On Saturday, October 31, 2015 at 4:21:12 PM UTC-4, wrote:
Well, this is an old discussion. I already published my home built bottom fed Flarm (and ADSB) dipole antennas 2 years ago. https://sites.google.com/site/threeu...flarm-antennas By now, my antennas are painted black. Thanks 3U for contributing. Yes I'm familiar with your work and website. I wish you would expand your article to include "how to" details so DIY guys like me could fabricate their own antennas. Regarding PowerFLARM antenna A, what amount of signal degradation would be experienced if there were two "A" antennas by means of some sort of splitter? |
On Sat, 31 Oct 2015 15:28:07 -0700, bensoaring wrote:
On Saturday, October 31, 2015 at 4:21:12 PM UTC-4, wrote: Well, this is an old discussion. I already published my home built bottom fed Flarm (and ADSB) dipole antennas 2 years ago. https://sites.google.com/site/threeu...rm/powerflarm- antennas By now, my antennas are painted black. Thanks 3U for contributing. Yes I'm familiar with your work and website. I wish you would expand your article to include "how to" details so DIY guys like me could fabricate their own antennas. Regarding PowerFLARM antenna A, what amount of signal degradation would be experienced if there were two "A" antennas by means of some sort of splitter? A thought: you can pick up nylon-covered steel trace (1.3mm OD, the steel trace is 1.0mm diameter from eBay (10m for $8.95) and good fishing shops also stock it. Crimp the end over and add a blob of epoxy for eye protection and there's a very thin antenna. On a glare shield one of these would be almost invisible. The older Swiss FLARMs, used antennae which were just a 1/4 wave length of what looked like 0.8mm (1/32") music wire mounted at the centre of a circular 80mm diameter metal ground plane. The fox-hunting crowd, i.e. orienteers who run XC in search of a hidden radio beacon) make Yagi DF antennae from steel tape-measures and plastic plumbing pipe which seem to work pretty well, so would this nylon-coated steel trace be any good for making up PowerFLARM dipoles or bottom-fed antennae? I'd be interested to hear what somebody who understands antennae thinks about using this stuff or even thinner trace material: it is available down to 20 lb breaking strain. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Saturday, October 31, 2015 at 6:56:02 PM UTC-4, Martin Gregorie wrote:
On Sat, 31 Oct 2015 15:28:07 -0700, bensoaring wrote: On Saturday, October 31, 2015 at 4:21:12 PM UTC-4, wrote: Well, this is an old discussion. I already published my home built bottom fed Flarm (and ADSB) dipole antennas 2 years ago. https://sites.google.com/site/threeu...rm/powerflarm- antennas By now, my antennas are painted black. Thanks 3U for contributing. Yes I'm familiar with your work and website. I wish you would expand your article to include "how to" details so DIY guys like me could fabricate their own antennas. Regarding PowerFLARM antenna A, what amount of signal degradation would be experienced if there were two "A" antennas by means of some sort of splitter? A thought: you can pick up nylon-covered steel trace (1.3mm OD, the steel trace is 1.0mm diameter from eBay (10m for $8.95) and good fishing shops also stock it. Crimp the end over and add a blob of epoxy for eye protection and there's a very thin antenna. On a glare shield one of these would be almost invisible. The older Swiss FLARMs, used antennae which were just a 1/4 wave length of what looked like 0.8mm (1/32") music wire mounted at the centre of a circular 80mm diameter metal ground plane. The fox-hunting crowd, i.e. orienteers who run XC in search of a hidden radio beacon) make Yagi DF antennae from steel tape-measures and plastic plumbing pipe which seem to work pretty well, so would this nylon-coated steel trace be any good for making up PowerFLARM dipoles or bottom-fed antennae? I'd be interested to hear what somebody who understands antennae thinks about using this stuff or even thinner trace material: it is available down to 20 lb breaking strain. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Smiling...us redneck bass fisherman know this as nylon coated stainless steel fishing leader. |
Does one of those neat caps in the photo come with each unit?
