PowerFlarm Core + Libelle 301
Old December 25th 15, 04:03 PM posted to rec.aviation.soaring
Kevin Christner
Default PowerFlarm Core + Libelle 301
That's what I was getting at. Wondering if it is worthwhile.
Old December 25th 15, 04:50 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Try it with one (FLARM A) and run it through the RF Range Analyzer. If you have relatively circular coverage and adequate range, you may elect not to install FLARM B (if you are not grandfathered, this is also at extra cost).. If you don't have good circular coverage, you can experiment with FLARM B..
I have an SZD-55 and it gives me a roughly circular 5.5 km, which is good for me. A friend, also with an original CORE, has the same type glider, and had to install FLARM B to get a good all-around view. Antenna placement is fairly critical (distance between antennae, and GPS antennae). 'Verticality' of FLARM and ADS-B is important - set it so it is vertical in flight. This is due to the dipole antenna beamform.
The second antenna gives you a look at parts of the sky the other may not see.
You can do some of this on the ground. Install your system, and then drive around it with a FLARM Portable in your car (airfields have a lot of space to do this kind of thing). Run the range analyzer, or have a buddy drive it around while you observe in the cockpit ranges.
I've installed FLARMs in club ASW-20, ASW-24, Puchacz, own SZD-55, Junior. All work with only FLARM A (but none have carbon fibre and are transparent to RF (except for metal instruments); I run the RF Analyzer whenever an instrument change is made, and a couple of times a year to ensure the 'smiling piece of meat' (me) is protected.
Dan
2D
PowerFlarm Core and RS232 Tom Roth Soaring 3 May 28th 15 11:09 PM
Flarmview and Powerflarm Core Config File? Papa3[_2_] Soaring 4 May 18th 15 10:51 PM
PowerFLARM Core secondary FLARM antenna [email protected] Soaring 27 October 7th 14 01:53 PM
For Sale - Used PowerFLARM Core v1 Paul Remde Soaring 1 May 30th 14 03:09 AM
Powerflarm Brick/Core ADSB Range Sean F (F2) Soaring 3 September 5th 13 03:10 PM
