PowerFlarm range tool
Old November 16th 15, 05:15 PM posted to rec.aviation.soaring
Mark628CA
Default PowerFlarm range tool
I have run several flights through the PowerFlarm range tool, and my coverage seems adequate, but I am wondering if anyone has a method of determining 3D coverage? The tool shows a decent depiction of horizontal coverage, but I wouldn't mind having an idea of the coverage above and (especially) below.
Also, in a previous thread, one poster (mark...@lennoxengineering) mentioned he had developed a tool to splice together several flights. Is this available for others' use?
Old November 17th 15, 03:30 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Mon, 16 Nov 2015 08:15:56 -0800 (PST), Mark628CA
others' use?
If you are comfortable with old DOS commands, you can use the
following to concatenate multiple IGC files and submit the result to
the Range Analyzer.
- Put the IGC files of interest in a temp directory
- Open a 'cmd' shell in the directory of your IGC files.
- Enter the command: type *.igc all.igc
- Upload all.igc to the range analyzer
There is an upper limit to the size of the file the Range Analyzer can
handle, so the number of files concatenated is not unlimited.
Bob
Old November 17th 15, 06:24 AM posted to rec.aviation.soaring
Old discussion:
https://groups.google.com/forum/#!searchin/rec.aviation.soaring/wx$20flarm/rec.aviation.soaring/xPaHe0jK5Tk/g-WNEik8iBsJ
Google "concatenate" for commands in different operating systems
PowerFlarm Butterfly Display not changing range [email protected] Soaring 2 May 1st 14 05:54 PM
PowerFlarm: 2.7 Vertical Range [email protected] Soaring 8 April 10th 13 12:27 AM
PowerFlarm Range Analysis Richard[_9_] Soaring 0 March 25th 13 05:43 PM
PowerFlarm BRICK range issues - are we alone???? Mark Soaring 79 October 17th 12 01:17 PM
PowerFLarm expected range [email protected] Soaring 6 August 30th 12 04:43 PM
