htm
Richard
Old October 31st 15, 09:28 PM posted to rec.aviation.soaring
bumper[_4_]
I'm offering new covert, semi-low drag mounts.
https://upload.wikimedia.org/wikiped...e_110_1945.jpg
Old October 31st 15, 09:36 PM posted to rec.aviation.soaring
jfitch
And, with that on your glider, you probably won't have to worry about the leachers as they will be well in front!
second PowerFlarm antenna Andrzej Kobus Soaring 10 November 2nd 15 03:39 PM
PowerFLARM antenna mounts Dave Nadler Soaring 52 August 14th 14 01:34 PM
PowerFlarm antenna recommendation Sam Discusflyer[_2_] Soaring 3 April 7th 13 08:41 PM
PowerFLARM antenna mounts Dave Nadler Soaring 0 July 4th 12 04:11 PM
PowerFlarm antenna install Sam Zimmerman Soaring 10 November 11th 10 09:54 PM
