CQ Oshkosh, CQ Oshkosh
Old July 1st 03, 07:22 PM
Warren & Nancy
Default CQ Oshkosh, CQ Oshkosh
My aircraft radio doesn't go that high!
Jim Weir wrote:
Just a friendly reminder...
The airborne simplex national calling frequency is the same as the ground
frequency...146.520. This frequency also works well on the ground at Oshkosh.
Rarely is it busy for more than a couple of minutes at a time.
For the repeater frequencies, pick up a copy of the Oshkosh Frequency List
downloadable from the home page at www.rstengineering.com
Listen for me and give me a shout...N 73 CQ BlueOnBlue 182.
To Nebraska on Sunday, to St. Louis on Monday, to Oshkosh on Tuesday, weather
gods willing.
http://www.rst-engr.com
Old July 2nd 03, 07:17 AM
My radio does! However when you key up on 34-94 all you hear is
squeal from 50 repeaters at the same time. :-(
146.52 works VERY well into a 10,000 ft high antenna with 1db coax
loss.
John
On Tue, 01 Jul 2003 13:22:26 -0400, Warren & Nancy
gods willing.
Old July 2nd 03, 04:12 PM
Ron Natalie
wrote in message ...
34-10-4 as we call it around here isn't much better on the ground :-)
Repeater operation is going to be a problem in most parts of the country
on 2 meters. Just far too congested. Simplex is the way to go in the air.
Old July 3rd 03, 07:24 PM
John Mireley
This brings up a question I hadn't thought of.
Are there FCC/FAA rules regrarding operation
HAM radios from experimental aircraft.
Thanks
Old July 3rd 03, 07:42 PM
Jim Weir
Only FAR 91.3 and 91.21. Other than that, the FCC could give a rat's hiney less
where the radio is so long as the operator has the appropriate class of amateur
license for the mode being used.
John Mireley
-This brings up a question I hadn't thought of.
-Are there FCC/FAA rules regrarding operation
-HAM radios from experimental aircraft.
-Thanks
EAA Oshkosh Airventure 2004 In-Home Housing David Schultz Aerobatics 0 May 21st 04 07:30 AM
Oshkosh images posted!!! Tyson Rininger Aerobatics 0 November 8th 03 12:33 PM
