XCSoar and Wind
Old November 15th 15, 03:39 PM posted to rec.aviation.soaring
Dan Marotta
Default XCSoar and Wind
Hello XCSoar users. I love my XCSoar/Streak combo in my glider and I
installed a second Streak in the Pipistrel Sinus. In the Sinus there is
no computer/GPS to feed the Streak and so the XCSoar relies on the
internal GPS of the Streak. With the solo setup, I never see winds.
I've flown zig-zags and circles and never get a wind presentation. In
the settings under Config System Glide Computer Wind, I have Auto
Wind - Both selected. Any ideas.
Dan, 5J
Old November 15th 15, 11:32 PM posted to rec.aviation.soaring
TND
Instead of "Both", try "Circling". That worked on my Streak before I had a vario connected to it.
On Monday, November 16, 2015 at 2:39:20 AM UTC+11, Dan Marotta wrote:
Hello XCSoar users.* I love my XCSoar/Streak combo in my glider and
I installed a second Streak in the Pipistrel Sinus.* In the Sinus
there is no computer/GPS to feed the Streak and so the XCSoar relies
on the internal GPS of the Streak.* With the solo setup, I never see
winds.* I've flown zig-zags and circles and never get a wind
presentation.* In the settings under Config System Glide
Computer Wind, I have Auto Wind - Both selected. * Any ideas.
Dan, 5J
This message is intended for the addressee named and may contain
confidential information. If you are not the intended recipient, please
delete it and notify the sender. Views expressed in this message are those
of the individual sender, and are not necessarily the views of their
organisation.
Old November 16th 15, 05:35 PM posted to rec.aviation.soaring
Dan Marotta
Thanks - I'll try that on the next flight.
I installed a second Streak in the Pipistrel Sinus. In the Sinus
on the internal GPS of the Streak. With the solo setup, I never see
winds. I've flown zig-zags and circles and never get a wind
presentation. In the settings under Config System Glide
Computer Wind, I have Auto Wind - Both selected. Any ideas.
Dan, 5J
Dan, 5J
Old November 17th 15, 02:59 AM posted to rec.aviation.soaring
Dan,
Make sure you enable XCsoar to use the internal GPS device. You must do this explicitly. ConfigDevices then A: Built-in GPS & sensors....make sure it is enabled
Old November 18th 15, 05:49 PM posted to rec.aviation.soaring
Ramy[_2_]
Dan, also make sure your wind is not set to "external" if you are not connected to external source. Which version are you using?
Ramy
Old November 18th 15, 06:43 PM posted to rec.aviation.soaring
Dan Marotta
Ramy,
I'm running version 6.8.2. I can't find "external" (to turn it off) in
the configuration screen on the PC simulator. Next time I get to the
airport, I'll see about setting went to NOT external.
Ramy
Dan, 5J
Old November 18th 15, 11:11 PM posted to rec.aviation.soaring
Ramy
"Prefer external wind" setting was removed from version 6.8 and later.
Old November 19th 15, 05:09 AM posted to rec.aviation.soaring
Ramy[_2_]
I haven't upgraded to 6.8 yet. So how do you tell XCSoar to use external wind instead of calculating it?
Ramy
Old November 19th 15, 05:19 AM posted to rec.aviation.soaring
Ramy
Seems like you can't....
David
Old November 19th 15, 05:34 AM posted to rec.aviation.soaring
Ramy[_2_]
So is it always using external wind when available? I sure hope so since I found 302 wind calculation far more accurate and reliable. Also some flight computers nowadays can calculate wind instantaneously and very accurately.
Ramy
XCSoar and V7 [email protected] Soaring 8 January 17th 14 09:19 PM
XCSoar wind calculation Martin Gregorie[_5_] Soaring 11 October 8th 09 05:26 AM
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) JR[_2_] Aviation Photos 0 August 13th 08 09:36 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
