GP 14 Update and Video of Innovative Motor Deployment System for GP14 E Motorglider
Old December 24th 15, 03:43 AM posted to rec.aviation.soaring
Tim[_11_]
Default GP 14 Update and Video of Innovative Motor Deployment System for GP14 E Motorglider
Hello All:
While progress has not been as quick as we had hoped for, plans are moving forward to take the GP 14 E Motorglider to first flight very early in the new year and then for first customer deliveries soon after just in time for the beginning of the European racing calendar.
For a taste of what is to come, please have a look at the two links below for "first Look" at the innovative pylon/motor deployment system for this new motorglider in the 13.5 Meter Class.
https://www.facebook.com/gpgliders/v...95333550523888
https://www.facebook.com/gpgliders/v...95321143858462
- Quick Deployment (@ 5 seconds to deployment and power on)
- Minimal Deployed Drag (Pre-start/Post-shutdown)
- No Aligning of the Prop for Quick Stowage (@5 seconds to full retraction from power off)
Pretty cool!
Tim McAllister "EY"
GP Gliders USA
Old December 24th 15, 04:20 AM posted to rec.aviation.soaring
Default GP 14 Update and Video of Innovative Motor Deployment System forGP 14 E Motorglider
On Wednesday, December 23, 2015 at 7:44:01 PM UTC-8, Tim wrote:
Hello All:
Pretty cool!
Tim McAllister "EY"
GP Gliders USA
The batteries will be in the wings or in the fuselage?
Old December 24th 15, 05:16 AM posted to rec.aviation.soaring
Tim[_11_]
Hello All:
Pretty cool!
Tim McAllister "EY"
GP Gliders USA
The battery packs will be located in the wings and connected for easy removal for charging separate from the glider should that be required.
Tim McAllister "EY"
GP Gliders USA
Old December 24th 15, 02:47 PM posted to rec.aviation.soaring
pjschae
What is the the duration of the batteries?
Old December 24th 15, 02:49 PM posted to rec.aviation.soaring
pjschae
....and self-launch or just sustainer?
Old December 24th 15, 04:00 PM posted to rec.aviation.soaring
http://www.gpgliders.com/gp-14-e-velo
Old December 24th 15, 06:51 PM posted to rec.aviation.soaring
lynn
Hello All:
Pretty cool!
Tim McAllister "EY"
GP Gliders USA
Tim, Do you have a price list? Will there be any sales presence at the SSA Convention?
Old December 27th 15, 06:41 AM posted to rec.aviation.soaring
krasw
The published masses of E-model are just not realistic. GP website says 135 kg empty weight for pure glider and 170 kg for electric one. Even production glider mass is bound to be higher than specified (it invariably is). Current FES installations with 4 kWh batteries weigh 70-75 kg extra with over 30 kg for batteries alone. How an earth GP is going to pull of this feat, doing the whole installation with 35kg weight penalty? FES installations have very little structure for motor/propeller, whereas GP uses complex mast (which looks nice BTW) and doors. It seems quite clear that to participate 13.5m comp you would have to strip pretty much everything from GP-E.
Old December 27th 15, 06:54 AM posted to rec.aviation.soaring
Where do you get 75 kg for FES weight? I see 45 kg on the FES website.
Old December 27th 15, 10:53 AM posted to rec.aviation.soaring
krasw
That's pretty consistently the difference in empty weight when comparing FES-equipped glider to similar pure glider. Check LAK-17B for example.
New Innovative GPS devices jennyjenny Instrument Flight Rules 0 April 14th 08 10:27 AM
Relief System Update [email protected] Soaring 4 March 16th 07 03:49 AM
First-hand video of a BRS deployment. Jim Logajan Piloting 158 March 2nd 07 09:15 PM
First-hand video of a BRS deployment. Jim Logajan Home Built 166 March 2nd 07 09:15 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