On Sat, 31 Oct 2015 17:20:18 -0700, bensoaring wrote:
On Saturday, October 31, 2015 at 6:56:02 PM UTC-4, Martin Gregorie wrote: On Sat, 31 Oct 2015 15:28:07 -0700, bensoaring wrote: On Saturday, October 31, 2015 at 4:21:12 PM UTC-4, wrote: Well, this is an old discussion. I already published my home built bottom fed Flarm (and ADSB) dipole antennas 2 years ago. https://sites.google.com/site/threeu...rm/powerflarm- antennas By now, my antennas are painted black. Thanks 3U for contributing. Yes I'm familiar with your work and website. I wish you would expand your article to include "how to" details so DIY guys like me could fabricate their own antennas. Regarding PowerFLARM antenna A, what amount of signal degradation would be experienced if there were two "A" antennas by means of some sort of splitter? A thought: you can pick up nylon-covered steel trace (1.3mm OD, the steel trace is 1.0mm diameter from eBay (10m for $8.95) and good fishing shops also stock it. Crimp the end over and add a blob of epoxy for eye protection and there's a very thin antenna. On a glare shield one of these would be almost invisible. The older Swiss FLARMs, used antennae which were just a 1/4 wave length of what looked like 0.8mm (1/32") music wire mounted at the centre of a circular 80mm diameter metal ground plane. The fox-hunting crowd, i.e. orienteers who run XC in search of a hidden radio beacon) make Yagi DF antennae from steel tape-measures and plastic plumbing pipe which seem to work pretty well, so would this nylon-coated steel trace be any good for making up PowerFLARM dipoles or bottom-fed antennae? I'd be interested to hear what somebody who understands antennae thinks about using this stuff or even thinner trace material: it is available down to 20 lb breaking strain. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Smiling...us redneck bass fisherman know this as nylon coated stainless steel fishing leader. I don't fish (well, once or twice trolling for trout on Lake Taupo) and have only used this steel trace (the UK term) for connecting controls to the timer in free flight model aircraft. Would you use it for a FLARM antenna? I suppose you'd have to crimp the feeder connection as its unlikely to take solder. BTW, here's a link to one of those Yagis. In case you're wondering, the reason they like 'em is partly because they're light and partly because you can crash through the undergrowth with one without breaking or bending it: http://theleggios.net/wb2hol/projects/rdf/tape_bm.htm -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Sunday, November 1, 2015 at 1:41:26 AM UTC-7, Martin Gregorie wrote:
On Sat, 31 Oct 2015 17:20:18 -0700, bensoaring wrote: On Saturday, October 31, 2015 at 6:56:02 PM UTC-4, Martin Gregorie wrote: On Sat, 31 Oct 2015 15:28:07 -0700, bensoaring wrote: On Saturday, October 31, 2015 at 4:21:12 PM UTC-4, wrote: Well, this is an old discussion. I already published my home built bottom fed Flarm (and ADSB) dipole antennas 2 years ago. https://sites.google.com/site/threeu...rm/powerflarm- antennas By now, my antennas are painted black. Thanks 3U for contributing. Yes I'm familiar with your work and website. I wish you would expand your article to include "how to" details so DIY guys like me could fabricate their own antennas. Regarding PowerFLARM antenna A, what amount of signal degradation would be experienced if there were two "A" antennas by means of some sort of splitter? A thought: you can pick up nylon-covered steel trace (1.3mm OD, the steel trace is 1.0mm diameter from eBay (10m for $8.95) and good fishing shops also stock it. Crimp the end over and add a blob of epoxy for eye protection and there's a very thin antenna. On a glare shield one of these would be almost invisible. The older Swiss FLARMs, used antennae which were just a 1/4 wave length of what looked like 0.8mm (1/32") music wire mounted at the centre of a circular 80mm diameter metal ground plane. The fox-hunting crowd, i.e. orienteers who run XC in search of a hidden radio beacon) make Yagi DF antennae from steel tape-measures and plastic plumbing pipe which seem to work pretty well, so would this nylon-coated steel trace be any good for making up PowerFLARM dipoles or bottom-fed antennae? I'd be interested to hear what somebody who understands antennae thinks about using this stuff or even thinner trace material: it is available down to 20 lb breaking strain. