Radio acting up
Old January 26th 16, 02:44 AM posted to rec.aviation.soaring
Blake Seese 3Y
Default Radio acting up
On Sunday, October 18, 2015 at 3:05:51 PM UTC-6, Blake Seese 3Y wrote:
Hello all,
My Becker 4201 just started acting up. Specifically, it has a cyclic regular dead spot when transmitting, so the person listening to you gets about half of each word. It receives just fine, and all functions work as they should. Same thing happens with a fully charged battery or one that has been used for several hours. Has anyone ever run in to this?
Thanks,
3Y
Finally got to the radio in my glider and found that with all the instruments on, I am getting a huge voltage drop at the radio when I transmit causing the cyclic drop of the signal. With all the other instruments off and a fresh battery, I have no problems. Also the voltage is dropping at the radio and not the battery. Looks like I need to replace the wiring from the batteries to the panel and redo the wiring behind the panel. Planning on using one battery for the radio, and one for the transponder and everything else. I'm also going to add circuit breakers and run two master switches, one for each battery. Does anyone have any knowledge of the tyco circuit breakers sold by aircraft spruce? They are pretty low cost, but are they cheap?
Thanks,
3Y
Old January 26th 16, 02:51 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Hello all,
Thanks,
3Y
Thanks,
3Y
Which radio?
Fuses have lower voltage drop (much lower) than circuit breakers.
When you say, fresh battery, is that just off charge or new?
What other loads on the battery? varios, computer, pda, flarm, cameras?
Lead acid or LiFePo?
Real aircraft wiring, proper guage?
Old January 26th 16, 03:49 AM posted to rec.aviation.soaring
Blake Seese 3Y
Hello all,
Thanks,
3Y
Ship was rewired by the previous owner, not sure if he used aircraft wiring.. Batteries are lead acid 12v. 12amp hr, one new, one about two years old. Currently one battery supplies everything, instruments are Power Flarm Core w/ Butterfly display, Cambridge 302 vario, Borgelt B400 vario, Oudie 2, Becker 4201 radio, Trigg 21 transponder. Batteries both have about 12.8 volts just off the charger. Voltage at radio drops about 2.5 to 3 volts when transmitting and about .4volts at the battery when transmitting.
Old January 26th 16, 05:14 AM posted to rec.aviation.soaring
Hello all,
Thanks,
3Y
Ship was rewired by the previous owner, not sure if he used aircraft wiring. Batteries are lead acid 12v. 12amp hr, one new, one about two years old.. Currently one battery supplies everything, instruments are Power Flarm Core w/ Butterfly display, Cambridge 302 vario, Borgelt B400 vario, Oudie 2, Becker 4201 radio, Trigg 21 transponder. Batteries both have about 12.8 volts just off the charger. Voltage at radio drops about 2.5 to 3 volts when transmitting and about .4volts at the battery when transmitting.
I would start at the battery and go back through the wiring to see where the voltage is dropping.
Could be a loose connection, corroded connection, broken wire (inside the insulation), etc.
Since the voltage drop is different between what the radio see's and at the battery, it's a wiring issue.
Old January 26th 16, 02:54 PM posted to rec.aviation.soaring
Hello all,
Thanks,
3Y
Thanks,
3Y
Use fuses, not circuit breakers. Breakers can cause a big voltage drop.
UH
Old January 26th 16, 03:07 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Hello all,
Thanks,
3Y
Your power budget:
Core - 165 mA
Butterfly - 45 mA
302 - 350mA
B400 - 200 mA
Oudie 2 - 200 - 220 mA plus 200 mA if battery is being charged
TT21 - 200 mA
So about 1180 mA with no radio (1380 mA if Oudie is charging - I don't know if you bring it to the airport charged or not)
The radio: Becker 4201 - 70 mA standby 500 mA receive 2.5 A transmit
So draw is (worst case, Oudie is charging):
1.45 A radio standby
1.88 A radio receive (don't know how active your frequency is)
3.88 A radio transmit
That's a lot of draw for one battery when the radio is transmitting. I have an ammeter that I put in between my battery and the glider to test draw - inexpensive way of looking at what I'm asking the battery to do. By all means, check the wiring, but you might be better off with two circuits (my opinion).
An excellent presentation on glider avionic wiring is the "2015 Nephi OLC Camp presentation", which you can download at: http://aviation.derosaweb.net/presentations/. Excellent in all respects - note the comments on wire size, and circuit breakers... Great work by John DeRosa.
Old January 26th 16, 07:08 PM posted to rec.aviation.soaring
On Sunday, October 18, 2015 at 5:05:51 PM UTC-4, Blake Seese 3Y wrote:
Hello all,
Thanks,
3Y
What are you using to test this?
I had a similar problem a few years back
By chance are you using an Icom handheld?
Randy
Old January 26th 16, 07:31 PM posted to rec.aviation.soaring
Blake Seese 3Y
Hello all,
Thanks,
3Y
Thank you to all who responded, super helpful info! I will post again once I have addressed the wiring.
Best to all,
Blake - 3Y
Old January 26th 16, 11:06 PM posted to rec.aviation.soaring
Hello all,
Thanks,
3Y
Ship was rewired by the previous owner, not sure if he used aircraft wiring. Batteries are lead acid 12v. 12amp hr, one new, one about two years old. Currently one battery supplies everything, instruments are Power Flarm Core w/ Butterfly display, Cambridge 302 vario, Borgelt B400 vario, Oudie 2, Becker 4201 radio, Trigg 21 transponder. Batteries both have about 12.8 volts just off the charger. Voltage at radio drops about 2.5 to 3 volts when transmitting and about .4volts at the battery when transmitting.
Your power budget:
Core - 165 mA
Butterfly - 45 mA
302 - 350mA
B400 - 200 mA
TT21 - 200 mA
Excellent post, lot's of thought & research.
My only issue is...... why the drop at the radio (in voltage) but not the drop at the battery (in voltage)?
If the total system was overdrawing the battery (or, the drop when transmitting...), wouldn't you think the battery voltage drop would be close to the voltage drop at the radio?
Just asking....
Old January 26th 16, 11:33 PM posted to rec.aviation.soaring
On Tuesday, January 26, 2016 at 6:06:49 PM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
Hello all,
Thanks,
3Y
Your power budget:
Core - 165 mA
Butterfly - 45 mA
302 - 350mA
B400 - 200 mA
TT21 - 200 mA
An excellent presentation on glider avionic wiring is the "2015 Nephi OLC Camp presentation", which you can download at: http://aviation.derosaweb..net/presentations/. Excellent in all respects - note the comments on wire size, and circuit breakers... Great work by John DeRosa.
Just asking....
Distribution losses . Wire size, terminations, current protection, ground problems, etc.
UH
Acting FAA Administrator Pro User Fees Larry Dighera Piloting 0 October 25th 07 06:03 PM
Acting FAA Administrator FredGarvinMaleProstitute Piloting 3 September 28th 07 02:36 PM
GoogleGroups Acting Hinky? Jay Honeck Piloting 37 May 5th 07 07:54 PM
Garmin 196 acting up Glenn Westfall Piloting 8 March 17th 04 12:32 PM
Garmin 196 acting up Peter Duniho Piloting 3 March 16th 04 01:16 PM