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Smiling...us redneck bass fisherman know this as nylon coated stainless steel fishing leader. I don't fish (well, once or twice trolling for trout on Lake Taupo) and have only used this steel trace (the UK term) for connecting controls to the timer in free flight model aircraft. Would you use it for a FLARM antenna? I suppose you'd have to crimp the feeder connection as its unlikely to take solder. BTW, here's a link to one of those Yagis. In case you're wondering, the reason they like 'em is partly because they're light and partly because you can crash through the undergrowth with one without breaking or bending it: http://theleggios.net/wb2hol/projects/rdf/tape_bm.htm -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Yagi antenna are great for highly directional transmit/receive. I.E. if you placed a yagi/flarm antenna pointing forward, the signal in any other direction would be practically non-existant. Not a good choice for a signal you want to send/receive in all directions. Mike |
On Fri, 06 Nov 2015 18:26:37 -0800, SoaringXCellence wrote:
Yagi antenna are great for highly directional transmit/receive. I.E. if you placed a yagi/flarm antenna pointing forward, the signal in any other direction would be practically non-existant. Not a good choice for a signal you want to send/receive in all directions. Of course. I know that: re-read the last few posts on the thread. I was asking if anybody had experience with using nylon-coated steel fishing trace for bottom-fed 1/4 wave FLARM dipoles. Its so thin you'd soon cease to notice antennas made of it mounted on top of your glare shield. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Sat, 07 Nov 2015 17:33:00 +0000, Martin Gregorie wrote:
On Fri, 06 Nov 2015 18:26:37 -0800, SoaringXCellence wrote: Yagi antenna are great for highly directional transmit/receive. I.E. if you placed a yagi/flarm antenna pointing forward, the signal in any other direction would be practically non-existant. Not a good choice for a signal you want to send/receive in all directions. Of course. I know that: re-read the last few posts on the thread. I was asking if anybody had experience with using nylon-coated steel fishing trace for bottom-fed 1/4 wave FLARM dipoles. Its so thin you'd soon cease to notice antennas made of it mounted on top of your glare shield. For 'dipole' read 'antenna'. Sorry 'bout that. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Flarm antennaes are HIDEOUS. i would HATE to put one of those into my cockpit. in fact it would be one of the reasons i would decide not to put a unit it. now, before starting an argument, i'm not anti-flarm. but i AM anti ****ty hideous flarm antennae. i didn't spend all that time making our glider cockpit beautiful to stick that ugly piece right in my forward field of vision. ew.
On Monday, November 9, 2015 at 10:44:25 AM UTC-6, ND wrote:
Flarm antennaes are HIDEOUS. i would HATE to put one of those into my cockpit. in fact it would be one of the reasons i would decide not to put a unit it. now, before starting an argument, i'm not anti-flarm. but i AM anti ****ty hideous flarm antennae. i didn't spend all that time making our glider cockpit beautiful to stick that ugly piece right in my forward field of vision. ew. Hmm, you obviously are in the "die early and leave a good looking corpse" camp! Me, I can take a hideous antenna if it works. Just put it where you won't see it! Cheers, Kirk 66 |
second PowerFlarm antenna | Andrzej Kobus | Soaring | 10 | November 2nd 15 03:39 PM |
PowerFLARM antenna mounts | Dave Nadler | Soaring | 52 | August 14th 14 01:34 PM |
PowerFlarm antenna recommendation | Sam Discusflyer[_2_] | Soaring | 3 | April 7th 13 08:41 PM |
PowerFLARM antenna mounts | Dave Nadler | Soaring | 0 | July 4th 12 04:11 PM |
PowerFlarm antenna install | Sam Zimmerman | Soaring | 10 | November 11th 10 09:54 PM |
